Unable to update or install anything
Chester007
Re: Unable to update or install anything
Post by Chester007 »
Fourdee wrote:
Chester007 wrote:Would it help if I get hold of a working /var/lib/dpkg/diversions and replace mine with it?
It may fix that issue now, but I wouldn't recommend it. Instead, try to resolve the underlying issue (Hardware, PSU, SD and/or RPi itself), or things will get much worse.
Ah I see.. It's just that those things cost money and currently I don't have the luxury to acquire those if I do troubleshoot the hardware
Fourdee
Post by Fourdee »
Chester007 wrote: Ah I see.. It's just that those things cost money and currently I don't have the luxury to acquire those if I do troubleshoot the hardware
No worries, know the feeling :)
Ok, here is the file contents of /var/lib/dpkg/diversions on RPi 3, fresh install :
/lib/udev/rules.d/75-persistent-net-generator.rules
/lib/udev/rules.d/75-persistent-net-generator.rules.distrib
/usr/share/man/man1/sh.1.gz
/usr/share/man/man1/sh.distrib.1.gz
dash
/usr/share/man/man1/config_data.1.gz
/usr/share/man/man1/config_data.diverted.1.gz
libmodule-build-perl
/usr/bin/config_data
/usr/bin/config_data.diverted
/bin/sh
/bin/sh.distrib
dash
Might also be worth clearing apt cache aswell:
apt-get clean
Chester007
Fourdee wrote: No worries, know the feeling :)
dash
/bin/sh
/bin/sh.distrib
dash
apt-get clean
Thank you! I was about to completely give up on DietPi but once I tried this, everything worked fine! You just made my day, thanks :D
I do understand that I should really not set aside my power problem and I'll attend to that as soon as I can. For the mean time, I'll have fun tinkering with DietPi
Fourdee
Post by Fourdee »
No worries, great to hear this is now working for you :)
