You were correct, I took my old Sandisk UHS 16GB and ... The result was the same...
But luckily I found and old image of v145 and writen it to both.
GoodRAM - no luck (No Ethernet controller found error)
Sandisk - It works!!!
In the mean time, set NTP back to "Boot + daily" and try changing the NTPD mirror in:
dietpi-config > Networking Options: NAS/MISC > NTPD mirror
Hi, I'm having the same problem after a reboot: The DietPi folder is empty
Running on C2 with latest Dietpi package (installed it yesterday).
For a quick solution: is there any way to replace the Dietpi system files or should I just re install Dietpi on the SD?
pilobasualdo wrote:Hi, I'm having the same problem after a reboot: The DietPi folder is empty
I'm having the same problem. I tried to use dietpi-software to install the Plex server. The SD card may have filled up, lots of error messages about not having space. So the install failed and then when I rebooted I got the same empty dietpi folder error. After making some space the error persists.
Raspberry pi 3, 32GB SD card, DietPi v6.3
root@DietPi:~# ls -lha /var/tmp/dietpi/logs
total 296K
drwxr-xr-x 2 root root 4.0K Mar 7 11:52 .
drw-rw---- 3 dietpi dietpi 4.0K Feb 18 13:59 ..
-rw-r--r-- 1 root root 217K Mar 7 07:58 dietpi-firstrun-setup.log
-rw-r--r-- 1 root root 1.9K Mar 8 18:32 dietpi-ramdisk.log
-rw-r--r-- 1 root root 1.1K Mar 8 18:32 dietpi-ramlog.log
-rw-r--r-- 1 root root 173 Mar 8 18:29 dietpi-software_apt.log
-rw-r--r-- 1 root root 44K Mar 7 11:54 dietpi-update.log
-rw-r--r-- 1 root root 211 Feb 18 13:39 fs_expand.log
-rw-r--r-- 1 root root 1.8K Feb 18 13:39 fs_partition_resize.log
/etc/fstab was BLANK and the filesystem was read only. I copied the fstab file from the image and everything seems fine.
Then I installed plexserver without issue. The only thing I can think of is that I had a manual entry on fstab to load a samba share. Now I'm mounting it through diepi-config and I left fstab as it was.
I'm a new user but unfortunately I believe I just joined this club. Installed DietPi on a fresh Odroid C2 w/ a Sandisk 128gb card. Had things up and running and was tinkering with it. Connected an external USB drive and rebooted -- and directory is now empty. Boots and I can login but can't run any dietpi commands.
