IPsec VPN Server
cdlenfert
Re: IPsec VPN Server
Post by cdlenfert »
Sorry for the super slow response. I was enjoying the ipsec VPN for a while, but I resorted to using a different device. I also run a music server called forked-daapd on the aforementioned device and it doesn't play nice with the VPN, they basically require different build libraries (if that's the right word :? ). Because of this I want to get the ipsec VPN running on diet-pi. I do the trick above creating an empty auth.log file and the script seems to run perfectly. However there's nothing I can do to connect to my VPN as I was able to before on the other device. I'm not sure what the fail point could be but https://github.com/hwdsl2/setup-ipsec-v ... -519954852.
