Pine A64: - Move the filesystem to a USB Drive
DrewG
Re: Move the filesystem to a USB Drive
Post by DrewG »
k-plan wrote:Hi,
System:
DietPi v148 | Pine A64+ 1GB Board (e.g. in my case a fresh installation)
Micro SD-Card: - SanDisk microSDHC Ultra 4GB
USB Device: - SanDisk Cruzer Fit 8GB USB-Stick 2.0
Hint: - Don't use this crappy SD-Card or USB Flash drive - I do this only for my tests ! !
Thanks for the info guys. I'll give it a try. I've had to step away from this project right now, but I'll be sure to give this a look when I have more free time.
Thanks again
DrewG
Post by DrewG »
k-plan wrote:Hi,
DrewG wrote:I've been able to get it to work on RPis in the past and I'd really like to get this working on my Pine so I can prolong the life on the SD card.
Technically it is the same as my tutorial for Odroid device you can found here.
But, as @maxtox wrote, you have to edit uEnv.txt.
cu
k-plan
Hi k-plan,
I got your tutorial to work thank you so much. I think the problem I had before was I missed setting the USB to MBR!
Thanks again!. It was super easy to follow...as long as you follow ALL of the instructions :roll:
- Drew
