0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.What happens if you install those packages and try again :?:
CODE: SELECT ALL
apt-get install libssl-dev libcurl4-openssl-dev python-dev python-setuptools
Installing MotionEYE on OrangePi Zero
- fredjedimaster
Re: Installing MotionEYE on OrangePi Zero
- lucasmenno
We're at it again, i refuse to give up, something has to work, right?
When there is an error again, upgrade your pip installer using this
pip install -U setuptools
python -m pip install --upgrade pip
Everything i say can and maybe will be corrected by the DietPi seniors in this forum
BananaPi M1 using image for BananaPi Pro.
-1TB HDD, Network storage,Downloader(JD,Deluge,ripme) testing what looks interesting.
- fredjedimaster
Man....i have no words to thank you. Still not work but your determination moves me.
I'm restarting all the tutorial.
The same erros are found when processing:
pip install motioneye
Failed building wheel for pillow
Running setup.py clean for pillow
Running setup.py bdist_wheel for pycurl ... error
Failed building wheel for pycurl
Running setup.py clean for pycurl
Failed to build pillow pycurl
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-G6EOSi/pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-ddw5lo-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-G6EOSi/pillow/
When i force install
(dietpi-software install 136)
This message are displayed:
DietPi-Software
Mode: Automated install
Please wait...
[Info] 136: MotionEye is already installed
[Ok] No changes applied for: MotionEye
Do you need additional information?
But how to get launch it?
DietPi-Software
Please wait...
- lucasmenno
Motioneye is installed.
Remove first with
Then reboot and try again installing.
Remove first with
dietpi-software uninstall 136
- fredjedimaster
reboot and try automated install?
- lucasmenno
Try with the command
- fredjedimaster
Same errors...
all goes well until the installation of pip motioneye...
- lucasmenno
Feeling out of options here (my dietpi-VM is working, BPI also).
Have you updated the system?
When its updating try again. Uninstall and install.
When it's not, let's try 2 "different" ways.
First
and try again.
I'm trying to get the pycurl package elsewhere, that is failing in the whole installation.
apt-get update && apt-get dist-upgrade
First
When this won't install either tryeasy_install pycurl
apt-get install python-pycurl
- fredjedimaster
error: Setup script exited with error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1Code: Select all
easy_install pycurl
root@DietPi:~# apt-get install python-pycurl
Reading package lists... Done
Building dependency tree
Suggested packages:
libcurl4-gnutls-dev python-pycurl-dbg python-pycurl-doc
python-pycurl
Need to get 48.8 kB of archives.
After this operation, 144 kB of additional disk space will be used.
Get:1 http://ftp.debian.org/debian/ jessie/main python-pycurl armhf 7.19.5-3 [48.8 kB]
Fetched 48.8 kB in 8s (5,873 B/s)
Selecting previously unselected package python-pycurl.
(Reading database ... 35842 files and directories currently installed.)
Preparing to unpack .../python-pycurl_7.19.5-3_armhf.deb ...
Unpacking python-pycurl (7.19.5-3) ...
Setting up python-pycurl (7.19.5-3) ...
- lucasmenno
Please install the suggested packages also
maybe try again, after removing motioneye. I keep my fingers crossed and investigate further
apt-get install libcurl4-gnutls-dev python-pycurl-dbg python-pycurl-doc
