[Completed] Logitech Media Server 7.9.1
kaosnews
Re: Logitech Media Server 7.9.1
Post by kaosnews »
-ol- wrote:Please don´t worry I got the old version up and running again quite easily. But what happened basically justifies the existence of this thread, don´t you think? Right now it´s just not that easy to update LMS - at least not on the Odroid C2. Not sure if the same goes for other SBCs, too?
If you follow the instructions here (installing 7.9.1): http://wiki.slimdevices.com/index.php/Debian_Package you receive the latest version and also new updates. You should first remove the old version (I think)
-ol-
Post by -ol- »
Hi Kaosnews,
sorry, the officialy given commands do not work out for me. I first uninstalled the LMS provided by DietPi and then just copied the commands from slimdevices.com - LMS doesn´t even install. Maybe I should head over to the slimdevices forums... perhaps they can help. Thanks for your efforts anyways!
Regards,
Oliver
kaosnews
Post by kaosnews »
-ol- wrote:Hi Kaosnews,
Regards,
Oliver
Try this (I see that the instructions are indeed not working):
mkdir -p /sources
cd /sources
wget http://downloads.slimdevices.com/nightly/7.9/sc/ffc273f/logitechmediaserver_7.9.1~1508904967_arm.deb
dpkg -i logitechmediaserver_7.9.1~1508904967_arm.deb
-ol-
Post by -ol- »
Hi, your new instruction set is basically working now but LMS won´t start (restarts every 5 sec) correctly after installation. I think I will continue over here -> http://forums.slimdevices.com/showthrea ... roid+%2Bc2 ! Cheers, Ol
asplundj
Post by asplundj »
I also want LMS 7.9.1 to work on Rock64
-ol-
Post by -ol- »
Aarch64 now appears to be supported in the latest nightly built of LMS, plz follow this link: http://forums.slimdevices.com/showthrea ... post900189 - I wonder if now the necessary adjustments to DietPi could be done in order to simply update LMS in the future whenever you want? Also at the moment Odroid C2 doesn´t meet the requierements since it´s using a different perl version?
Any short feedback whether a renewal of LMS implementation in Dietpi is at least somehwere on the agenda would be great and very much appreciated!
k-plan
Post by k-plan »
-ol- wrote:Any short feedback whether a renewal of LMS implementation in Dietpi is at least somehwere on the agenda would be great
Agenda with only 226 open Points are here: https://github.com/Fourdee/DietPi/issues
-ol-
Post by -ol- »
Do I sense a hint of sarcasm in your answer?! ;-) Seriously, searching the given list of issues - thanks for the link! -I didn´t find anything concerning the outdated implementation of LMS for the Odroid C2... so I assume it´s not "on the agenda".
-ol-
Post by -ol- »
Since dietpi just experienced a major overhaul (thanks a lot for that!) I am wondering if the implementation of LMS will be updated soon, too? It´s still the old version (01/2016) without working transcoding...
k-plan
Post by k-plan »
Hi -ol- ,
-ol- wrote:Do I sense a hint of sarcasm in your answer?! ;)
Yes. ;)
-ol- wrote:Since dietpi just experienced a major overhaul (thanks a lot for that!)
Nice you have noticed this and good to hear you like it.
-ol- wrote:I am wondering if the implementation of LMS will be updated soon, too?
Sorry, no english, is to time-consuming, to complicated for me.
Bevor die heiße Phase von v6.x startete, mussten leider alle Software Requests geschlossen werden.
Sorry, ging nicht anders. Man kann nicht an 50 Baustellen auf einmal arbeiten. Da kommt nur Mist bei raus.
DietPi v6 war ein tiefgreifender Eingriff unter der Haube. Viele Dinge laufen jetzt völlig anders und gleichzeitig wurde auf Debian Stretch geschwenkt. Deshalb ist auch keine "rolling update" möglich. Ja, ich weiß, nicht für uns Odroid Nutzer, aber dazu später mehr.
Wir sind momentan in der Startphase, da werden hin und wieder neue Probleme zu Tage treten.
Außerdem sind genau in dieser Phase andere Tiefschläge hinzugekommen, die viel Zeit, Kräfte und Aufmerksamkeit kosten.
Daher glaube ich nicht, dass es im Moment Sinn macht oder Zeit vorhanden ist, die LMS Sache anzugehen.
Die Änderungen dafür sind wohl tiefgreifender. Wenn es so einfach wäre, hättest du es mit Hilfe der Beschreibungen, sicher selbst hinbekommen.
Außerdem wird es extrem aufwendig, extra für Odroids mit Jessie und Kernel 3.x eine Sonderlösung einzubauen.
Leider muss man bei so einer Breite an unterschiedlichen Hard- u. Softwareunterstützung immer Wechsel- u. Nebenwirkungen im Auge behalten. Da gibt es immer Leute, die machen mit Ihrer Hardware, noch völlig andere Dinge.
-ol- wrote: I didn´t find anything concerning the outdated implementation of LMS for the Odroid C2.
Bei Dingen, die so stark verknüpft sind mit Kernel, Modulen oder binären Blobs (closed Source by Harware Manufactor),
sind wir eindeutig auf Dritte angewiesen. Das ist und war auch nie die Kernkompetenz von DietPi.
Für die Odroids kommt die Basis, Distribution, Kern und Module von meverick der sie auch pflegt (im Rahmen seiner Möglichkeiten).
Die Sourcen dafür stammen von Hardkernel, die auch die Blobs von den Hersteller wie Amlogic oder Mali bereitstellen.
Da geht es aber im Moment nicht so recht voran. Da keine neuen Quellen oder Blobs bereitgestellt werden (Hersteller),
läuft der C2 auch immer noch auf Kernel 3.x.
Die Stretch Fortentwicklung schreitet auch nicht so recht voran, daher auch noch Debian Jessie im Moment.
Würde man jetzt auf Stretch schwenken, was man machen kann, verliert man z.B. Kodi Unterstützung und große Teile des GPU / VPU Supports.
Hardkernel fokussiert sich zur Zeit auch auf andere Dinge, wie XU4-HC1 Fortentwicklung und den neuen Odroid N1.
Also unser C2 sehe ich eher in der Sackgasse im Moment.
Bitte nicht falsch verstehen, die Hardware ist prima und leistungsfähig, eines der besten, schnellsten Boards, die ich besitze.
Zur Zeit mangelt es halt nur an der Fortentwicklung des vorhandenen.
Dürfte das gleiche Problem sein, wie bei DietPi.
Zu viele offene Baustellen, Wünsche und Ziele, zu wenig Unterstützung, zu wenig helfende Hände.
Hilft dir zwar alles nichts bei deinem Wunsch oder Problem weiter, aber vielleicht erleichtert es das Erfassen der Zusammenhänge etwas.
Viele Dinge hätte ich auch gerne anders, manches können wir gemeinsam ändern, anderes müssen wir auch einfach akzeptieren.
cu
k-plan
