Reinstalling is where the trouble started.
Now, when I reinstall mariadb only, it goes well, but starting the service fails. (lighttpd and ncc too).
When I use the combined reinstall as suggested in the bullseye upgrade hint (dietpi-software reinstall 38 40 47 48 56 83 84 85 88 89 93 114 143), the latter services startup fine, just mariadb fails.
dietpi-software reinstall 88
[ OK ] DietPi-Software | Initialised database
[ OK ] DietPi-Software | Reading database
DietPi-Software
Mode: Automated reinstall
[ OK ] DietPi-Software | Reinstalling MariaDB: Persistent cached file-per-table database server
[ OK ] DietPi-Software | Free space check: path=/ | available=4179 MiB | required=500 MiB
[ OK ] DietPi-Software | DietPi-Userdata validation: /mnt/usb_1/dietpi_userdata
[ OK ] DietPi-Software | Checking network connectivity
[ OK ] DietPi-Software | Checking DNS resolver
[ OK ] Network time sync | Completed
[ SUB1 ] DietPi-Services > unmask
[ OK ] DietPi-Services | unmask : nmbd
[ OK ] DietPi-Services | unmask : smbd
[ OK ] DietPi-Services | unmask : redis-server
[ OK ] DietPi-Services | unmask : mariadb
[ OK ] DietPi-Services | unmask : postgresql
[ OK ] DietPi-Services | unmask : php7.4-fpm
[ OK ] DietPi-Services | unmask : lighttpd
[ OK ] DietPi-Services | unmask : jellyfin
[ OK ] DietPi-Services | unmask : cron
[ SUB1 ] DietPi-Services > stop
[ OK ] DietPi-Services | stop : cron
[ OK ] DietPi-Services | stop : jellyfin
[ OK ] DietPi-Services | stop : lighttpd
[ OK ] DietPi-Services | stop : php7.4-fpm
[ OK ] DietPi-Services | stop : postgresql
[ OK ] DietPi-Services | stop : mariadb
[ OK ] DietPi-Services | stop : redis-server
[ OK ] DietPi-Services | stop : smbd
[ OK ] DietPi-Services | stop : nmbd
[ OK ] DietPi-Software | mkdir -p /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads /var/www /opt /usr/local/bin
[ OK ] DietPi-Software | chown dietpi:dietpi /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads
[ OK ] DietPi-Software | chmod 0775 /mnt/dietpi_userdata/Music /mnt/dietpi_userdata/Pictures /mnt/dietpi_userdata/Video /mnt/dietpi_userdata/downloads
[ INFO ] DietPi-Software | APT update, please wait...
Hit:1 https://deb.debian.org/debian bullseye InRelease
Hit:2 https://dietpi.com/meveric all InRelease
Get:3 https://deb.debian.org/debian bullseye-updates InRelease [39.4 kB]
Hit:4 https://dietpi.com/meveric bullseye InRelease
Hit:5 https://deb.debian.org/debian-security bullseye-security InRelease
Get:6 https://deb.debian.org/debian bullseye-backports InRelease [40.9 kB]
Get:7 https://repo.jellyfin.org/debian bullseye InRelease [6639 B]
Fetched 86.9 kB in 3s (29.1 kB/s)
Reading package lists...
[ OK ] DietPi-Software | APT update
DietPi-Software
Step: Checking for prerequisite software
DietPi-Software
Step: Installing MariaDB: Persistent cached file-per-table database server
[ INFO ] DietPi-Software | Preparing database directory at: /mnt/dietpi_userdata/mysql
[ INFO ] DietPi-Software | /mnt/dietpi_userdata/mysql exists, will migrate containing databases
[ OK ] DietPi-Software | rm -Rf /var/lib/mysql
[ OK ] DietPi-Software | ln -s /mnt/dietpi_userdata/mysql /var/lib/mysql
[ INFO ] DietPi-Software | APT install for: mariadb-server php7.4-mysql, please wait...
[ OK ] DietPi-Software | APT install for: mariadb-server php7.4-mysql
[ INFO ] DietPi-Software | Removing obsolete SysV mysql service
[ OK ] DietPi-Software | update-rc.d mysql remove
DietPi-Software
Step: Finalising install
[ OK ] DietPi-Software | systemctl daemon-reload
[ SUB1 ] DietPi-Services > dietpi_controlled
[ OK ] DietPi-Services | dietpi_controlled : nmbd
[ OK ] DietPi-Services | dietpi_controlled : smbd
[ OK ] DietPi-Services | dietpi_controlled : redis-server
[ OK ] DietPi-Services | dietpi_controlled : mariadb
[ OK ] DietPi-Services | dietpi_controlled : postgresql
[ OK ] DietPi-Services | dietpi_controlled : php7.4-fpm
[ OK ] DietPi-Services | dietpi_controlled : lighttpd
[ OK ] DietPi-Services | dietpi_controlled : jellyfin
[ OK ] DietPi-Services | dietpi_controlled : cron
DietPi-Software
Step: Install completed
[ OK ] DietPi-Survey | Purging survey data
[ SUB1 ] DietPi-Services > restart
[ OK ] DietPi-Services | restart : nmbd
[ OK ] DietPi-Services | restart : smbd
[ OK ] DietPi-Services | restart : redis-server
[FAILED] DietPi-Services | restart : mariadb
[ OK ] DietPi-Services | restart : postgresql
[ OK ] DietPi-Services | restart : php7.4-fpm
[FAILED] DietPi-Services | restart : lighttpd
[ OK ] DietPi-Services | restart : jellyfin
[ OK ] DietPi-Services | restart : cron
[FAILED] DietPi-Services | ncc maintenance:mode --off
# apt install --reinstall mariadb-server
Reading package lists... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 34.8 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 https://deb.debian.org/debian bullseye/main arm64 mariadb-server all 1:10.5.11-1 [34.8 kB]
Fetched 34.8 kB in 0s (98.0 kB/s)
(Reading database ... 35151 files and directories currently installed.)
Preparing to unpack .../mariadb-server_1%3a10.5.11-1_all.deb ...
Unpacking mariadb-server (1:10.5.11-1) over (1:10.5.11-1) ...
Setting up mariadb-server (1:10.5.11-1) ...
At the end, I can’t restart mariadb.service. Like before, without any useful error message.
Hmm in this case we might need to purge and remove everything related to mariadb otherwise I’m not sure how to fix but definitely you need a backup from before.
I have tried reinstalls both of entire LEMP package & Mariadb on its own. I have renamed & recreated all configuration folders but still have no luck. DietPi v7.6.2 (beta) with all upgrades done. I have no useful information to add - similar messages & lack of error.log.
I made a full dump of all databases prior upgrade to bullseye, so I’ll be happy to volunteer.
What would be the best way to purge/delete/install without killing my nextcloud from being restored?
…it might be worth mentioning that error.log seems to be disabled by default (/etc/mysql/mariadb.conf.d/50-server.conf)
# When running under systemd, error logging goes via stdout/stderr to journald
# and when running legacy init error logging goes to syslog due to
# /etc/mysql/conf.d/mariadb.conf.d/50-mysqld_safe.cnf
# Enable this if you want to have error logging into a separate file
#log_error = /var/log/mysql/error.log
