Speed ttyS0 not correct if ARM Temp Limit : [45'c]
Good afternoon.
DietPi-Config
3 : Performance Options
ARM Temp Limit : [50’c]
if set speed 115200 t_bit ~=9 mks
if set speed 9600 t_bit ~=104 mks
DietPi-Config
ARM Temp Limit : [45’c]
if set speed 115200 t_bit ~=16 mks
if set speed 9600 t_bit ~=160 mks
Why is the operation speed (strobe frequency of the UART port) incorrectly set when the temperature limit is set to 45 degrees?
Sergey
Forgot to specify the board:
Board Raspberry Pi 3 b+, DietPi_RPi-ARMv8-Bullseye_.7z.
