red LED blinking twice repeatedly after upgrade Topic is solved
Fourdee
Re: red LED blinking twice repeatedly after upgrade
Post by Fourdee »
Confirmed, looks like a bug in the OPi Kernel.
LED control pulls its current values directly from /sys/class/leds. This is telling us that "none" is active, however, it appears the LED gets stuck on "always on". Changing from "none" to "anything else" then back to "none" seems to resolve it.
Not much we can do about this one as kernel is provided by ARMbian. We'll have to wait for a fix in their kernel updates via apt.
syl3nt
Post by syl3nt »
ok, thanks, i will be waiting patiently for it then :mrgreen:
Sciamano
Post by Sciamano »
My configuration, with green led always on and red led blinking works perfectly on both my OPi PCs, after multiple reboots.
I assume the problem lies in the [none] option only?
