I finally found the way to reach also ubuntu (it was for some strange reason off line).
But when I lounch sudo touch /mnt/nfs_client/test
nothing appear… is this right?
Does it means it is working??
usually it succeed if it did not return anything.The command just created an empty file. can you try something to see if you are able to change permission and owner
sudo df -h
sudo ls -la /mnt/nfs_client
sudo chmod 777 /mnt/nfs_client/test
sudo chown dietpi:dietpi /mnt/nfs_client/test
I think it is working now. Isn’t it?
root@DietPi:~# sudo df -h
/dev/root 7.4G 3.4G 3.7G 49% /
devtmpfs 87M 0 87M 0% /dev
tmpfs 215M 4.4M 211M 3% /dev/shm
tmpfs 86M 11M 76M 13% /run
tmpfs 50M 28K 50M 1% /var/log
tmpfs 1.0G 0 1.0G 0% /tmp
/dev/mmcblk0p1 127M 52M 75M 42% /boot
/dev/sda1 916G 4.1G 912G 1% /mnt/ownclouddrive
192.168.1.112:/ 457G 210G 225G 49% /mnt/nfs_client
root@DietPi:~# sudo ls -la /mnt/nfs_client
total 8
drwxr-xr-x 2 root root 4096 Feb 11 23:17 .
drwxr-xr-x 9 root root 4096 Jan 22 15:58 ..
-rw-r--r-- 1 root root 0 Feb 11 23:18 test
root@DietPi:~# sudo chmod 777 /mnt/nfs_client/test
root@DietPi:~# sudo chown dietpi:dietpi /mnt/nfs_client/test
total 8
-rwxrwxrwx 1 dietpi dietpi 0 Feb 11 23:18 test
that seems to be working fine. Can you try to run a backup?
Again Great JOB.
The backup on Ubuntu is working…
Thanks a lot
So question is what has changed now? What was the trigger to allow the backup this time? ![]()
It’s a mistery… like often happens with IT affairs ![]()
Lol, always good to document every step you do when debugging issues, would have been quite interesting what it was
. However, great that it finally works.
It’s true MichaIng ,
the problem is I do not understand how we managed the situation. We went forward and back several times without really understand what was wrong.
I guess if someone follows the steps indicated in this tutorial https://phoenixnap.com/kb/ubuntu-nfs-server It should manage the situation easily.
Goodmorning everybody,
I re-open this topic because, after a long period I realized The daily backup is not working anymore.
I’ve tried to go back to the discussion, but I’m a little scared to follow the steps because I’m quite sure a lot of the work is already done.
For example: How can I check on the backup host (the Ubuntu server) if the right directory (where the backup will be hosted) is already done?
Maybe by doing this “reverse engineering” I can resume all the step followed ![]()
What is the error message if you try to execute a manual backup?
Hi @Joulinar , I haven’t tried to backup manually because when I go to the dietpi-backup page I can’t find the drive I would backup in, mounted. This is the reason why I’m not sure if it is already ready on the Ubuntu server.
is your backup drive still mounted?
df -h
Looks like it isn’t there:
/dev/root 7.4G 3.5G 3.6G 50% /
devtmpfs 207M 0 207M 0% /dev
tmpfs 239M 1.2M 238M 1% /dev/shm
tmpfs 96M 6.7M 89M 7% /run
tmpfs 50M 0 50M 0% /var/log
/dev/mmcblk0p1 127M 52M 75M 41% /boot
/dev/md0 916G 5.4G 864G 1% /mnt/raid1
tmpfs 48M 4.0K 48M 1% /run/user/998
tmpfs 48M 4.0K 48M 1% /run/user/0
Isn’t it?
Did you reboot your system in between? Maybe it is not yet mounted. Usually external drives are mounted once the are used only. (not automatically during boot). Did you checked drive manager if the configuration is still there?
I’m afraid I didn’t check it. How can I?
In between, I’ve rebooted it sometimes of course (just during some blackout). But the system rebooted alone without any problem.
Did you tried to open drive manager? Is the drive visible?
where in the dietpi consolle?
I opened it but I can’t see the drive
I’m neither sure the NFS is still working in the dietpi…
If it is not visible in drive manager, it is not mounted anymore and you would need to mount it again.
