Sickrage not starting
Hello pals,
since last upgrade, sickrage won’t start in my rpi/kodi server. every other service is starting except sickrage.
here is the crash log :
Branch/Commit: starting sickrage
OS: DietPI / Raspberry PI 3
What you did: updated sickrage then restarted
What happened: sickrage not starting and crashing the pi
What you expected: sickrage to start
Logs:
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Wed Dec 20 18:40:31 UTC 2017
Kodi Options:
Arch: armv7l
Kernel: Linux 4.9.62-v7+ #2 SMP Fri Nov 17 23:52:26 GMT 2017
Release: Raspbian GNU/Linux 8 (jessie)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can’t get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
18:40:10.275 T:1946071712 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:40:10.275 T:1946071712 NOTICE: -----------------------------------------------------------------------
18:40:10.275 T:1946071712 NOTICE: Starting Kodi (17.3 Git:20170525-1789806-dirty). Platform: Linux ARM 32-bit
18:40:10.275 T:1946071712 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
18:40:10.275 T:1946071712 NOTICE: Kodi compiled May 25 2017 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
18:40:10.275 T:1946071712 NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.9.62-v7+
18:40:10.284 T:1946071712 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
18:40:10.284 T:1946071712 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
18:40:10.284 T:1946071712 NOTICE: ARM Features: Neon enabled
18:40:10.284 T:1946071712 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
18:40:10.284 T:1946071712 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
18:40:10.284 T:1946071712 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
18:40:10.284 T:1946071712 NOTICE: special://masterprofile/ is mapped to: /root/.kodi/userdata
18:40:10.284 T:1946071712 NOTICE: special://envhome/ is mapped to: /root
18:40:10.284 T:1946071712 NOTICE: special://home/ is mapped to: /root/.kodi
18:40:10.284 T:1946071712 NOTICE: special://temp/ is mapped to: /root/.kodi/temp
18:40:10.284 T:1946071712 NOTICE: special://logpath/ is mapped to: /root/.kodi/temp
18:40:10.284 T:1946071712 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin
18:40:10.284 T:1946071712 NOTICE: Local hostname: DietPi
18:40:10.285 T:1946071712 NOTICE: Log File is located: /root/.kodi/temp//kodi.log
18:40:10.285 T:1946071712 NOTICE: -----------------------------------------------------------------------
18:40:10.422 T:1946071712 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
18:40:10.441 T:1946071712 NOTICE: load settings…
18:40:10.611 T:1946071712 NOTICE: Found 2 Lists of Devices
18:40:10.611 T:1946071712 NOTICE: Enumerated PI devices:
18:40:10.611 T:1946071712 NOTICE: Device 1
18:40:10.611 T:1946071712 NOTICE: m_deviceName : HDMI
18:40:10.611 T:1946071712 NOTICE: m_displayName : HDMI
18:40:10.611 T:1946071712 NOTICE: m_displayNameExtra:
18:40:10.611 T:1946071712 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:40:10.611 T:1946071712 NOTICE: m_channels : FL,FR
18:40:10.611 T:1946071712 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
18:40:10.611 T:1946071712 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
18:40:10.611 T:1946071712 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
18:40:10.611 T:1946071712 NOTICE: Device 2
18:40:10.612 T:1946071712 NOTICE: m_deviceName : Analogue
18:40:10.612 T:1946071712 NOTICE: m_displayName : Analogue
18:40:10.612 T:1946071712 NOTICE: m_displayNameExtra:
18:40:10.612 T:1946071712 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:40:10.612 T:1946071712 NOTICE: m_channels : FL,FR
18:40:10.612 T:1946071712 NOTICE: m_sampleRates : 48000
18:40:10.612 T:1946071712 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
18:40:10.612 T:1946071712 NOTICE: m_streamTypes : No passthrough capabilities
18:40:10.612 T:1946071712 NOTICE: Device 3
18:40:10.612 T:1946071712 NOTICE: m_deviceName : Both
18:40:10.612 T:1946071712 NOTICE: m_displayName : HDMI and Analogue
18:40:10.612 T:1946071712 NOTICE: Enumerated ALSA devices:
18:40:10.612 T:1946071712 NOTICE: Device 1
18:40:10.612 T:1946071712 NOTICE: m_deviceName : @
18:40:10.612 T:1946071712 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
18:40:10.612 T:1946071712 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
18:40:10.612 T:1946071712 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
18:40:10.692 T:1946071712 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
18:40:10.692 T:1946071712 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are…
<?xml version="1.0" encoding="UTF-8" ?> 720 540 30 31457280 18:40:10.718 T:1946071712 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml) 18:40:10.718 T:1946071712 NOTICE: Default Video Player: VideoPlayer 18:40:10.718 T:1946071712 NOTICE: Default Audio Player: paplayer 18:40:10.718 T:1946071712 NOTICE: Disabled debug logging due to GUI setting. Level 0. 18:40:10.718 T:1946071712 NOTICE: Log level changed to "LOG_LEVEL_NORMAL" 18:40:10.718 T:1946071712 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml 18:40:10.727 T:1946071712 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml. 18:40:12.150 T:1946071712 NOTICE: Loaded playercorefactory configuration 18:40:12.151 T:1946071712 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml. 18:40:12.152 T:1946071712 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping. 19:40:23.992 T:1946071712 NOTICE: Running database version Addons27 19:40:26.628 T:1946071712 NOTICE: ADDONS: Using repository repository.xbmc.org 19:40:26.628 T:1946071712 NOTICE: ADDONS: Using repository repository.aresproject 19:40:26.628 T:1946071712 NOTICE: ADDONS: Using repository repository.colossus 19:40:26.628 T:1946071712 NOTICE: ADDONS: Using repository superrepo.kodi.krypton.repositories 19:40:26.628 T:1946071712 NOTICE: ADDONS: Using repository superrepo.kodi.krypton.subtitles 19:40:26.870 T:1946071712 NOTICE: Raspberry PI firmware version: Aug 8 2017 12:01:57 Copyright (c) 2012 Broadcom version 196063438d7bb0769861c86f948ae653727adb7e (clean) (release) 19:40:26.870 T:1946071712 NOTICE: ARM mem: 896MB GPU mem: 128MB MPG2:0 WVC1:0 19:40:26.870 T:1946071712 NOTICE: cache.memorysize: 30MB libass.cache: 0MB 19:40:26.870 T:1946071712 NOTICE: Config: arm_freq=1350 audio_pwm_mode=1 config_hdmi_boost=5 core_freq=400 desired_osc_freq=0x36ee80 disable_commandline_tags=2 disable_l2cache=1 disable_splash=1 force_eeprom_read=1 force_pwm_open=1 framebuffer_height=1080 framebuffer_ignore_alpha=1 framebuffer_swap=1 framebuffer_width=1920 gpu_freq=300 hdmi_channel_map=8 hdmi_force_cec_address=65535 init_uart_clock=0x2dc6c00 initial_turbo=20 lcd_framerate=60 over_voltage=5 over_voltage_avs=0x19f0a over_voltage_avs_boost=0x19f0a pause_burst_frames=1 program_serial_random=1 sdram_freq=450 temp_limit=75 19:40:26.870 T:1946071712 NOTICE: Config: device_tree=- 19:40:26.871 T:1946071712 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi 19:40:26.872 T:1946071712 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 72.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 71.928070 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 75.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 56.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 72.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 71.928070 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 75.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 70.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 75.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1152 x 864 for display 0 with 1152 x 864 @ 75.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1280 x 960 for display 0 with 1280 x 960 @ 60.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1280 x 960 for display 0 with 1280 x 960 @ 59.940063 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 60.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 59.940063 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 75.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 60.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 59.940063 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1440 x 1080 for display 0 with 1600 x 1200 @ 60.000000 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1440 x 1080 for display 0 with 1600 x 1200 @ 59.940063 Hz 19:40:26.873 T:1946071712 NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 60.000000 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 59.940063 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 1366 x 768 for display 0 with 1366 x 768 @ 60.000000 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 1366 x 768 for display 0 with 1366 x 768 @ 59.940063 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz 19:40:26.874 T:1946071712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz 19:40:26.874 T:1946071712 NOTICE: Found (1920x1080@60.000000) at 49, setting to RES_DESKTOP at 16 19:40:26.874 T:1946071712 NOTICE: Checking resolution 50 19:40:27.202 T:1946071712 NOTICE: GL_VENDOR = Broadcom 19:40:27.202 T:1946071712 NOTICE: GL_RENDERER = VideoCore IV HW 19:40:27.202 T:1946071712 NOTICE: GL_VERSION = OpenGL ES 2.0 19:40:27.202 T:1946071712 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00 19:40:27.202 T:1946071712 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker 19:40:28.696 T:1925182384 NOTICE: Running database version Addons27 19:40:28.700 T:1925182384 NOTICE: Running database version ViewModes6 19:40:28.707 T:1925182384 NOTICE: Running database version Textures13 19:40:28.730 T:1809666992 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001) 19:40:28.737 T:1925182384 NOTICE: Running database version MyMusic60 19:40:28.769 T:1925182384 NOTICE: Running database version MyVideos107 19:40:28.776 T:1925182384 NOTICE: Running database version TV29 19:40:28.781 T:1925182384 NOTICE: Running database version Epg11 19:40:28.787 T:1946071712 NOTICE: start dvd mediatype detection 19:40:29.563 T:1946071712 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList" 19:40:30.030 T:1946071712 NOTICE: UpdateLibraries: Starting video library startup scan 19:40:30.030 T:1946071712 NOTICE: UpdateLibraries: Starting music library startup scan 19:40:30.134 T:1946071712 NOTICE: initialize done 19:40:30.134 T:1946071712 NOTICE: Running the application... 19:40:30.145 T:1946071712 NOTICE: starting zeroconf publishing 19:40:30.151 T:1946071712 NOTICE: CWebServer[8080]: Started 19:40:30.151 T:1946071712 NOTICE: starting upnp client 19:40:30.203 T:1946071712 NOTICE: starting upnp server 19:40:30.221 T:1946071712 NOTICE: starting upnp renderer 19:40:30.230 T:1492120496 NOTICE: ES: Starting UDP Event server on port 9777 19:40:30.230 T:1492120496 NOTICE: UDP: Listening on port 9777 (ipv6 : true) 19:40:30.269 T:1637610416 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00 19:40:30.472 T:1925182384 NOTICE: VideoInfoScanner: Starting scan .. 19:40:31.434 T:1458566064 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.moviegenreicons.transparent/Reality.png 19:40:31.451 T:1458566064 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.moviegenreicons.transparent/Soap.png \ \ ############### END LOG FILE ################
############ END Kodi CRASH LOG #############
i can’t seem to understand what it comes from. i asked for help in the sickrage github but admin told me it isn’t a sickrage crash but kodi.
The log you posted is a crash log for Kodi, not Sickrage. If Sickrage is what you are trying to troubleshoot, then I guess you posted the wrong log.
Can you give us the output from
systemctl status sickrage
● sickrage.service - SickRage
   Loaded: loaded (/etc/systemd/system/sickrage.service; disabled)
   Active: failed (Result: exit-code) since Sat 2017-12-23 18:13:49 UTC; 1 day 1                                                         h ago
  Process: 1196 ExecStart=/usr/bin/python /etc/sickrage/SickBeard.py -q --daemon                                                          --nolaunch --datadir=/mnt/dietpi_userdata/sickrage (code=exited, status=1/FAILU                                                         RE)
Dec 23 18:13:49 DietPi python[1196]: File "/etc/sickrage/sickbeard/tv.py", line                                                          36, in <module>
Dec 23 18:13:49 DietPi python[1196]: from sickbeard import db, helpers, image_ca                                                         che, logger, network_timezones, notifiers, postProcessor, subtitles
Dec 23 18:13:49 DietPi python[1196]: File "/etc/sickrage/sickbeard/notifiers/__i                                                         nit__.py", line 24, in <module>
Dec 23 18:13:49 DietPi python[1196]: from sickbeard.notifiers import (boxcar2, d                                                         iscord, emailnotify, emby, freemobile, growl, join, kodi, libnotify, nma, nmj, n                                                         mjv2, plex, prowl, pushalot,
Dec 23 18:13:49 DietPi python[1196]: File "/etc/sickrage/sickbeard/notifiers/twe                                                         et.py", line 23, in <module>
Dec 23 18:13:49 DietPi python[1196]: import twitter
Dec 23 18:13:49 DietPi python[1196]: ImportError: No module named twitter
Dec 23 18:13:49 DietPi systemd[1]: sickrage.service: control process exited, cod                                                         e=exited status=1
Dec 23 18:13:49 DietPi systemd[1]: Failed to start SickRage.
Dec 23 18:13:49 DietPi systemd[1]: Unit sickrage.service entered failed state.
here it is :slight_smile:
Try
systemctl enable sickrage
systemctl start sickrage
It should now start on boot.
Tried that, still getting the same result even after restarting.
crash log :
Loaded: loaded (/etc/systemd/system/sickrage.service; enabled)
Active: failed (Result: exit-code) since Mon 2017-12-25 22:53:08 UTC; 2min 0s ago
Process: 575 ExecStart=/usr/bin/python /etc/sickrage/SickBeard.py -q --daemon --nolaunch --datadir=/mnt/dietpi_userdata/sickrage (code=exited, status=1/FAILUR E)
Dec 25 22:53:07 DietPi python[575]: File “/etc/sickrage/sickbeard/tv.py”, line 3 6, in
Dec 25 22:53:07 DietPi python[575]: from sickbeard import db, helpers, image_cac he, logger, network_timezones, notifiers, postProcessor, subtitles
Dec 25 22:53:07 DietPi python[575]: File “/etc/sickrage/sickbeard/notifiers/in it.py”, line 24, in
Dec 25 22:53:07 DietPi python[575]: from sickbeard.notifiers import (boxcar2, di scord, emailnotify, emby, freemobile, growl, join, kodi, libnotify, nma, nmj, nm jv2, plex, prowl, pushalot,
Dec 25 22:53:07 DietPi python[575]: File “/etc/sickrage/sickbeard/notifiers/twee t.py”, line 23, in
Dec 25 22:53:07 DietPi python[575]: import twitter
Dec 25 22:53:07 DietPi python[575]: ImportError: No module named twitter
Dec 25 22:53:08 DietPi systemd[1]: sickrage.service: control process exited, cod e=exited status=1
Dec 25 22:53:08 DietPi systemd[1]: Failed to start SickRage.
Dec 25 22:53:08 DietPi systemd[1]: Unit sickrage.service entered failed state.
up
Have you tried uninstall and then reinstall?
Backup the cache folder and the following files before uninstalling - sickbeard.db, cache.db, config.ini and failed.db.
Then reinstall and copy those files back.
John
