USB dries not being recognized
- DietPi version: G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=16
G_DIETPI_VERSION_RC=2
- Distro version: bullseye 0
- Kernel version: Linux DietPi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
- Architecture: arm64
- SBC model: RPi 4 Model B (aarch64)
- Power supply used: 5V 1A RAVpower
- SD card used: SanDisk
After inserting the USB drive, I invoke “Dietpi-software”, “User Data Location”, and “List”, and I only see the boot and main program file location, nothing else. I then launch Drive-Manager and see same.
After exiting, run “mount”, don’t see it, run “cat /etc/fstab” and see only the main two physical drives for Dietpi, no sda1 mounts.
I tried a few USB storage devices, both external and flashdrives, and tried both the USB2 and USB3 ports on my R-PI, all to no avail.
Now, everything I’ve read states they should just automount and with every other distro for the R-Pi I’ve run they just mount.
Is there anything I can try, or am I overlooking something?
Thanks,
Gamma
You need to use dietpi-drive_manager to mount the drive. This script creates an entry in the fstab, after reboot the drive is mounted automatically if anything tries to access it.
We don’t mount drives automatically just while they plug in. You need to use dietpi-drive_manager to configure the mount point. If drives are not visible there, they are not recognized by the system at all. You can verify available drives using following command.
