Also, when I disconnect from the VPN (not the OpenVPN but the one I use to anonimyse traffic) the OpenVPN starts to work normally.
When I disconnect from VPN:
sudo ss -tunlp | grep vpn
udp UNCONN 0 0 0.0.0.0:1194 0.0.0.0:* users:(("openvpn",pid=24436,fd=6))
dietpi@DietPi:~$ ip -4 addr; ip -4 ro list table all; ip -4 ru
inet 192.168.31.254/24 brd 192.168.31.255 scope global eth0
7: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 100
inet 10.8.0.1 peer 10.8.0.2/32 scope global tun0
default via 192.168.31.1 dev eth0 table 100
default via 192.168.31.1 dev eth0 onlink
10.8.0.0/24 via 10.8.0.2 dev tun0
10.8.0.2 dev tun0 proto kernel scope link src 10.8.0.1
192.168.31.0/24 dev eth0 proto kernel scope link src 192.168.31.254
local 10.8.0.1 dev tun0 table local proto kernel scope host src 10.8.0.1
broadcast 127.0.0.0 dev lo table local proto kernel scope link src 127.0.0.1
broadcast 192.168.31.0 dev eth0 table local proto kernel scope link src 192.168.31.254
local 192.168.31.254 dev eth0 table local proto kernel scope host src 192.168.31.254
broadcast 192.168.31.255 dev eth0 table local proto kernel scope link src 192.168.31.254
0: from all lookup local
16010: from all sport 1194 lookup 100
32766: from all lookup main
32767: from all lookup default
Only the tun0 interface remains
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.31.254 netmask 255.255.255.0 broadcast 192.168.31.255
inet6 fe80::2247:47ff:feed:9fea prefixlen 64 scopeid 0x20<link>
ether 20:47:47:ed:9f:ea txqueuelen 1000 (Ethernet)
RX packets 9548329 bytes 10711485755 (9.9 GiB)
RX errors 0 dropped 2678 overruns 0 frame 0
TX packets 5275915 bytes 1416320847 (1.3 GiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 20 memory 0xf7200000-f7220000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 71641 bytes 18705391 (17.8 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 71641 bytes 18705391 (17.8 MiB)
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 10.8.0.1 netmask 255.255.255.255 destination 10.8.0.2
inet6 fe80::c85a:4eee:abc5:765 prefixlen 64 scopeid 0x20<link>
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 100 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
TX packets 4 bytes 304 (304.0 B)
