Thanks, but I don't deserve any credit.
I have just used a ready-made tutorial for the Raspberry Pi and applied it with DietPi as a "base" instead of Raspbian.
Superjamie deserves to get the full credit for this.
[SOLVED] DietPi as VPN Gateway
Re: [SOLVED] DietPi as VPN Gateway
I hope this inst' a dead post yet... my question concerning the killswitch mentioned, how do you use this when trying to install software on dietpi? Part of their update process is to kill running service to include OpenVPN which in turn activates the kill switch and thus I can't download updates.
I'm using PIA too.
Thoughts?
I'm using PIA too.
Thoughts?
Unfortunately you'll have to delete the iptables rules included in the killswitch part of the tutorial, update DietPi and then follow the killswitch tutorial again.
Or, you use a dedicated machine and never update it
