DietPi folder empty
johnvick
Legend
Re: DietPi folder empty
Post by johnvick »
Just to add to this I have had the empty DietPi folder a few times recently on two Orange Pi Zeros. I wasn't far into setting them so I just started again. The most recent happened with a new Stonetronics PSU and new Kingston 8 GB SD card.
Should this recur Fourdee and way to troubleshoot this or any log entries that may help??
John
Fourdee
Post by Fourdee »
johnvick wrote:Just to add to this I have had the empty DietPi folder a few times recently on two Orange Pi Zeros. I wasn't far into setting them so I just started again. The most recent happened with a new Stonetronics PSU and new Kingston 8 GB SD card.
John
Thanks John,
Ok, lets try and find the cause for this. Seems we have a reoccurring issue.
If anyone has experienced an issue of /DietPi being empty, please post the following answers and we can investigate:
  • Device used (eg: RPi)
  • Software installed (both through dietpi-software and manually)
  • What was the last command run, before this occurred (eg: dietpi-update)
  • PSU used (eg: Official RPi 5v/2A)
  • SD card used
  • fstab entries (hide any pass worded network drives)
    cat /etc/fstab
  • DietPi-RAMlog status
    systemctl status dietpi-ramlog -l
Thanks guys and apologies for the inconvenience.
johnvick
Legend
Post by johnvick »
Hi Fourdee,
Just happened again after shutdown now and move to different power socket in another room.
Orange Pi Zero, Rpi3 Stonetronics 2.5 A PSU, Kinsgton 8 GD SD card.
Installed, all through dietpi-software - nextcloud, Lighthttpd, MySQL, PhPMyAdmin, Syncthing, XRDP.
fstab
#Internal Drives---------------------------------------------------
proc            /proc           proc    defaults											0 0
/dev/mmcblk0p1  /boot           auto    defaults,noatime,discard							0 2
/dev/mmcblk0p2  /               auto    defaults,noatime,discard							0 1
tmpfs 			/tmp  			tmpfs 	defaults,noatime,nodev,nosuid,mode=1777				0 0
tmpfs 			/var/log 		tmpfs 	defaults,size=20m,noatime,nodev,nosuid,mode=1777	0 0
tmpfs 			/DietPi 		tmpfs 	defaults,size=10m,noatime,nodev,nosuid,mode=1777	0 0
#External Drives---------------------------------------------------
#NB: Please use dietpi-drive_manager to setup and control your external drives.
UUID=a2bb0b5c-bb0f-4ab5-95dc-2987f476d83d       /mnt/usb_1      auto     defaults,noatime,nofail,x-systemd.automount  0 0
#/dev/sdb1       /mnt/usb_2      auto     defaults,noatime,nofail,x-systemd.automount  0 0
#/dev/sdc1       /mnt/usb_3      auto     defaults,noatime,nofail,x-systemd.automount  0 0
#/dev/sdd1       /mnt/usb_4      auto     defaults,noatime,nofail,x-systemd.automount  0 0
#/dev/sde1       /mnt/usb_5      auto     defaults,noatime,nofail,x-systemd.automount  0 0
#Samba Client------------------------------------------------------
#/mnt/samba . Please use dietpi-config and the Networking Options: NAS menu to setup this mount
#FTP Client Mount--------------------------------------------------
#/mnt/ftp_client . Please use dietpi-config and the Networking Options: NAS menu to setup this mount
#NFS Client Mount--------------------------------------------------
#/mnt/nfs_client . Please use dietpi-config and the Networking Options: NAS menu to setup this mount
# a swapfile is not a swap partition, no line here
#   use  dphys-swapfile swap[on|off]  for that
root@Orange2:~# systemctl status dietpi-ramlog -l
● dietpi-ramlog.service - DietPi-RAMlog
   Loaded: loaded (/etc/systemd/system/dietpi-ramlog.service; enabled)
   Active: failed (Result: exit-code) since Thu 2017-01-19 14:40:35 NZDT; 5min ago
  Process: 472 ExecStart=/bin/bash -c /boot/dietpi/dietpi-ramlog 0 (code=exited, status=2)
Jan 19 14:40:34 Orange2 bash[472]: /boot/dietpi/dietpi-ramlog: line 1: ------------------------: command not found
Jan 19 14:40:34 Orange2 bash[472]: /boot/dietpi/dietpi-ramlog: line 2: syntax error near unexpected token `}'
Jan 19 14:40:34 Orange2 bash[472]: /boot/dietpi/dietpi-ramlog: line 2: `}'
Jan 19 14:40:35 Orange2 systemd[1]: dietpi-ramlog.service: control process exited, code=exited status=2
Jan 19 14:40:35 Orange2 systemd[1]: Failed to start DietPi-RAMlog.
Jan 19 14:40:35 Orange2 systemd[1]: Unit dietpi-ramlog.service entered failed state.
John
qnx
Post by qnx »
Hi Fourdee,
I'm on a Rpi 2 Model B. I use Samsung's SD, 64 Gb. My setup is headless, no X nor VNC. Dropbear, Subsonic plus a webserver stack with Lighttpd/MariaDB/Php. I also used to have smbd and nmbd running, but it seems no daemons are running anymore as they couldn't be launched. I'm lucky that Dropbear is on at least!
root@jpi:~# dietpi-services
-bash: /DietPi/dietpi/dietpi-services: No such file or directory
root@jpi:~# /boot/dietpi/dietpi-services
sed: can't read /DietPi/dietpi/.hw_model: No such file or directory
/boot/dietpi/dietpi-services: line 144: /DietPi/dietpi/func/dietpi-notify: No such file or directory
DietPi-Services
Available commands: start / stop / restart / enable / disable
I'm not sure about the last command run before /DietPi disappeared, but it could have been after a restart upon update to the latest release. Now I can't even run dietpi-update as the script seems to have been located in the missing folder. Here are my answers.
root@jpi:/boot# systemctl status dietpi-ramdisk -l
● dietpi-ramdisk.service - DietPi-RAMdisk
   Loaded: loaded (/etc/systemd/system/dietpi-ramdisk.service; enabled)
   Active: active (exited) since Tue 2017-01-17 11:03:02 CET; 1 day 21h ago
Jan 17 11:03:01 jpi systemd[1]: Starting DietPi-RAMdisk...
Jan 17 11:03:01 jpi bash[410]: DietPi-Ramdisk: Starting
Jan 17 11:03:01 jpi bash[410]: cp: cannot stat ‘/boot/boot.ini’: No such file or directory
Jan 17 11:03:01 jpi bash[410]: sed: can't read /DietPi/boot.ini: No such file or directory
Jan 17 11:03:01 jpi bash[410]: cp: cannot stat ‘/boot/uEnv.txt’: No such file or directory
Jan 17 11:03:01 jpi bash[410]: sed: can't read /DietPi/uEnv.txt: No such file or directory
Jan 17 11:03:02 jpi bash[410]: DietPi-Ramdisk: Completed
Jan 17 11:03:02 jpi systemd[1]: Started DietPi-RAMdisk.
I've removed commented lines from fstab:
root@jpi:/boot# cat /etc/fstab
/dev/sda1       /mnt/usb_1      auto     defaults,noatime,nofail,x-systemd.automount  0 0
/dev/sda2       /mnt/NAS        auto     defaults,noatime,nofail,x-systemd.automount  0 0
Permissions:
root@jpi:~# ls -lha /DietPi
total 4.0K
drwxrwxrwt  2 root root   40 Jan 17 13:01 .
drwxr-xr-x 20 root root 4.0K Nov  1 17:50 ..
Any ideas how to reach dietpi-software, dietpi-services (and others)? I'd like to get daemons up again, and I have another issue with MariaDB and would like to reinstall it.
Should I symlink /DietPi to /boot/dietpi? Or should I just use apt-get? (A bit worried this will break "integration" with DietPi packages I have installed such as PhpMyAdmin and Wordpress.)
Fourdee
Post by Fourdee »
Hi guys,
Thanks for the info and apologies for the issues. I've created a ticket for this and will start investigations:
https://github.com/Fourdee/DietPi/issues/719
johnvick wrote:Just happened again after shutdown now and move to different power socket in another room.
Thanks John, this will give us something to debug for :)
We may need to run some further tests on your systems (if permitting), but i'll let you guys know once ready.
johnvick
Legend
Post by johnvick »
I've tested this a lot over the weekend and suspect that my problem was a flaky SD card. So far so good with a different one.
Is there a way to test SD cards that you suspect are faulty?
John
Fourdee
Post by Fourdee »
johnvick wrote:I've tested this a lot over the weekend and suspect that my problem was a flaky SD card. So far so good with a different one.
John
Hi John,
Does sound like a SD issue, i've still been unable to replicate this issue on various devices and SD cards.
As for finding out if SD is stable in a SBC environment, you'll only know once filesystem based issues occur (eg: fsck recovery, I/O errors listed in dmesg etc).
From my experience, the following SD card has issues:
- Transcend = IO errors on NanoPi Neo/AIR, intermittent on other devices
The following cards are highly recommended, never had an issue with any of them:
- SanDisk
- Verbatim
Fourdee
Post by Fourdee »
Hi all,
We've enabled debugging for v143, if you experience the issue of missing DietPi folder, please see here:
https://github.com/Fourdee/DietPi/issue ... -275921944
chunder
Post by chunder »
I had this problem today after running dietpi-update. Quite annoying, is there any way to recover the system or do I have to start again?
Symptoms:
[*] This message displayed at login prompt: -bash: /DietPi/dietpi/login: No such file or directory
[*] /DietPi is empty
[*] None of the dietpi- commands are available
Device: RPi 3
Installed: kodi, mopidy, pihole, samba
Last command: dietpi-update, followed by reboot when prompted
PSU: A 2.4 A USB port on a power board (new)
SD card: Sandisk
fstab:
//192.168.1.104/media /mnt/samba cifs username=XXXXX,password=XXXXX,_netdev,iocharset=utf8,sec=ntlm,nofail  0  0
root@DietPi:/DietPi# systemctl status dietpi-ramlog -l
   Active: failed (Result: exit-code) since Mon 2017-01-30 17:00:33 AEDT; 21min ago
  Process: 452 ExecStart=/bin/bash -c /boot/dietpi/dietpi-ramlog 0 (code=exited, status=127)
Jan 30 17:00:33 DietPi bash[452]: /bin/bash: /boot/dietpi/dietpi-ramlog: No such file or directory
Jan 30 17:00:33 DietPi systemd[1]: dietpi-ramlog.service: control process exited, code=exited status=127
Jan 30 17:00:33 DietPi systemd[1]: Failed to start DietPi-RAMlog.
Jan 30 17:00:33 DietPi systemd[1]: Unit dietpi-ramlog.service entered failed state.
root@DietPi:/DietPi# cat /etc/dietpi/logs/dietpi-ramdisk.log
DietPi-Ramdisk: Already running
/bin/bash: /boot/dietpi/dietpi-ramdisk: No such file or directory
Fourdee
Post by Fourdee »
chunder wrote:I had this problem today after running dietpi-update. Quite annoying, is there any way to recover the system or do I have to start again?
Many thanks for the report and I apologise for the inconvenience.
We are still unsure as to the cause of this issue, however, with thanks to your report, we are working on a solution/prevention.
If you made a backup (dietpi-backup) of your system, prior to dietpi-update, you can restore back to the previous state before the issue occurred:
Grab the dietpi-backup script:
wget https://raw.githubusercontent.com/Fourdee/DietPi/master/dietpi/dietpi-backup -O /root/dietpi-backup
chmod +x /root/dietpi-backup
Run the script, find your previous backup, restore and reboot:
/root/dietpi-backup
