Update from 148 to 149 does not work
dietpiOK
Re: Update from 148 to 149 does not work
Post by dietpiOK »
When run this command after the update to switch off the ramdisk I see the following things:
  • After next reboot the ramdisk is on again
    Without ramdisk I might have lower performance
    AND: Even switching the ramdisk off after the update the /boot/dietpi/.version will still show 148
So this obviously does not work for me :(
SubNoize
Post by SubNoize »
anyone have a fix? stuck on 150, can't go to v151 @Fourdee
Fourdee
Post by Fourdee »
SubNoize wrote:anyone have a fix? stuck on 150, can't go to v151 @Fourdee
Do you have PiHole installed?
dietpiOK
Post by dietpiOK »
No, what is it?
Fourdee
Post by Fourdee »
dietpiOK wrote:No, what is it?
Great :) http://dietpi.com/phpbb/viewtopic.php?f ... rt=20#p174
Our update system appears to be fully functional at the moment. We cant replicate this at our end.
Have you made any changes to the system (eg: installed software/changed a config), outside of the DietPi scripts (eg: manually)?
dietpiOK
Post by dietpiOK »
I am running the LAMP stack and also Python scripts. I installed some additional Python modules.
And additionally I mounted my NAS via /etc/fstab. Furthermore I applied some cron jobs at /etc/crontab.
When I reboot the machine at Login I can see "UPdate available". /boot/dietpi/.version will show me "148".
Can you help me investigate on the root cause? For example:
1) Can I check in any way if I have the latest builds on my raspi (dietpi-update will do something but I cant'f figure out if it all succeeds).
2) When will the new version be written to /boot/dietpi/.version? And what might have happened if writing to this file does not succeed?
Here are some details from my last dietpi-update run:
[Ok] kernel dietpi_rpi | Completed
[Ok] Patch 150 completed
DietPi-Update
Mode: Updating DietPi
Please wait...
[Info] Current Version : 150
[Info] Server Version : 151
[Info] Patching 150 to 151
[Info] Checking RootFS R/W access. Please wait...
[Ok] RootFS R/W access.
[Info] Initializing database, please wait...
[Info] Reading database, please wait...
DietPi-Software
Mode: Automated reinstall
Please wait...
[Info] 37: Shairport Sync is not currently installed
[Info] The program must be installed, before reinstall can be used
[Ok] No changes applied for: Shairport Sync
[Ok] Patch 151 completed
DietPi-Update
Mode: Completed
Please wait...
[Info] Current Version : 151
[Ok] Update completed
After this dietpi-update run the /boot/dietpi/.version still shows 148 :(
Best regardsm
Olaf
dietpiOK
Post by dietpiOK »
Are there any other actions I can take to get the Pi updated properly? Even the latest update to 153 results in the same behaviour.
Is there a chance to check if the dietpi-update command did all updates but only the wrong version will be shown?
Fourdee
Post by Fourdee »
dietpiOK wrote:Are there any other actions I can take to get the Pi updated properly? Even the latest update to 153 results in the same behaviour.
Most likely dietpi-ramdisk is failing to save on shutdown.
After updating DietPi, try forcing a ramdisk save and checking status:
systemctl restart dietpi-ramdisk
systemctl status dietpi-ramdisk -l
If it reports active and success, reboot system and recheck version.
dietpiOK
Post by dietpiOK »
Hmm...
can someone explain this to me?
Loggin in does not seem to ask for an update:
DietPi | 21:50 | Wed 12/07/17
V153 | RPi 3 Model B (armv7l)
IP Address | 192.168.168.212
Created by : Daniel Knight
Web : http://DietPi.com
Twitter : http://twitter.com/dietpi_
Donate : http://goo.gl/pzISt9
DietPi's web hosting is powered by: MyVirtualServer.com
dietpi-launcher = All the DietPi programs in one place.
dietpi-config = Feature rich configuration tool for your device.
dietpi-software = Select optimized software for installation.
htop = Resource monitor.
cpu = Shows CPU information and stats.
In the .version file I can find 148:
root@maschine2:~# cat /boot/dietpi/.version
148
dietpi-update determines version 153:
root@maschine2:~# dietpi-update
DietPi-Update
Mode: Checking for DietPi updates
Please wait...
[Info] Checking Mirror : http://dietpi.com/downloads/dietpi-upda ... er_version
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 6 100 6 0 0 103 0 --:--:-- --:--:-- --:--:-- 115
[Ok] Using update server: http://dietpi.com/downloads/dietpi-upda ... er_version
[Info] Detecting drives, please wait...
[Info] Detected /dev mount: /dev/mmcblk0p1 > /boot
[Info] Detected /dev mount: /dev/mmcblk0p2 > /
[Info] Processing drive information, please wait...
[Info] Checking available free space on RootFS, please wait...
[Ok] 13178 MB available, 500 MB required
[Ok] No updates required, your DietPi installation is up to date.
[Info] Current Version : 153
[Info] Server Version : 153
So the only weird thing is why /boot/dietpi/.version is outdated? How can I fix that?
