Vaultwarden and HTTPS tutorial
Bonus question:
I can reach vaultwarden via web now. But…the web interface is a little mobile-unfriendly…
What if I wanted to use the bitwarden android app using my selfhosted vaultwarden instance?
I am aware I have to enter the base server url in the app…
But I couldn’t make it connect so far with the credentials I have setup via the webvault.
What would be the base url- https://dietpi.example.com/vault Or https://dietpi.example.com?
Note: https://dietpi.example.com/vault/ doesn’t work as the bitwarden client automatically removes the trailing slash
Any experience in using the bitwarden client with a selfhosted server?
Thanks again!
It should be https://dietpi.example.com/vault using the sub path. The trailing slash challange is somehow known to Vaultwarden guys and documented on thier wiki Using an alternate base dir · dani-garcia/vaultwarden Wiki · GitHub However I’m not 100% sure on a solution for using lighttpd as revers proxy :thinking:
Thanks for confirming.
Just tested the android bitwarden app and I can login to my selfhosted vaultwarden instance.
All good, all working. :grinning:
