well you could have used dietpi-services to manage/change Squeezelite service configuration as described on our user documents viewtopic.php?p=1009#p1009
As far as I can see on your screen print, you already use a dietpi-service drop-in configuration file for Squeezelite. So quite easy to manage
I know what you mean, and thanks for you kindness.
I have used dietpi-services modify squeezelite, but failed, because when I entry dietpi-sevices to edit name, windows drag me into a uncorrespond path, see my attached. So i has been unsuccessful .
I am not sure if its a bug, because I used other Linux image update to dietpi, rather than download dietpi provide official image for odroid.
Thanks for you great job, dietpi help me a lot.
Gain knowledge, I reinstalled squeezelite, edited dietpi-services follow you instructions, add new
Execstart=, delete # , successes! Forgive me, I'm a novice
