ntpdgaffa wrote:Hi,
I just tried:
ntpq -pn
ntpq: read: Connection refused
Any help?
Garry
Ntpd update running 100% on Pi3
Re: Ntpd update running 100% on Pi3
Daniel,
I rebooted yesterday and it's been running fine since!!!!!
Garry
Spoke too soon, problem has returned!!!!!! After killing grep this is what htop says (See attachment)
Garry
Garry
Garry
any news on this?
Garry
any news on this?
Garry
Hi Garry,gaffa wrote:Hi,
any news on this?
Garry
Not sure yet, I've checked the source code and the only thing that would cause a hang is:
cat /DietPi/dietpi.txt | grep -m1 '^ntpd_update_mode=' | sed 's/.*=//'
df -P | awk '{print $6}' | tail -n +2
grep -ci -m1 'dietpi_check_for_updates=1' /DietPi/dietpi.txt
sed -n 5p /DietPi/dietpi/.dietpi-sync_settings
When the 100% CPU occurs, can you try running those commands locally, see if they also hang?
Also, lets check the contents of /etc/cron.daily/dietpi, just to make sure
cat /etc/cron.daily/dietpi
cat /etc/fstab
Hi Daniel,
This morning, see attachments
I'll try the commands manually later. Fstab is also attached.
Garry
Garry
Thanks Garry,gaffa wrote:Hi Daniel,
Garry
Pretty sure this is the failing command, did running this cause the 100% in the attached image?:
blkid
mount
Daniel,
running the command manually works!!!!
No hang.
root@Pi3:~# blkid
/dev/mmcblk0p1: SEC_TYPE="msdos" LABEL="boot" UUID="1623-A8B8" TYPE="vfat" PARTUUID="ee614650-01"
/dev/mmcblk0p2: UUID="c352383b-22f5-437e-a30a-74198bd98a55" TYPE="ext4" PARTUUID="ee614650-02"
/dev/sda1: UUID="ea8fe470-f3e6-4a1f-a79c-9559f5297169" TYPE="ext4" PARTLABEL="primary" PARTUUID="d71d3a0e-d82e-49e4-8d9f-2e0e8870c0c0"
/dev/mmcblk0: PTUUID="ee614650" PTTYPE="dos"
root@Pi3:~#
oot@Pi3:~# mount
/dev/sda1 on / type ext4 (rw,noatime,discard,data=ordered)
devtmpfs on /dev type devtmpfs (rw,relatime,size=437048k,nr_inodes=109262,mode=755)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=23,pgrp=1,timeout=300,minproto=5,maxproto=5,direct)
systemd-1 on /mnt/usb_1 type autofs (rw,relatime,fd=24,pgrp=1,timeout=300,minproto=5,maxproto=5,direct)
systemd-1 on /mnt/c352383b-22f5-437e-a30a-74198bd98a55 type autofs (rw,relatime,fd=25,pgrp=1,timeout=300,minproto=5,maxproto=5,direct)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
tmpfs on /DietPi type tmpfs (rw,nosuid,nodev,noatime,size=10240k)
tmpfs on /var/log type tmpfs (rw,nosuid,nodev,noatime,size=20480k)
/dev/mmcblk0p2 on /mnt/c352383b-22f5-437e-a30a-74198bd98a55 type ext4 (rw,noatime,data=ordered)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
/dev/mmcblk0p1 on /boot type vfat (rw,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro,discard)
/dev/sda1 on /mnt/usb_1 type ext4 (rw,noatime,discard,data=ordered)
root@Pi3:~#
No hang.
root@Pi3:~# blkid
root@Pi3:~#
oot@Pi3:~# mount
root@Pi3:~#
Fourdee wrote:Thanks Garry,gaffa wrote:Hi Daniel,
Garry
Pretty sure this is the failing command, did running this cause the 100% in the attached image?:Lets clean up your /etc/fstab /mnt/usb_x entries, they wont be helping system. Before we do that, I'll need to see the following:Code: Select all
blkid mount
Hi Daniel,
just now:
CPU is running at 75 degrees!
Garry
just now:
Hi Garry,gaffa wrote:running the command manually works!!!!
No hang.
Could indicate an issue with hardware (PSU/SD), or, other software causing system instability.
Is RootFS transferred to USB disk? Or, running off SD card? Which brand SD card?I have an official Pi3 PSU and am running off a USB stick from Sandisk.
Ok, you can disable all /dev/sdX entries in /etc/fstab with a #, excluding /dev/sda1 (as its currently being used)/dev/sda1: UUID="ea8fe470-f3e6-4a1f-a79c-9559f5297169" TYPE="ext4" PARTLABEL="primary" PARTUUID="d71d3a0e-d82e-49e4-8d9f-2e0e8870c0c0"
