Sparky Update Stalls
Fourdee
Re: Sparky Update Stalls
Post by Fourdee »
Yatsushiro wrote:As requested:
root@Sparky:~# cat /DietPi/dietpi/.hw_model
70
Sparky SBC (armv7l)
3
/dev/mmcblk0p2
2936888e-d7c8-43fe-be10-f09c6ab5c2b1
2
armv7l
0
0
0
Unknown
Unknown
0
Unknown
root@Sparky:~#
root@Sparky:~# /DietPi/dietpi/dietpi-obtain_hw_model
root@Sparky:~#
Thanks. Appears fine.
Ok lets get a bug report for this, it will contain system information we can use to debug:
http://dietpi.com/phpbb/viewtopic.php?f=8&t=499#p2184
Yatsushiro
Post by Yatsushiro »
HI Dan
Bug report completed, Reference Code is 2936888e-d7c8-43fe-be10-f09c6ab5c2b1-0
Thanks for your help.
Fourdee
Post by Fourdee »
Yatsushiro wrote:HI Dan
Sincere apologies for the delay, this one slipped the net :(
Are you still experiencing this issue with failed updates?
Yatsushiro
Yep, keep trying every couple of days, but stalls at the same point each time.
Yatsushiro
A gentle bump...
With an update to v155 now available, I still can't upgrade from 153 to 154. I'm happy to sport flares and a permed mullet, but I like my software to be up to date :shock:
Yatsushiro
Sorry to be an irritant, but have you had a chance to have a look at this?
Fourdee
Post by Fourdee »
Yatsushiro wrote:Sorry to be an irritant, but have you had a chance to have a look at this?
Apologies again, I have not had a chance to look into this further yet.
Due to a mishap with the micro-usb power port, the Sparky itself is powered through the GPIO pins
I believe this is the culprit, unstable power causing filesystem and stability issues. Although, we cant verify this yet.
To prevent wasting your time, and to provide a solution now:
- Everything our end appears to be in order. We cant see any issues in your system setup/configuration that would cause this issue at the moment.
- As we believe the issue is related to your current hardware and installation only (we cant replicate the issue, and, this is the sole case), we recommend writing a fresh DietPi image and reinstalling the software you require.
If problems persist after the fresh image write, we may need to look at:
- replacing the SD card
- verify the GPIO wires are 2A+ capable
- verify the GPIO connections are stable
- try the Micro USB power. Curious, what actually happened with the USB power port?
With SBC's, any slight interruption in power stability can cause havoc on the filesystem. Opening a can of endless worms.
