You can setup proxy from the SSH to forward ports. Example here
Otherwise you can open more addresses and ports on the firewall.
It doesn’t work, it gets stuck while trying to connect.
iptables-save -c ?
Generated by iptables-save v1.8.7 on Wed Oct 11 13:39:38 2023
*filter
:INPUT ACCEPT [0:0]
:FORWARD DROP [2:108]
:OUTPUT ACCEPT [0:0]
:DOCKER - [0:0]
:DOCKER-ISOLATION-STAGE-1 - [0:0]
:DOCKER-ISOLATION-STAGE-2 - [0:0]
:DOCKER-USER - [0:0]
[3051:158863] -A INPUT -s 192.168.0.0/16 -p tcp -m tcp --dport 9091 -j ACCEPT
[0:0] -A INPUT -s 192.168.0.0/16 -p tcp -m tcp --dport 8096 -j ACCEPT
[0:0] -A INPUT -s 192.168.0.0/16 -p tcp -m tcp --dport 9091 -j ACCEPT
[6:360] -A INPUT -s 10.0.0.0/8 -p tcp -m tcp --dport 22 -j ACCEPT
[270819:72868197] -A FORWARD -j DOCKER-USER
[270819:72868197] -A FORWARD -j DOCKER-ISOLATION-STAGE-1
[106010:23080734] -A FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
[690:37471] -A FORWARD -o docker0 -j DOCKER
[109457:42793400] -A FORWARD -i docker0 ! -o docker0 -j ACCEPT
[22:2575] -A FORWARD -i docker0 -o docker0 -j ACCEPT
[35:12995] -A FORWARD -o br-d9a46b4fb181 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
[0:0] -A FORWARD -o br-d9a46b4fb181 -j DOCKER
[45:2850] -A FORWARD -i br-d9a46b4fb181 ! -o br-d9a46b4fb181 -j ACCEPT
[0:0] -A FORWARD -i br-d9a46b4fb181 -o br-d9a46b4fb181 -j ACCEPT
[0:0] -A FORWARD -o br-64b8bd1bb8b5 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
[0:0] -A FORWARD -o br-64b8bd1bb8b5 -j DOCKER
[0:0] -A FORWARD -i br-64b8bd1bb8b5 ! -o br-64b8bd1bb8b5 -j ACCEPT
[0:0] -A FORWARD -i br-64b8bd1bb8b5 -o br-64b8bd1bb8b5 -j ACCEPT
[401509:134684763] -A FORWARD -o br-53881ace3f35 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
[329:17268] -A FORWARD -o br-53881ace3f35 -j DOCKER
[402610:61299114] -A FORWARD -i br-53881ace3f35 ! -o br-53881ace3f35 -j ACCEPT
[0:0] -A FORWARD -i br-53881ace3f35 -o br-53881ace3f35 -j ACCEPT
[0:0] -A FORWARD -o br-353dfaeb6856 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
[0:0] -A FORWARD -o br-353dfaeb6856 -j DOCKER
[0:0] -A FORWARD -i br-353dfaeb6856 ! -o br-353dfaeb6856 -j ACCEPT
[0:0] -A FORWARD -i br-353dfaeb6856 -o br-353dfaeb6856 -j ACCEPT
[6:312] -A DOCKER -d 172.20.0.2/32 ! -i br-53881ace3f35 -o br-53881ace3f35 -p tcp -m tcp --dport 5055 -j ACCEPT
[0:0] -A DOCKER -d 172.17.0.3/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 51413 -j ACCEPT
[0:0] -A DOCKER -d 172.19.0.2/32 ! -i br-d9a46b4fb181 -o br-d9a46b4fb181 -p tcp -m tcp --dport 6595 -j ACCEPT
[0:0] -A DOCKER -d 172.17.0.3/32 ! -i docker0 -o docker0 -p udp -m udp --dport 51413 -j ACCEPT
[0:0] -A DOCKER -d 172.17.0.3/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 9091 -j ACCEPT
[0:0] -A DOCKER -d 172.17.0.4/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 9000 -j ACCEPT
[0:0] -A DOCKER -d 172.17.0.5/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 8083 -j ACCEPT
[668:34896] -A DOCKER -d 172.17.0.6/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 80 -j ACCEPT
[0:0] -A DOCKER -d 172.17.0.2/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 3129 -j ACCEPT
[109457:42793400] -A DOCKER-ISOLATION-STAGE-1 -i docker0 ! -o docker0 -j DOCKER-ISOLATION-STAGE-2
[9:570] -A DOCKER-ISOLATION-STAGE-1 -i br-d9a46b4fb181 ! -o br-d9a46b4fb181 -j DOCKER-ISOLATION-STAGE-2
[0:0] -A DOCKER-ISOLATION-STAGE-1 -i br-64b8bd1bb8b5 ! -o br-64b8bd1bb8b5 -j DOCKER-ISOLATION-STAGE-2
[28173:2666890] -A DOCKER-ISOLATION-STAGE-1 -i br-53881ace3f35 ! -o br-53881ace3f35 -j DOCKER-ISOLATION-STAGE-2
[0:0] -A DOCKER-ISOLATION-STAGE-1 -i br-353dfaeb6856 ! -o br-353dfaeb6856 -j DOCKER-ISOLATION-STAGE-2
[270821:72868305] -A DOCKER-ISOLATION-STAGE-1 -j RETURN
[0:0] -A DOCKER-ISOLATION-STAGE-2 -o docker0 -j DROP
[0:0] -A DOCKER-ISOLATION-STAGE-2 -o br-d9a46b4fb181 -j DROP
[0:0] -A DOCKER-ISOLATION-STAGE-2 -o br-64b8bd1bb8b5 -j DROP
[0:0] -A DOCKER-ISOLATION-STAGE-2 -o br-53881ace3f35 -j DROP
[0:0] -A DOCKER-ISOLATION-STAGE-2 -o br-353dfaeb6856 -j DROP
[137639:45460860] -A DOCKER-ISOLATION-STAGE-2 -j RETURN
[10568837:7443229852] -A DOCKER-USER -j RETURN
COMMIT
# Completed on Wed Oct 11 13:39:38 2023
# Generated by iptables-save v1.8.7 on Wed Oct 11 13:39:38 2023
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:DOCKER - [0:0]
[12858:777038] -A PREROUTING -m addrtype --dst-type LOCAL -j DOCKER
[8108:662136] -A OUTPUT ! -d 127.0.0.0/8 -m addrtype --dst-type LOCAL -j DOCKER
[40498:3393458] -A POSTROUTING -s 172.17.0.0/16 ! -o docker0 -j MASQUERADE
[15:900] -A POSTROUTING -s 172.19.0.0/16 ! -o br-d9a46b4fb181 -j MASQUERADE
[0:0] -A POSTROUTING -s 172.21.0.0/16 ! -o br-64b8bd1bb8b5 -j MASQUERADE
[167350:10598122] -A POSTROUTING -s 172.20.0.0/16 ! -o br-53881ace3f35 -j MASQUERADE
[0:0] -A POSTROUTING -s 172.18.0.0/16 ! -o br-353dfaeb6856 -j MASQUERADE
[0:0] -A POSTROUTING -s 172.20.0.2/32 -d 172.20.0.2/32 -p tcp -m tcp --dport 5055 -j MASQUERADE
[0:0] -A POSTROUTING -s 172.17.0.3/32 -d 172.17.0.3/32 -p tcp -m tcp --dport 51413 -j MASQUERADE
[0:0] -A POSTROUTING -s 172.19.0.2/32 -d 172.19.0.2/32 -p tcp -m tcp --dport 6595 -j MASQUERADE
[0:0] -A POSTROUTING -s 172.17.0.3/32 -d 172.17.0.3/32 -p udp -m udp --dport 51413 -j MASQUERADE
[0:0] -A POSTROUTING -s 172.17.0.3/32 -d 172.17.0.3/32 -p tcp -m tcp --dport 9091 -j MASQUERADE
[0:0] -A POSTROUTING -s 172.17.0.4/32 -d 172.17.0.4/32 -p tcp -m tcp --dport 9000 -j MASQUERADE
[0:0] -A POSTROUTING -s 172.17.0.5/32 -d 172.17.0.5/32 -p tcp -m tcp --dport 8083 -j MASQUERADE
[0:0] -A POSTROUTING -s 172.17.0.6/32 -d 172.17.0.6/32 -p tcp -m tcp --dport 80 -j MASQUERADE
[0:0] -A POSTROUTING -s 172.17.0.2/32 -d 172.17.0.2/32 -p tcp -m tcp --dport 3129 -j MASQUERADE
[4218:253050] -A DOCKER -i docker0 -j RETURN
[0:0] -A DOCKER -i br-d9a46b4fb181 -j RETURN
[0:0] -A DOCKER -i br-64b8bd1bb8b5 -j RETURN
[4167:250020] -A DOCKER -i br-53881ace3f35 -j RETURN
[0:0] -A DOCKER -i br-353dfaeb6856 -j RETURN
[6:312] -A DOCKER ! -i br-53881ace3f35 -p tcp -m tcp --dport 5055 -j DNAT --to-destination 172.20.0.2:5055
[0:0] -A DOCKER ! -i docker0 -p tcp -m tcp --dport 51414 -j DNAT --to-destination 172.17.0.3:51413
[0:0] -A DOCKER ! -i br-d9a46b4fb181 -p tcp -m tcp --dport 6595 -j DNAT --to-destination 172.19.0.2:6595
[0:0] -A DOCKER ! -i docker0 -p udp -m udp --dport 51414 -j DNAT --to-destination 172.17.0.3:51413
[0:0] -A DOCKER ! -i docker0 -p tcp -m tcp --dport 9091 -j DNAT --to-destination 172.17.0.3:9091
[0:0] -A DOCKER ! -i docker0 -p tcp -m tcp --dport 9002 -j DNAT --to-destination 172.17.0.4:9000
[0:0] -A DOCKER ! -i docker0 -p tcp -m tcp --dport 8083 -j DNAT --to-destination 172.17.0.5:8083
[668:34896] -A DOCKER ! -i docker0 -p tcp -m tcp --dport 80 -j DNAT --to-destination 172.17.0.6:80
[0:0] -A DOCKER ! -i docker0 -p tcp -m tcp --dport 3129 -j DNAT --to-destination 172.17.0.2:3129
COMMIT
It will not work if you have allowed 192.168.0.0/16 but you are trying from 10.0.0.0/8.
Also please use preformated text for console output. Enclose the text inside 3 backquotes.
text here
which shows like this
text here
Sorry my bad. I’ve edited the format.
[6:360] -A INPUT -s 10.0.0.0/8 -p tcp -m tcp --dport 22 -j ACCEPT?
Format is okay now, but the problem remains that you are trying to connect from 10.0.0.0/8 and you don’t allow it for ports 8096, and 9001
Thank you for your patience. Now I see what you meant.
I’ll add the following to the up script and try again:
iptables -A INPUT -s 10.0.0.0/8 -p tcp -m tcp --dport 8096 -j ACCEPT
iptables -A INPUT -s 10.0.0.0/8 -p tcp -m tcp --dport 9091 -j ACCEPT
