root@DietPi:~# ls -la /usr/share/lighttpd/
total 28
drwxr-xr-x 2 root root 4096 Nov 6 15:10 .
drwxr-xr-x 89 root root 4096 Nov 6 16:07 ..
-rwxr-xr-x 1 root root 6139 Jan 27 2019 create-mime.conf.pl
-rwxr-xr-x 1 root root 462 Sep 27 2019 include-conf-enabled.pl
-rw-r--r-- 1 root root 3388 Sep 27 2019 index.html
-rwxr-xr-x 1 root root 247 Sep 18 2020 use-ipv6.pl
ok let’s try following
sed -i 's/create-mime\.assign\.pl/create-mime.conf.pl/g' /etc/lighttpd/lighttpd.conf
systemctl restart lighttpd.service
OK - that’s got lighthttpd running again and I can hit the placeholder page. Great - thanks!
So, I think we’re at the point you wanted to get to (which was to get the base distro upgraded to Buster) and then, if I recall, it was PHP next because if I try the /nextcloud page I get the internal server error message which started off this whole conversation.
let’s check what version is installed
dpkg -l | grep 'php'
root@DietPi:~# dpkg -l | grep 'php'
ii libapache2-mod-php8.0 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf server-side, HTML-embedded scripting language (Apache 2 module)
ii php 2:8.0+84+0~20210621.36+debian9~1.gbp28513e all server-side, HTML-embedded scripting language (default)
ii php-apcu 5.1.20+4.0.11-1+0~20210304.24+debian9~1.gbp1c3d4d armhf APC User Cache for PHP
ii php-common 2:84+0~20210621.36+debian9~1.gbp28513e all Common files for PHP packages
ii php-igbinary 3.2.6+2.0.8-1+0~20210913.27+debian9~1.gbp64b0ea armhf igbinary PHP serializer
ii php-mysql 2:8.0+84+0~20210621.36+debian9~1.gbp28513e all MySQL module for PHP [default]
ii php-pear 1:1.10.12+submodules+notgz+20210212-1+0~20210228.21+debian9~1.gbpf2b98f all PEAR Base System
ii php-php-gettext 1.0.12-0.1 all read gettext MO files directly, without requiring anything other than PHP
ii php-phpseclib 2.0.14-1 all implementations of an arbitrary-precision integer arithmetic library
ii php-redis 5.3.4+4.3.0-1+0~20210329.35+debian9~1.gbpdc7ead armhf PHP extension for interfacing with Redis
ii php7.3-cli 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf command-line interpreter for the PHP scripting language
ii php7.3-common 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf documentation, examples and common module for PHP
rc php7.3-curl 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf CURL module for PHP
ii php7.3-fpm 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf server-side, HTML-embedded scripting language (FPM-CGI binary)
ii php7.3-gd 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf GD module for PHP
ii php7.3-intl 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf Internationalisation module for PHP
ii php7.3-json 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf JSON module for PHP
ii php7.3-mbstring 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf MBSTRING module for PHP
ii php7.3-mysql 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf MySQL module for PHP
ii php7.3-opcache 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf Zend OpCache module for PHP
ii php7.3-readline 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf readline module for PHP
ii php7.3-xml 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf DOM, SimpleXML, WDDX, XML, and XSL module for PHP
ii php7.3-zip 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 armhf Zip module for PHP
ii php8.0 8.0.11-1+0~20210923.24+debian9~1.gbp50d5dd all server-side, HTML-embedded scripting language (metapackage)
ii php8.0-apcu 5.1.20+4.0.11-1+0~20210304.24+debian9~1.gbp1c3d4d armhf APC User Cache for PHP
ii php8.0-cli 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf command-line interpreter for the PHP scripting language
ii php8.0-common 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf documentation, examples and common module for PHP
ii php8.0-igbinary 3.2.6+2.0.8-1+0~20210913.27+debian9~1.gbp64b0ea armhf igbinary PHP serializer
ii php8.0-mysql 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf MySQL module for PHP
ii php8.0-opcache 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf Zend OpCache module for PHP
ii php8.0-readline 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf readline module for PHP
ii php8.0-redis 5.3.4+4.3.0-1+0~20210329.35+debian9~1.gbpdc7ead armhf PHP extension for interfacing with Redis
ii phpmyadmin 4:4.6.6-5 all MySQL web administration tool
try following
apt purge '*php8.0*'
apt install php7.3-apcu php7.3-redis
Thanks again for your continued support on this.
I have run the commands and, as a precaution, rebooted the Pi. This appears to have killed lighthttpd again -
DietPi-Services
âââââââââââââââââââââââââââââââââââââââââââââââââââââ
Mode: status
[ OK ] DietPi-Services | redis-server active (running) since Sun 2021-11-07 17:42:59 GMT; 58s ago
[ OK ] DietPi-Services | mariadb active (running) since Sun 2021-11-07 17:43:01 GMT; 56s ago
[ OK ] DietPi-Services | php7.3-fpm active (running) since Sun 2021-11-07 17:43:02 GMT; 54s ago
[FAILED] DietPi-Services | â lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2021-11-07 17:43:06 GMT; 51s ago
Process: 765 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=255/EXCEPTION)
Nov 07 17:43:06 DietPi systemd[1]: lighttpd.service: Service RestartSec=100ms expired, scheduling restart.
Nov 07 17:43:06 DietPi systemd[1]: lighttpd.service: Scheduled restart job, restart counter is at 5.
Nov 07 17:43:06 DietPi systemd[1]: Stopped Lighttpd Daemon.
Nov 07 17:43:06 DietPi systemd[1]: lighttpd.service: Start request repeated too quickly.
Nov 07 17:43:06 DietPi systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Nov 07 17:43:06 DietPi systemd[1]: Failed to start Lighttpd Daemon.
[ OK ] DietPi-Services | cron active (running) since Sun 2021-11-07 17:43:03 GMT; 54s ago
[ OK ] DietPi-Services | ssh active (running) since Sun 2021-11-07 17:42:58 GMT; 59s ago
[ INFO ] DietPi-Services | dietpi-vpn inactive (dead)
[ OK ] DietPi-Services | dietpi-ramlog active (exited) since Sun 2021-11-07 17:42:47 GMT; 1min 10s ago
[ OK ] DietPi-Services | dietpi-preboot active (exited) since Sun 2021-11-07 17:42:47 GMT; 1min 10s ago
Warning: The unit file, source configuration file or drop-ins of dietpi-postboot.service changed on disk. Run 'systemctl daemon-reload' to reload units.
[ OK ] DietPi-Services | dietpi-postboot active (exited) since Sun 2021-11-07 17:42:58 GMT; 59s ago
[ INFO ] DietPi-Services | dietpi-wifi-monitor inactive (dead)
Though it looks like php 7.3 has installed and is running.
Pls share
Happy to. Still very grateful for your continued assistance -
WARNING: include-conf-enabled.pl is deprecated and slated for removal.
Replace in lighttpd.conf with:
include "/etc/lighttpd/conf-enabled/*.conf"
2021-11-08 09:55:11: (configfile.c.1328) opening configfile /etc/lighttpd/conf-enabled/50-phpmyadmin.conf failed: No such file or directory
2021-11-08 09:55:11: (configfile.c.1296) source: /usr/share/lighttpd/include-conf-enabled.pl line: 7 pos: 8 parser failed somehow near here: (EOL)
2021-11-08 09:55:11: (configfile.c.1296) source: /etc/lighttpd/lighttpd.conf line: 32 pos: 1 parser failed somehow near here: (EOL)
ah phpMyAdmin has been removed as well. Therefore config would need to be disabled
rm /etc/lighttpd/conf-enabled/50-phpmyadmin.conf
Hi -
OK - done that. Web service now running again, and I am able to hit the root placeholder page.
When trying the /nextcloud URL I now have something new. Instead of the generic “Internal server error” message I had been seeing previously, the system is now displaying a Nextcloud look-and-feel web page (logo, etc…) but with the following displayed in the middle of the page which I think was what you were originally working towards in respect of getting a response and then helping me to fix PHP -
Error
PHP module cURL not installed.
Please ask your server administrator to install the module.
PHP modules have been installed, but they are still listed as missing?
Please ask your server administrator to restart the web server.
let’s see if we can install the required module
apt update
apt install php7.3-curl
dietpi-services restart
Thanks (again)
It was looking encouraging and then this popped up when I attempted to install the following came up -
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
php7.3-curl : Depends: php7.3-common (= 7.3.31-1~deb10u1) but 7.3.31-1+0~20210923.88+debian9~1.gbpac4058 is to be installed
E: Unable to correct problems, you have held broken packages.
Thought I’d use some initiative and try
apt install php7.3-common
, but it reports that this module is already at the newest version (7.3.31-1+0~20210923.88+debian9~1.gbpac4058).
The key seems to be in these held broken packages.
Ah it’s still the incorrect package from stretch. Let’s check what is installed
Output of the command -
ic libapache2-mod-php8.0 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf server-side, HTML-embedded scripting language (Apache 2 module)
ii php-apcu 5.1.17+4.0.11-1 armhf APC User Cache for PHP
ii php-igbinary 3.0.0-1 armhf igbinary PHP serializer
ii php-redis 4.2.0-1 armhf PHP extension for interfacing with Redis
ic php8.0-apcu 5.1.20+4.0.11-1+0~20210304.24+debian9~1.gbp1c3d4d armhf APC User Cache for PHP
ic php8.0-cli 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf command-line interpreter for the PHP scripting language
ic php8.0-common 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf documentation, examples and common module for PHP
ic php8.0-igbinary 3.2.6+2.0.8-1+0~20210913.27+debian9~1.gbp64b0ea armhf igbinary PHP serializer
ic php8.0-mysql 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf MySQL module for PHP
ic php8.0-opcache 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf Zend OpCache module for PHP
ic php8.0-readline 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd armhf readline module for PHP
ic php8.0-redis 5.3.4+4.3.0-1+0~20210329.35+debian9~1.gbpdc7ead armhf PHP extension for interfacing with Redis
rc phpmyadmin 4:4.6.6-5 all MySQL web administration tool
let me ping our developer MichaIng to get this sorted and cleaned up. Still some old packages.
Many thanks - I’ll keep an eye open for the next update ![]()
So the issue is that PHP module packages depend on an exact version of php-common and hence when Ondrej’s repository is removed, no new module can be installed. php-common also cannot be downgraded as long as any module from Ondrej’s repo is installed.
Yeah looks like all of them need to be downgraded to the Debian Buster packages then.
First of all purge the remaining PHP8.0 packages:
G_AGP '*php8.0*'
There are also config files from phpMyAdmin left. If you don’t use it, purge it as well:
G_AGP phpmyadmin
If you want to use it, I suggest to install it via dietpi-software after the PHP module reinstalls below, which will pull the latest upstream version of phpMyAdmin, instead of the Debian package.
Then try to reinstall + downgrade all PHP (7.3) packages this way:
apt install --reinstall --allow-downgrades $(dpkg --get-selections '*php*' | mawk '{print $1}')
Thank you for joining this conversation. Joulinar has been absolutely brilliant up until this point, but needed your input - so I thank you again.
The first two commands worked fine from what I could see, but when I tried the last command this is what I saw -
Reinstallation of php-common is not possible, it cannot be downloaded.
Reinstallation of php7.3-cli is not possible, it cannot be downloaded.
Reinstallation of php7.3-common is not possible, it cannot be downloaded.
Reinstallation of php7.3-fpm is not possible, it cannot be downloaded.
Reinstallation of php7.3-gd is not possible, it cannot be downloaded.
Reinstallation of php7.3-intl is not possible, it cannot be downloaded.
Reinstallation of php7.3-json is not possible, it cannot be downloaded.
Reinstallation of php7.3-mbstring is not possible, it cannot be downloaded.
Reinstallation of php7.3-mysql is not possible, it cannot be downloaded.
Reinstallation of php7.3-opcache is not possible, it cannot be downloaded.
Reinstallation of php7.3-readline is not possible, it cannot be downloaded.
Reinstallation of php7.3-xml is not possible, it cannot be downloaded.
Reinstallation of php7.3-zip is not possible, it cannot be downloaded.
Please try:
apt purge php7.3-curl
apt update
