wget https://raw.githubusercontent.com/Fourdee/DietPi/testing/dietpi/dietpi-cpuinfo -O /DietPi/dietpi/dietpi-cpuinfo
cpu
Gord_W wrote:Looks good. Temperature drops through 0 deg smoothly now.
Thanks,
Gordon
Excellent, thanks Gordon
Thanks,
Gordon
ahm, i dont know about anyone else, but for me, my Orange Pi, after the 149 update shows me 0 degrees O_O
and i do cat of that temperature variable and it's not 0, (i did it , because i dont have the orange pi anywhere near me to check manually)
Gord_W wrote:
Just tried it again with your revised code and it still works for Nanopi Neo. Linux DietPi 4.10.3-sun8i
Gordon Williams
Thanks Gordon
