Change DietPi Wi-Fi Settings Editing the SDcard on a PC Topic is solved
k-plan
Re: Change DietPi Wi-Fi Settings Editing the SDcard on a PC
Post by k-plan »
dianakev wrote:
    #/etc/network/interfaces
    #Please use DietPi-Config to modify network settings.
    # Local
    auto lo
    iface lo inet loopback
    # Ethernet
    #allow-hotplug eth0
    iface eth0 inet dhcp
    address 192.168.0.100
    netmask 255.255.255.0
    gateway 192.168.0.1
    #dns-nameservers 8.8.8.8 8.8.4.4
    # Wifi
    #allow-hotplug wlan0
    iface wlan0 inet dhcp
    gateway 192.168.0.1
    wireless-essid FuzonWifi
    wireless-key abcde12345
    wireless-mode Managed
    wireless-power off
    wpa-ssid FuzonWifi
    wpa-psk abcde12345
btw why it stated dhcp while we want to set it as static?
Answer:
- duplicate ip addresses
and
