DietPi folder empty
Bernie V
Re: DietPi folder empty
Post by Bernie V »
This is my type of sdcard: Transcend 64GB microSD Premium 400x Class 10 UHS-I
Yes!!! DietPi is repaired. Thx a lot. After reboot It needed to be updated to the latest version.
I only have still these warnings at startup:
-bash: warning: setlocale: LC_ALL: cannot change locale (0.UTF-8)
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (0.UTF-8)
Is there something to do on it?
Bernie V
Post by Bernie V »
@Fourdee: Thx for the great assistance! Please send me the PayPal adres to support your project, with the link in the sig I can't use PayPal for some reason.
Fourdee
Post by Fourdee »
Bernie V wrote:Transcend
Hi Bernie,
I've experienced consistent IO failures with Transcend's cards, on various devices during DietPi testing over the years, i personally wouldn't recommend them for stability.
With the FSCK recovery and official PSU, i believe unstable SD card is to blame.
I'd highly recommend Sandisk, any model, they have proven to me over the years (they take a hammering) that they are fully stable and reliable.
I've seen this before, think we may have a solution on forums, let me find and link it.
Bernie V
Post by Bernie V »
PayPal link worked now. Check your PayPal ;)
Fourdee
Post by Fourdee »
Bernie,
Found it: http://dietpi.com/phpbb/viewtopic.php?f ... nge+locale
Try:
rm /etc/environment
Then run:
dpkg-reconfigure locales
Make sure [*] en_GB.UTF-8 UTF-8[/color] is ticked (space bar).
Enter
Select en_GB.UTF-8 as default
Enter
Reboot system and check if issue is resolved
Fourdee
Post by Fourdee »
Bernie V wrote:PayPal link worked now. Check your PayPal ;)
Thanks Bernie, really appreciate it.
I actually need to order some more Sandisk SD cards (6 isnt enough for 20+ devices and testing lol) , so will be put to good use :D
Thank you.
Bernie V
Post by Bernie V »
Fourdee wrote: Thanks Bernie, really appreciate it.
Thank you.
:D
Bernie V
Post by Bernie V »
Fourdee wrote:Make sure [*] en_GB.UTF-8 UTF-8[/color] is ticked (space bar).
Enter
Enter
I'm from Belgium, so does this matter for the selection? Time zone Belgium = UTC +1
qnx
Post by qnx »
Hi all!
Similar problem to Bernie's (empty /DietPi), except I don't have /boot.bak.
root@jpi:/# ls
bin   dev     etc  lost+found  opt   root  sbin  sys  usr
boot  DietPi  lib  mnt         proc  run   srv   tmp  var
But /boot/dietpi seems to contain something:
root@jpi:/# ls /boot/dietpi
boot               dietpi-config         dietpi-logclear         dietpi-survey
conf               dietpi-cpuinfo        dietpi-morsecode        dietpi-sync
dietpi-autostart   dietpi-cpu_set        dietpi-obtain_hw_model  dietpi-update
dietpi-backup      dietpi-cron           dietpi-process_tool     finalise
dietpi-banner      dietpi-drive_manager  dietpi-ramdisk          func
dietpi-bugreport   dietpi-funtime        dietpi-ramlog           login
dietpi-cleaner     dietpi-launcher       dietpi-services         misc
dietpi-cloudshell  dietpi-letsencrypt    dietpi-software
How should I go on to restore my /DietPi folder?
Fourdee
Post by Fourdee »
qnx wrote:But /boot/dietpi seems to contain something:
We'll need to check the status of the DietPi-RAMdisk service to see why it failed:
systemctl status dietpi-ramdisk -l
Also, can we see your /etc/fstab to check mount entry for /DietPi:
cat /etc/fstab
And, lets check permissions on /DietPi:
ls -lha /DietPi
