syl3nt wrote:Sciamano wrote:Those are the settings for the share called "dietpi".
In the configuration file you posted that share is not present, so I guess you posted the wrong file
Maybe webmin uses a separate file?
i don't really know, maybe yes, but i don't know why, right now, i entered on vlc the share, and it didn't workd with "nobody", "anonymous", or "guest" users, so i am clueless :-/
and i had to use the user root with the corresponding password, of course, and it did work everything normal
but you say it maybe uses different conf files, that maybe a hit , let me search , so i can compare and if i find something , i'll let you know
