Odroid XU4 test new 4.9 kernel without new image?
bgx
Post by bgx »
I'm new in the business. I've had dietpi running nice on my Odroid XU4. I want to try little bit with hardware transcoding and for that I must update to kernel ver 4.9
Is there a way to update to kernel ver 4.9 without start complete new image? And when, how do I archive that?
Thx and great piece of software...
Fourdee
Re: Odroid XU4 test new 4.9 kernel without new image?
Post by Fourdee »
Yep, you can update 3.x image with:
https://github.com/Fourdee/DietPi/issue ... -298170796
bgx
Post by bgx »
Thx, that worked. I tried to compile my own ffmpeg with the howto from here but I failed at the line: sudo apt-get build-dep ffmpeg
root@DietPi:~/ffmpeg_sources/FFmpeg# sudo apt-get build-dep ffmpeg
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
E: »Build-Depends«-Abhängigkeit für ffmpeg kann nicht erfüllt werden, da die Version des Installationskandidaten für das Paket debhelper die Versionsanforderungen nicht erfüllen kann.
johnvick
Legend
Post by johnvick »
There is a link on that page to download compiled versions of ffmpeg:
http://www.mediafire.com/?l39zeyy4r172m
bgx
Post by bgx »
Ok, now is the time to try once again.
Kernel has patched and emby server in the last beta has also patched for odroid xu4 hw encoding. The only thing I need is the patched ffmpeg with hw encoder running.
I tried once again to install all the deb files but I failed greatly stuck at a broken apt-get with missed updates. Took me 4 hours to repair.
Somebody has tried to install the hw patched ffmpeg version on an xu4? Or can somebody lead me to a solution?
Heres the thread in odroid forum, somebody else tried it also and failed also on dietpi:
https://forum.odroid.com/viewtopic.php? ... 96#p191996
I don't want to start from scratch without dietpi. I think there must be a chance to install the patched ffmpeg...
