Cheapest DietPiHole Solution
Fourdee
Re: Cheapest DietPiHole Solution
Post by Fourdee »
rothchild wrote:The only tweak I did was to fix the ethernet setting in dietpi.txt to 100 as that's the rate of the socket, not sure if it makes any difference but hey
Yep, their cute alright lol :). Just wish it had a 1GBit eth, then it would be more awesome :)
Yep, no need to set that value, its only to force a specific "down speed". Mainly used for some Pine A64 boards that have a hardware failure under 1GBit.
