ODROID C2 update 142 won't load kernel Topic is solved
Fourdee
Re: ODROID C2 update 142 won't load kernel
Post by Fourdee »
USB drive = 500mA
Modem = 100mA
USB DAC = 100mA
A stable 5v/2A should be more than adequate.
