Z83-II and other Atom based devices
midnightwatcher
Re: Z83-II and other Atom based devices
Post by midnightwatcher »
Username wrote: Thu Aug 30, 2018 7:33 pm root@BeelinkS2:~# aplay -l
aplay: device_list:270: no soundcards found...
root@BeelinkS2:~# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
This is the sound card that is installed per pciutils: lspci | grep "Audio"
00:0e.0 Audio device: Intel Corporation Device 3198 (rev 03)
Have you managed to get audio working? I have a Z83 and decided to give Kodi a try, but I also have "no soundcards found" ...
midnightwatcher
Any update? Or is an updated kernel likely needed?
Username
Post by Username »
soundcard stil not showing up. No luck
You might want to try Linux kernel 4.19 from backports:
apt install -t stretch-backports linux-image-amd64
Username
Post by Username »
that fixed the no sound card problem! thanks!
@Username
Thanks for feedback. Good that Debian Buster was just released yesterday, so we officially release Buster images for x86_64 soon.
