The ls of global modules lists 16 but only shows 4
total 16
drwxr-xr-x 4 1001 nx 4096 Jun 20 14:13 corepack
drwxr-xr-x 6 root root 4096 Dec 25 2022 node-red-contrib-blynk-iot
drwxr-xr-x 7 1001 nx 4096 Jun 20 14:13 npm
drwxr-xr-x 5 root root 4096 Dec 23 2022 onoff
gave me
npm WARN deprecated loadash@1.0.0: Package is unsupport. Please use the lodash package instead.
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
npm WARN deprecated formidable@1.2.6: Please upgrade to latest, formidable@v2 or formidable@v3! Check these notes: https://bit.ly/2ZEqIau
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated superagent@3.7.0: Please upgrade to v7.0.2+ of superagent. We have fixed numerous issues with streams, form-data, attach(), filesystem errors not bubbling up (ENOENT on attach()), and all tests are now passing. See the releases tab for more information at <https://github.com/visionmedia/superagent/releases>.
npm WARN deprecated superagent@6.1.0: Please upgrade to v7.0.2+ of superagent. We have fixed numerous issues with streams, form-data, attach(), filesystem errors not bubbling up (ENOENT on attach()), and all tests are now passing. See the releases tab for more information at <https://github.com/visionmedia/superagent/releases>.
added 628 packages in 1m
43 packages are looking for funding
run `npm fund` for details
Okay, Node.js is latest already. onoff is needed for the Blynk Server. Side question: Are you still using it and does it still work well with the legacy (Android) app and/or with the Node-RED connector? Quite a pain that support and development for the home server was dropped in favour of their hosted variant.
node-red-contrib-blynk-iot could be installed locally:
npm r -g node-red-contrib-blynk-iot
and then either
cd /mnt/dietpi_userdata/node-red
sudo -u nodered npm i --no-audit node-red-contrib-blynk-iot
I’m using the new Blynk IoT version, but I’ve just removed the old “ws” version (as you say it’s a pain they dropped the home server version) and all nodes no longer in use.
But it still won’t update.
Then I hadn’t removed the unused nodes.
So next I’ll remove all nodes and try again, even if this is successful I’ll still move everything to a 64bit version as soon as my USB3 to SDD cable arrives. Mind you I’m now trying to figure out the necessary permissions for influxDB and Grafana so I can copy out the folders
