WiFi Hotspot using another wireless connection?
Is it possible to use the WiFi Hotspot to share the internet connection from another wireless card?
I want to configure my DietPi to make an hotspot from another wifi connection, to proxy all the client traffic to VPN or else!
Thank you!
Theoretically, you can do this. However, our installation tools do not support 2 WiFi adapters at the moment. We expect eth0 and wlan0 adapters in our configuration. Nevertheless, you can install it manually.
Great, do you know the files are used for the configuration of the hotspot?
You can get an impression by looking at our software installation script
Theoretically, you could change the script itself to match your interface names.
