I am running dietpi headless and using the hdmi screen to display some stats over the terminal.
My problem is that after about 10 minutes the screen goes blank and I haven’t been able to find a way to prevent that.
many thanks for your message. Just for clarification: Headless means you are running without screen attached
Back to your topic. Probably you are hit by a screen saver. Ho do you display the stats via HDMI? Do you have some xsession running? Or a web browser? Or via plain CLI?
You’re right,
I meant to say that I don’t have a graphical desktop.
I am running padd on boot from .bashrc
That’s a pretty cool application!
I tried to replicate the issue on my RPi3B+ having a normal monitor attached via HDMI. But even after 40 minutes uptime, the screen did not go blank.
can you try to connect a normal screen (I guess you have a waveshare attached) to see how it behaving?
I was wondering if there is any OS/kernel-wise powersave/blanking mechanism as I only know about one through X server and of course the display itself may have one. However, in case of a little LCD I would have expected none as this is usually used to show something permanently without user input, compared to a larger monitor.
However did some search and found: http://ventures.tpedersen.net/projects/puttingraspberrypimonitortosleepdpms (no HTTPS, really? )
So please try to add consoleblank=0 to the end of the line in /boot/cmdline.txt.
Cmdline.txt in /boot/ didn’t exist, so I created one though I feel like this is not going to solve the issue.
Here’s what’s inside:
Automation_Custom_Script.sh FSCK0002.REC System.map-3.16.85+ config-3.16.85+ dietpi-LICENSE.txt dietpi.txt uInitrd
FSCK0000.REC Image boot.ini dietpi dietpi-README.md initrd.img-3.16.85+ uInitrd-3.16.85+
FSCK0001.REC 'System Volume Information' cmdlinfe.txt dietpi-CHANGELOG.txt dietpi-wifi.txt meson64_odroidc2.dtb vmlinuz-3.16.85+
Edit: I am on odroid c2, not sure if that makes a difference because what you linked is talking about rpi
Edit2: I found this https://odroid.com/dokuwiki/doku.php?id=en:c2_android_release_note_v1.9 but boot.ini didn’t have suspend_hdmiphy
Ah sorry I did erroneously assume it’s an RPi. On Odroid C2 add it to /boot/boot.ini setenv bootargs line into the double quotes. The cmdline.txt can be removed, as it is only effective on RPi.
That seems to have to the trick, thank!
