could you please remove the () brackets from the image filenames
had to use DietPi_blahblah-\(Jessie\).7z to use your filename in any command.
DietPi (image) filenames Topic is solved
Re: DietPi (image) filenames
No, we wont be doing thatbigtreeman wrote:Hi,
You can also put the file in quotations, removing the need for escaping backslash, eg:had to use DietPi_blahblah-\(Jessie\).7z to use your filename in any command.
wget 'http://dietpi.com/downloads/images/DietPi_OrangePiPlus-armv7-(Jessie).7z' -O image.7z
