Z83-II and other Atom based devices
kevinshane
Re: Z83-II and other Atom based devices
Post by kevinshane »
Hi, would u please add auto find the fastest mirror for dietpi x86 apt-get update command? I am trying to install the beta version, so far so good, however, the default ftp.debian.org is toooooo slow for me, it took around 1hour during apt get update(the os auto start updating and I can't modify the source list) :oops: please ... pretty please , thanks~
and btw, awesome job guys, please keep it going, thanks
Shane
n8xyn
Post by n8xyn »
I've had mine up and running Transmission, Sickrage and openvpn 24/7 since this thread started without a single issue. I also installed Mate as an "incase" desktop. It's really very stable so far.
johnvick
Legend
Post by johnvick »
Just got mine today but not allowed it until Dec 25th :)
Fourdee
Post by Fourdee »
johnvick wrote:Just got mine today but not allowed it until Dec 25th :)
LOL :D
Username
Post by Username »
Hi, just installed dietpi on Beelink S2, but there is no audio support. Any update on when audio will be included in dietpi for beelink? thanks
Fourdee
Post by Fourdee »
Username wrote: Wed Aug 22, 2018 1:16 am Hi, just installed dietpi on Beelink S2, but there is no audio support. Any update on when audio will be included in dietpi for beelink? thanks
Very strange, on my Z83-II, audio support is working was setup in dietpi-config > audio:
root@DietPi:~# aplay -l
card 0: bytcrrt5651 [bytcr-rt5651], device 0: Audio (*) []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: bytcrrt5651 [bytcr-rt5651], device 1: Deep-Buffer Audio (*) []
  Subdevices: 1/1
card 1: Audio [Intel HDMI/DP LPE Audio], device 0: HdmiLpeAudio [Intel HDMI/DP LPE Audio]
  Subdevices: 1/1
card 1: Audio [Intel HDMI/DP LPE Audio], device 1: HdmiLpeAudio [Intel HDMI/DP LPE Audio]
  Subdevices: 1/1
card 1: Audio [Intel HDMI/DP LPE Audio], device 2: HdmiLpeAudio [Intel HDMI/DP LPE Audio]
  Subdevices: 1/1
it could be the beelink is using a non-standard audio chipset. Please can you paste results
aplay -l
aplay -L
Username
Post by Username »
root@BeelinkS2:~# aplay -l
aplay: device_list:270: no soundcards found...
root@BeelinkS2:~# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
This is the sound card that is installed per pciutils: lspci | grep "Audio"
00:0e.0 Audio device: Intel Corporation Device 3198 (rev 03)
kenhas
Post by kenhas »
Anybody got wifi working on these devices? I think mine is a first generation thing and maybe wifi is not working with this model. This is the model I have: https://www.banggood.com/nl/Z83-Windows ... rehouse=CN
But no matter what i try, i can't get wifi to work. I don't see much questions about wifi with these boxes so I assume people got it working.
When i use dietpi-config, I get the message "Wifi must be enabled before settings can be changed", i press "Ok" and i get this: Image
johnvick
Legend
Post by johnvick »
I haven't been able to get it working but the hardware is capable as the wifi works on Windows on the same device.
John
@kenhas
It looks like Ethernet is listening to DHCP. Could you try to disable Ethernet first and enable WiFi afterwards?
Also you could try the current beta since we worked a bid on WiFi settings and general interface up/down on boot: https://github.com/Fourdee/DietPi/issues/2140
