DietPiCam Jessie : Motion.php broken.
Zombievirus
Re: DietPiCam Jessie : Motion.php broken.
Post by Zombievirus »
Hi FourDee,
The v103 Changelog doesn't mention that DietPiCam has been updated to v6.0.19
I just installed it via dietpi-software to check.
You might want to update the changelog ;)
Fourdee
Post by Fourdee »
Zombievirus wrote:Hi FourDee,
+1 Great spot. Yes its been updated to v6.0.19.
Been a long day :o
