Hey there,
I run into a similar issue - only that I use an Odroid XU4.
After I did the upgrade to v145 and rebooted the device, the DietPi-folder is empty. Before that everything was fine and working for a few weeks now (v144).
I have to say that I switched (from point of installation DietPi) the system to an external usb-drive using the drive-manager.
So I unplugged my sdcard and changed the root partition back from the usb-drive to the sdcard in the boot.ini. After that I was able to access the device and the DietpI-folder (now on the sdcard) wasn't empty (as it should be and logically couldn't be).
Here are a few more infos:
Device I'm using Odroid Xu4
SdCard: Kingston 8GB
USB-Drive Transcend SDD 32gb TS32GSSD 370 connected via cloudshell
Software installed: webmin, samba, pihole
last command: dietpu-upgrade && reboot
PSU: official one of Odroid for the XU4
The not so useful ramlog cause it is the one generated using the sdcard as root-device ( the generated on on the usb-card isn't accessible):
systemctl status dietpi-ramlog -l
● dietpi-ramlog.service - DietPi-RAMlog
Loaded: loaded (/etc/systemd/system/dietpi-ramlog.service; enabled)
Active: active (exited) since Fr 2017-03-03 21:00:39 CET; 2 days ago
Process: 631 ExecStart=/bin/bash -c /boot/dietpi/dietpi-ramlog 0 (code=exited, status=0/SUCCESS)
Mär 03 21:00:38 dietpiserver systemd[1]: Starting DietPi-RAMlog...
Mär 03 21:00:38 dietpiserver bash[631]: DietPi-Ramlog: Starting
Mär 03 21:00:39 dietpiserver bash[631]: chown: invalid user: ‘debian-tor:nogroup’
Mär 03 21:00:39 dietpiserver bash[631]: DietPi-Ramlog: Completed
Mär 03 21:00:39 dietpiserver systemd[1]: Started DietPi-RAMlog.
When more infos are needed plz let me know.
Thx for your support!!
Michael
