I just tried to go ahead and try to back up the system while I wait to understand better the UFW.
I found and mounted the external drive on the NFS server configured on the ubuntu-desktop.
Once I try to change the backup location it shows me this:
DietPi-Backup ├───────────────────────────────────────────────────┐
│ - Command: mkdir -p /mnt/nfs_dietpibkp/dietpi-backup │
│ - Exit code: 1 │
│ - DietPi version: v8.0.2 (MichaIng/master) | HW_MODEL: 1 | HW_ARCH: 1 | DISTRO: 6 │
│ - Image creator: DietPi Core Team │
│ - Pre-image: from scratch │
│ - Error log: │
│ mkdir: cannot create directory ‘/mnt/nfs_dietpibkp/dietpi-backup’: Read-only file system │
│ Retry : Re-run the last command that failed │
│ DietPi-Config : Edit network, APT/NTP mirror settings etc │
│ Open subshell : Open a subshell to investigate or solve the issue │
│ Send report : Uploads bugreport containing system info to DietPi │
│ ●─ Devs only ──────────────────────────────────────● │
│ Change command : Adjust and rerun the command │
│ <Ok> <Exit>
As always what I’m doing wrong?
can you share following
showmount -e <ip_of_your_ubuntu>
cat /etc/fstab
Did you set the NFS export on Ubuntu to r/w?
this the output:
showmount -e <192.168.1.96> cat /etc/fstab
-bash: 192.168.1.96: No such file or directory
About the NFS export on ubuntu I followed the steps suggested here https://phoenixnap.com/kb/ubuntu-nfs-server, in the Export Shared Directory chapter… is this correct?
pls copy my commands one by one and not together in a single line. As well, pls remove place holder.
showmount -e 192.168.1.96
cat /etc/fstab
ops sorry
here it is:
root@DietPi:~# showmount -e 192.168.1.96
Export list for 192.168.1.96:
/mnt/dietpibkp 192.168.1.15
root@DietPi:~# cat /etc/fstab
# NETWORK
192.168.1.96:/ /mnt/nfs_client nfs nofail,noauto,x-systemd.automount
# TMPFS
tmpfs /tmp tmpfs size=1024M,noatime,lazytime,nodev,nosuid,mode=1777
tmpfs /var/log tmpfs size=50M,noatime,lazytime,nodev,nosuid,mode=1777
# MISC: ecryptfs, vboxsf (VirtualBox shared folder), gluster, bind mounts
# SWAP SPACE
/var/swap none swap sw
# PHYSICAL DRIVES
PARTUUID=0e2887fb-02 / ext4 noatime,lazytime,rw 0 1
PARTUUID=0e2887fb-01 /boot vfat noatime,lazytime,rw 0 2
UUID=614fbf4d-1260-405f-9f30-07d9c13067ce /mnt/ownclouddrive ext4 noatime,lazytime,rw,nofail,noauto,x-systemd.automount
UUID=2966eeaa-38a0-4cef-9469-fcd591d85249 /mnt/backup ext4 noatime,lazytime,rw,nofail,noauto,x-systemd.automount
You created the NFS export to be reachable for IP 192.168.1.15 only. This is correct?
ok pls do following
- open file /etc/fstab
nano /etc/fstab
- replace following line
with
192.168.1.96:/mnt/dietpibkp /mnt/nfs_client nfs nofail,noauto,x-systemd.automount
- save the file
- reboot your system
- check if the new mount is working
cd /mnt/nfs_client
df -h
touch demo.file
ls -la
done
root@DietPi:~# cd /mnt/nfs_client
root@DietPi:/mnt/nfs_client# df -h
/dev/root 7.4G 3.4G 3.7G 49% /
devtmpfs 87M 0 87M 0% /dev
tmpfs 215M 2.6M 213M 2% /dev/shm
tmpfs 86M 2.9M 84M 4% /run
tmpfs 1.0G 0 1.0G 0% /tmp
tmpfs 50M 20K 50M 1% /var/log
/dev/mmcblk0p1 127M 52M 75M 41% /boot
/dev/sda1 916G 3.7G 913G 1% /mnt/ownclouddrive
192.168.1.96:/mnt/dietpibkp 457G 236G 199G 55% /mnt/nfs_client
root@DietPi:/mnt/nfs_client# touch demo.file
root@DietPi:/mnt/nfs_client# ls -la
total 8
drwxrwxrwx 2 nobody nogroup 4096 Jan 21 18:36 .
drwxr-xr-x 9 root root 4096 Jan 21 15:03 ..
-rw-r--r-- 1 nobody nogroup 0 Jan 21 18:36 demo.file
Is this ok?
Yes looking good now. Try to run the backup.
thanks Joulinar
Now I found the location in the NFS server and it let me launch the backup but (there is always a but
After launch, it gives me a lot of: “failed: operation not permitted (1)”
Not only a lot, but every single file failed…
Sorry
I re-launched the backup and everything went well
Just the last question before closing the topic: Does the backup includes everything that is installed in the dietpi?
I mean does it include also everything is saved also in my personal cloud on owncloud?
Sorry, another question:
I saw the location of the backup is this one:
Current backup and restore location: │
│ - /mnt/backup/dietpi-backup
Is this the right place?
In the drive manager, I checked also the drive I thought the backup should be:
/mnt/nfs_client : 192.168.1.96:/mnt/dietpibkp | nfs4 | Capacity: 457G |
Is this right?
you would need to change backup location to /mnt/nfs_client
usually ownCloud data are included if they are located on SD card, as we include whole /mnt/dietpi_userdata/
You should be able to have a look into the backup folder to see what data are backed up
Sorry but… when i Change the backup location and try to launch the backup, it start again to give me “failed: operation not permitted
yes looks like permission issue. Have a look to NFS server side. I checked the guide and probably section Configure Shared Directory did not fit as you changed permissions to nobody:nogroup. Try to change the folder on Ubuntu to root:root
Nothing to do… still the same problem but I notice one thing:
when I mount the drive in dietpi I used this name: mnt/nfs_client, in fact when I try to select the new directory where to save the backup it shows me this option /mnt/nfs_client : 192.168.1.96:/ | size: 457GiB | available: 197GiB.
Since on ubuntu I called the drive /mnt/dietpibkp, could it be possible it cannot recognize the right directory?
can you do following
touch /mnt/nfs_client/demo2.file
ls -la /mnt/nfs_client/
chown root:root /mnt/nfs_client/demo2.file
chmod 777 /mnt/nfs_client/demo2.file
this is the output:
root@DietPi:~# touch /mnt/nfs_client/demo2.file
touch: cannot touch '/mnt/nfs_client/demo2.file': Read-only file system
root@DietPi:~# ls -la /mnt/nfs_client/
total 12
drwxr-xr-x 20 root root 4096 Apr 21 2021 .
drwxr-xr-x 9 root root 4096 Jan 22 15:58 ..
drwxr-xr-x 3 root root 4096 Jan 18 08:50 mnt
root@DietPi:~# chown root:root /mnt/nfs_client/demo2.file
chown: cannot access '/mnt/nfs_client/demo2.file': No such file or directory
root@DietPi:~# chmod 777 /mnt/nfs_client/demo2.file
chmod: cannot access '/mnt/nfs_client/demo2.file': No such file or directory
total 12
you still have permission issues to write to your NFS share.
Yes looks like… but how can I mount this drive /mnt/nfs_client : 192.168.1.96:/ | nfs4 | Capacity: 457G | Used: 237.4G if I have not permission on it? I mean: I see it, I can connect to it but I can’t write, read it?
Reading the share is not an issue. It’s writing files “only”
How does your /etc/exports looks like on server side.
