DietPi Does Not Boot to Desktop
The_Raven
Re: DietPi Does Not Boot to Desktop
Post by The_Raven »
This issue exist now for a long time. The problem and the fix is simple:
User "dietpi" must be in the group "video".
usermod -a -G video dietpi
I have to do this every time when setting up a new Pi, so please fix it ;)
Hazcrew
Post by Hazcrew »
Thank you @TamaTamaGoGo :D
Not being able to run the desktop is a user is major issue and such a minor/easy fix.
I was going to give up on DietPi and go back to Rasbian until I found this post.
I would have thought it could be easily addressed.
@Hazcrew
before giving up, you always welcome to raise your question on GitHub or this board.
Regarding the challenge to start a desktop as non-Root user. This is known and might change on a future version viewtopic.php?p=28867#p28867
