Is it normal that the backup is still running after 2 hours and a half?
Still running all the rsync: [receiver] chown “/mnt/nfs_client/…” failed: Operation not permitted (1) rows…
sometimes it shows a percentage… now it’s around 99%
execution time depends on target server speed. Anyway I guess the backup will not be correct as it is not able to set correct owner
I have no idea what went wrong.
I will try to get your current state of your config.
On your Ubuntu machine, make
ls -la /mnt/dietpibkp
and
cat /etc/exports
and
df -h
and show us the output pls.
On your Dietpi make
ls -la /mnt/nfs_client
and
df -h
and
cat /etc/fstab
This is the Ubuntu output:
totale 7456
drwxrwxrwx 4 nobody nogroup 4096 gen 27 21:14 .
drwxr-xr-x 3 root root 4096 gen 18 08:50 ..
drwxr-xr-x 11 nobody nogroup 4096 gen 28 00:00 data
-rw-r--r-- 1 nobody nogroup 0 gen 26 19:36 demo.file
drwxr-xr-x 4 nobody nogroup 4096 gen 27 18:00 dietpi-backup
-rw-r--r-- 1 nobody nogroup 7613185 gen 28 00:00 dietpi-backup.log
ghezzia@NASCasaGhezzi:~$ cat /etc/exports
# /etc/exports: the access control list for filesystems which may be exported
# to NFS clients. See exports(5).
# Example for NFSv2 and NFSv3:
# /srv/homes hostname1(rw,sync,no_subtree_check) hostname2(ro,sync,no_subtree_check)
# Example for NFSv4:
# /srv/nfs4 gss/krb5i(rw,sync,fsid=0,crossmnt,no_subtree_check)
# /srv/nfs4/homes gss/krb5i(rw,sync,no_subtree_check)
/mnt/dietpibkp 192.168.1.15(rw,sync,no_root_squash,no_subtree_check)
ghezzia@NASCasaGhezzi:~$ df -h
File system Dim. Usati Dispon. Uso% Montato su
udev 3,8G 0 3,8G 0% /dev
tmpfs 775M 1,8M 774M 1% /run
/dev/sda2 457G 240G 195G 56% /
tmpfs 3,8G 640K 3,8G 1% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 3,8G 0 3,8G 0% /sys/fs/cgroup
/dev/loop4 128K 128K 0 100% /snap/bare/5
/dev/loop3 56M 56M 0 100% /snap/core18/2284
/dev/loop8 56M 56M 0 100% /snap/core18/2253
/dev/loop5 9,5M 9,5M 0 100% /snap/htop/3354
/dev/loop10 62M 62M 0 100% /snap/core20/1270
/dev/loop6 66M 66M 0 100% /snap/gtk-common-themes/1519
/dev/loop11 248M 248M 0 100% /snap/gnome-3-38-2004/87
/dev/loop7 219M 219M 0 100% /snap/gnome-3-34-1804/77
/dev/loop2 219M 219M 0 100% /snap/gnome-3-34-1804/72
/dev/loop12 51M 51M 0 100% /snap/snap-store/547
/dev/loop9 44M 44M 0 100% /snap/snapd/14295
/dev/loop0 66M 66M 0 100% /snap/gtk-common-themes/1515
/dev/loop14 55M 55M 0 100% /snap/snap-store/558
/dev/sda1 511M 5,3M 506M 2% /boot/efi
tmpfs 775M 56K 775M 1% /run/user/1000
/dev/loop15 44M 44M 0 100% /snap/snapd/14549
/dev/loop13 62M 62M 0 100% /snap/core20/1328
and this is the DietPi output:
root@DietPi:~# ls -la /mnt/nfs_client
total 7456
drwxrwxrwx 4 nobody nogroup 4096 Jan 27 21:14 .
drwxr-xr-x 9 root root 4096 Jan 22 15:58 ..
drwxr-xr-x 11 nobody nogroup 4096 Jan 28 00:00 data
-rw-r--r-- 1 nobody nogroup 0 Jan 26 19:36 demo.file
drwxr-xr-x 4 nobody nogroup 4096 Jan 27 18:00 dietpi-backup
-rw-r--r-- 1 nobody nogroup 7613185 Jan 28 00:00 dietpi-backup.log
root@DietPi:~# df -h
/dev/root 7.4G 3.4G 3.7G 49% /
devtmpfs 87M 0 87M 0% /dev
tmpfs 215M 3.5M 212M 2% /dev/shm
tmpfs 86M 11M 76M 13% /run
tmpfs 1.0G 0 1.0G 0% /tmp
tmpfs 50M 12K 50M 1% /var/log
/dev/mmcblk0p1 127M 52M 75M 42% /boot
/dev/sda1 916G 3.7G 913G 1% /mnt/ownclouddrive
192.168.1.96:/mnt/dietpibkp 457G 240G 195G 56% /mnt/nfs_client
/dev/sdb1 7.3G 3.6G 3.7G 49% /mnt/backup
root@DietPi:~# cat /etc/fstab
# NETWORK
192.168.1.96:/mnt/dietpibkp /mnt/nfs_client nfs nofail,noauto,x-systemd.automount
# TMPFS
tmpfs /tmp tmpfs size=1024M,noatime,lazytime,nodev,nosuid,mode=1777
tmpfs /var/log tmpfs size=50M,noatime,lazytime,nodev,nosuid,mode=1777
# MISC: ecryptfs, vboxsf (VirtualBox shared folder), gluster, bind mounts
# SWAP SPACE
/var/swap none swap sw
# PHYSICAL DRIVES
PARTUUID=0e2887fb-02 / ext4 noatime,lazytime,rw 0 1
PARTUUID=0e2887fb-01 /boot vfat noatime,lazytime,rw 0 2
UUID=614fbf4d-1260-405f-9f30-07d9c13067ce /mnt/ownclouddrive ext4 noatime,lazytime,rw,nofail,noauto,x-systemd.automount
UUID=2966eeaa-38a0-4cef-9469-fcd591d85249 /mnt/backup ext4 noatime,lazytime,rw,nofail,noauto,x-systemd.automount
I’m still guessing the issue is with the exported directory /mnt/dietpibkp as it belongs to nobody:nogroup. Maybe it would be an idea to clean the entire directory, change owner to root:root and try again.
ok, how can I clean the directory?
Do you mean on Ubuntu or Dietpi?
sudo rm -R /mnt/dietpibkp && sudo mkdir /mnt/dietpibkp && sudo chown root:root /mnt/dietpibkp
this directory only exists on your Ubuntu machine
Just some extra, not strictly necessary info:
I can’t confirm this after some more testing (Ok to be fair, I’m not testing with Ubuntu as host, but another Debian-based distro)
It worked for me with:
- nobody:nogroup @ /mnt/dietpibkp and the no_root_squash option in /etc/exports
- root:root @ /mnt/dietpibkp and the no_root_squash option in /etc/exports
Doesn’t worked with:
- nobody:nogroup @ /mnt/dietpibkp and WITHOUT no_root_squash option in /etc/exports
backup starts, but with same error as ghezzia when trying to run backup, respectively other errors when trying to choose the directory in dietpi-backup
- with root:root and WITHOUT no_root_squash option I get " Error creating test file /mnt/nfs_client/dietpi-backup/.test, unable to │
│ check filesystem permissions "
I’m excited what will happen at ghezzia’s machine
I followed the suggestion (on Ubuntu) but now a really strange thing happens.
I’m not sure this is related to the above command but, when I try to launch on dietpi the command dietpi-backup doesn’t show anything. I have to close and re-open the ssh connection to go back to the main menu…
the NFS mount is still working on your DietPi device?
reboot
cd /mnt/nfs_client
df -h
Here the output
root@DietPi:/mnt/nfs_client# df -h
tmpfs 215M 3.6M 212M 2% /dev/shm
tmpfs 86M 2.9M 84M 4% /run
tmpfs 50M 24K 50M 1% /var/log
192.168.1.96:/mnt/dietpibkp 457G 236G 199G 55% /mnt/nfs_client
Looks like it is working, isn’t it?
Anyway, I tried to launch the backup panel and it is working now ![]()
Can I try to backup again on Ubuntu? Or should I do something different before?
Just do a backup
nothing again. But now ti shows me this on a grey background:
Error creating test file /mnt/nfs_client/.test, unable to check filesystem │
│ permissions
and when I give OK
it shows me (still on a grey background):
Unsupported NFS share: │
│ /mnt/nfs_client is an NFS share which does not support UNIX permissions. │
│ Make sure that the NFS share at the server is located on a filesystem with │
│ native symlink and UNIX permissions support.
I got this exact same error when I didn’t set the “no_root_squash” option, but you didn’t change anything in your config?
What do you mean Jappe, change something on the server-side or client-side? On the Server-side I made a lot of configuration changes…
on server side
cat /etc/exports
What file system you are using on your Ubuntu device?
I hope this is what you meant.
cat /etc/exports
ghezzia@NASCasaGhezzi:~$ lsblk -o name,fstype,label,size,ro,type,mountpoint,partuuid,uuid
NAME FSTYPE LABEL SIZE RO TYPE MOUNTPOINT PARTUUID UUID
loop0
squash 65,1M 1 loop /snap/gtk-
loop2
squash 219M 1 loop /snap/gnom
loop3
squash 55,5M 1 loop /snap/core
loop4
squash 4K 1 loop /snap/bare
loop5
squash 9,5M 1 loop /snap/htop
loop6
squash 65,2M 1 loop /snap/gtk-
loop7
loop8
loop9
squash 43,3M 1 loop /snap/snap
loop10
squash 61,9M 1 loop /snap/core
loop11
squash 247,9M 1 loop /snap/gnom
loop12
squash 51M 1 loop /snap/snap
loop13
loop14
squash 54,2M 1 loop /snap/snap
loop15
squash 43,4M 1 loop /snap/snap
sda 465,8G 0 disk
├─sda1
│ vfat 512M 0 part /boot/efi dfc4bd90-7e16-4c68-959e-388224edab66 1C52-C2E5
└─sda2
ext4 465,3G 0 part / 00e960eb-6cb6-4920-b32c-22088102bf63 6dec19b1-fc8f-47a3-ba03-480aa448f543
Is this comprehensible for you?
It wasn’t able to check whether UNIX permissions and symlinks are supported on NFS server-side because it failed to create the test file. There is no way to check the filesystem type directly via NFS, hence a test file is created, its owner changed and checked whether this was successful. So its still an issue with write permissions
Before you start the backup for testing, always try whether you can create a file manually. If this fails, the backup attempt is unnecessary overhead
touch /mnt/nfs_client/test
creating the file was not an issue on past. It was changing ownership always. But yeah still issues with permissons on server side.
If I try with touch /mnt/nfs_client/test
and this is the output:
touch: cannot touch '/mnt/nfs_client/test': Permission denied
definitely a permission issue…
