- DietPi version |
cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=9
G_DIETPI_VERSION_SUB=0
G_DIETPI_VERSION_RC=2
- Distro version |
bookworm 0
- Kernel version |
uname --all
uname --all
Linux pichiserver1 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
- Architecture |
dpkg --print-architecture
arm64
- SBC model |
echo $G_HW_MODEL_NAME
or (EG: RPi3)
RPi Zero 2 W (aarch64)
5V/2A -
integral 128Gb
Software title | (EG: Nextcloud)
No particular software was used -
Was the software title installed freshly or updated/migrated?
fresh installation -
Can this issue be replicated on a fresh installation of DietPi?
I dont see this issue on the x86 image on virtualbox
- Bug report ID |
echo $G_HW_UUID
No dietpi-bugreport was used
- Boot up the Pi zero 2 as usual
- Plug the USB stick (intergral 1tb) with a microUSB adapter
- No changes on the system, no device detected.
The device should be detected.
Some informative messages should appear on dmesg, lsusb and lsblk associated to the usb stick, at least.
Nothing, The system continues running as no usb stick was plugged.
no USB modules are loaded
# lsmod
Module Size Used by
sg 32768 0
binfmt_misc 20480 1
brcmfmac 331776 0
brcmutil 24576 1 brcmfmac
cfg80211 925696 1 brcmfmac
rfkill 32768 4 cfg80211
raspberrypi_hwmon 16384 0
i2c_bcm2835 16384 0
uio_pdrv_genirq 16384 0
uio 24576 1 uio_pdrv_genirq
i2c_dev 20480 0
i2c_bcm2708 16384 0
fuse 135168 1
dm_mod 139264 0
ip_tables 32768 0
x_tables 53248 1 ip_tables
ipv6 557056 40
# lsusb
# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk0 179:0 0 117.8G 0 disk
├─mmcblk0p1 179:1 0 128M 0 part /boot
└─mmcblk0p2 179:2 0 117.6G 0 part /
The usb stick is not present at all but it should
