Other than this im nearly out of my knowledge and a fresh start of compiling and installing dietpi would make a success
_____
Some info in other forums where saying that you would need a minimum of 2A power for the OrangePi and some/this stick to work (explained by the fact, that the kernel would only give out kernel panic. The system crashing meaning a 'unstable' / not enough power :|
Everything i say can and maybe will be corrected by the DietPi seniors in this forum BananaPi M1 using image for BananaPi Pro.
-1TB HDD, Network storage,Downloader(JD,Deluge,ripme) testing what looks interesting.
_____
Hmm... The results are disappoiting.
Here's the output of first command:
-rw-r--r-- 1 root root 843516 Jun 14 03:29 /lib/modules/3.4.113-sun8i/kernel/net/wireless/8192cu.ko
All other commands have been failed with message: No such file or directory (except nano, it said that file didn't exist and sayed that it will create a new file).
those files, if they are not there, then create them pls
You did reboot your device yourself here or there, when crashed by editing files, check the saved things, could always be gone :!:
lucasmenno wrote:those files, if they are not there, then create them pls
Okay, i created /etc/modprobe.d/8192cu.conf. All is the same. It crashes after some time (usually 10-30 seconds). I think it's a memory bug. Or, as you said, it can be power bug.
