Yes enabling autostart is done by systemctl enable
hmmm after a reboot the Fan runs 100% although the temperature is very lowβ¦
DietPi v7.9.3 : Update available
βββββββββββββββββββββββββββββββββββββββββββββββββββββ
- Device model : ROCKPro64 (aarch64)
- CPU temp : 25 Β°C / 77 Β°F : Who put me in the freezer!
- LAN IP : 192.168.2.5 (eth0)
- MOTD : Happy New Year, DietPi v8.0 is here:
https://dietpi.com/docs/releases/v8_0/
DietPi Team : MichaIng (lead), Daniel Knight (founder), Joulinar (support)
Image by : DietPi Core Team (pre-image: Armbian)
Web : https://dietpi.com | https://twitter.com/DietPi_
Patreon Legends : Camry2731
Contribute : https://dietpi.com/contribute.html
DietPi Hosting : Powered by https://myvirtualserver.com
dietpi-update : Run now to update DietPi from v7.9.3 to v8.0.2
dietpi-config : Feature rich configuration tool for your device
htop : Resource monitor
cpu : Shows CPU information and stats
A few days ago enabled the service to be started on boot:
systemctl enable --now ats
root@DietPi:~# service ats status
β ats.service - ATS - Active Thermal Service
Loaded: loaded (/usr/local/lib/luarocks/rocks/ats/master-0/ats.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2022-01-09 14:21:27 CET; 3min 0s ago
Main PID: 469 (lua)
Tasks: 1 (limit: 4463)
Memory: 1.4M
CPU: 26ms
CGroup: /system.slice/ats.service
ββ469 lua /usr/local/sbin/ats
Jan 09 14:21:27 DietPi systemd[1]: Started ATS - Active Thermal Service.
root@DietPi:~# service ats stop
Active: inactive (dead) since Sun 2022-01-09 14:25:25 CET; 29s ago
Process: 469 ExecStart=/usr/local/sbin/ats (code=killed, signal=TERM)
Main PID: 469 (code=killed, signal=TERM)
CPU: 31ms
Jan 09 14:25:25 DietPi systemd[1]: Stopping ATS - Active Thermal Service...
Jan 09 14:25:25 DietPi systemd[1]: ats.service: Succeeded.
Jan 09 14:25:25 DietPi systemd[1]: Stopped ATS - Active Thermal Service.
After a new Enable the Fan stopsβ¦
root@DietPi:~# systemctl enable --now ats
Active: active (running) since Sun 2022-01-09 14:26:41 CET; 6s ago
Main PID: 3844 (lua)
Memory: 324.0K
CPU: 15ms
ββ3844 lua /usr/local/sbin/ats
Jan 09 14:26:41 DietPi systemd[1]: Started ATS - Active Thermal Service.
there is no benefit of enabling the service again and again and again. Do following if you like to start or restart the service
systemctl start ats #this will start the service
systemctl stop ats #this will stop the service
systemctl restart ats #this will restart the service
systemctl status ats #this will show status of the service
journalctl -u ats #this will show some logs
the command
doesnβt enable also βautostartβ after a reboot, it just starts ats for the moment?
if not, what is the correct way to βautostartβ ats after a (re)boot?
systemctl enable is enabling the service to start on boot. This is needed only ONCE. It doesnβt need to be done every time again and again.
yes thought soβ¦
strange that the ats / fan was running after a reboot after enabeling with
βnow flag is starting the service. But same could be done using systemctl restart ats
But before doing this, check status and logs
journalctl -u ats
Yes sir ![]()
DietPi v8.0.2 : 3 APT updates available
- CPU temp : 35 Β°C / 95 Β°F : Cool runnings
- LAN IP : XXX.XXX.XXX.XXX (eth0)
root@DietPi:~# systemctl status ats
Active: active (running) since Sun 2022-01-09 14:26:41 CET; 6 days ago
Memory: 324.0K
CPU: 4.082s
root@DietPi:~# journalctl -u ats
-- Journal begins at Sun 2022-01-09 14:21:27 CET, ends at Sat 2022-01-15 17:03:23 CET. --
root@DietPi:~# systemctl restart ats
After a reboot the Fan is running again
DietPi v8.0.2 : 17:15 - Sat 01/15/22
- CPU temp : 28 Β°C / 82 Β°F : Who put me in the freezer!
Active: active (running) since Sat 2022-01-15 17:09:53 CET; 6min ago
Main PID: 473 (lua)
Memory: 1.5M
CPU: 22ms
ββ473 lua /usr/local/sbin/ats
Jan 15 17:09:53 DietPi systemd[1]: Started ATS - Active Thermal Service.
-- Journal begins at Sat 2022-01-15 17:09:52 CET, ends at Sat 2022-01-15 17:16:12 CET. --
After a Restart ats the Fan is OFF
Active: active (running) since Sat 2022-01-15 17:18:09 CET; 1min 15s ago
Main PID: 4712 (lua)
Memory: 320.0K
CPU: 14ms
ββ4712 lua /usr/local/sbin/ats
Jan 15 17:18:09 DietPi systemd[1]: Started ATS - Active Thermal Service.
-- Journal begins at Sat 2022-01-15 17:09:52 CET, ends at Sat 2022-01-15 17:18:09 CET. --
Jan 15 17:18:09 DietPi systemd[1]: Stopping ATS - Active Thermal Service...
Jan 15 17:18:09 DietPi systemd[1]: ats.service: Succeeded.
Jan 15 17:18:09 DietPi systemd[1]: Stopped ATS - Active Thermal Service.
So what is causing the problem that after a Reboot and starting ats the Fan keeps running?
honestly I donβt. Probably something to ask the maintainer of the script you are running. Maybe the service is starting to early? For dirty testing, you could add a sleep command into our service file definition. It should be placed within the [Service] section.
[Service]
ExecStartPre=/bin/sleep 30
Issue request at Github
https://github.com/tuxd3v/ats/issues/29
Which file is / what place is your service file definition located and named?
not sure what you mean with this
Where to add this in the service file definition?
In which file?
Is which path is this file located?
nano ....
Or to edit it via the graphic menu?
This should show the location
systemctl cat ats
That the service is starting too early was my idea as well. Probably journalctl reveals some ordering issue, i.e. ATS service starting and the fan being fully detected later. The sleep 30 should verify that, but probably we are able to find a smarter way by adding an After= definition to make the service start after the identified hardware device.
The location:
root@DietPi:~# systemctl cat ats
# /usr/local/lib/luarocks/rocks/ats/master-0/ats.service
[Unit]
Description=ATS - Active Thermal Service
After=local-fs.target
StartLimitIntervalSec=0
[Service]
Type=simple
Restart=always
RestartSec=8
User=root
[Install]
WantedBy=basic.target
Seems we can edit the parameter StartLimitIntervalSec=0
but this parameter did not delay the start.
https://www.freedesktop.org/software/systemd/man/systemd.unit.html#StartLimitIntervalSec=interval
Hello MichaIng
Here the journalctl after a fresh reboot
Part 1/2
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
DietPi v8.0.2 : 22:26 - Tue 01/18/22
- CPU temp : 32 Β°C / 89 Β°F : Cool runnings
-- Journal begins at Tue 2022-01-18 22:24:46 CET, ends at Tue 2022-01-18 22:26:02 CET. --
Jan 18 22:24:46 DietPi kernel: Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Jan 18 22:24:46 DietPi kernel: Linux version 5.10.63-rockchip64 (root@runner4) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.08.2 SMP PREEMPT Wed Sep 8 10:57:23 UTC 2021
Jan 18 22:24:46 DietPi kernel: Machine model: Pine64 RockPro64 v2.1
Jan 18 22:24:46 DietPi kernel: efi: UEFI not found.
Jan 18 22:24:46 DietPi kernel: NUMA: No NUMA configuration found
Jan 18 22:24:46 DietPi kernel: NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
Jan 18 22:24:46 DietPi kernel: NUMA: NODE_DATA [mem 0xf77e1100-0xf77e2fff]
Jan 18 22:24:46 DietPi kernel: Zone ranges:
Jan 18 22:24:46 DietPi kernel: DMA [mem 0x0000000000200000-0x00000000f7ffffff]
Jan 18 22:24:46 DietPi kernel: DMA32 empty
Jan 18 22:24:46 DietPi kernel: Normal empty
Jan 18 22:24:46 DietPi kernel: Movable zone start for each node
Jan 18 22:24:46 DietPi kernel: Early memory node ranges
Jan 18 22:24:46 DietPi kernel: node 0: [mem 0x0000000000200000-0x00000000f7ffffff]
Jan 18 22:24:46 DietPi kernel: Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
Jan 18 22:24:46 DietPi kernel: On node 0 totalpages: 1015296
Jan 18 22:24:46 DietPi kernel: DMA zone: 15864 pages used for memmap
Jan 18 22:24:46 DietPi kernel: DMA zone: 0 pages reserved
Jan 18 22:24:46 DietPi kernel: DMA zone: 1015296 pages, LIFO batch:63
Jan 18 22:24:46 DietPi kernel: cma: Reserved 128 MiB at 0x00000000e9000000
Jan 18 22:24:46 DietPi kernel: psci: probing for conduit method from DT.
Jan 18 22:24:46 DietPi kernel: psci: PSCIv1.0 detected in firmware.
Jan 18 22:24:46 DietPi kernel: psci: Using standard PSCI v0.2 function IDs
Jan 18 22:24:46 DietPi kernel: psci: MIGRATE_INFO_TYPE not supported.
Jan 18 22:24:46 DietPi kernel: psci: SMC Calling Convention v1.0
Jan 18 22:24:46 DietPi kernel: percpu: Embedded 33 pages/cpu s94232 r8192 d32744 u135168
Jan 18 22:24:46 DietPi kernel: pcpu-alloc: s94232 r8192 d32744 u135168 alloc=33*4096
Jan 18 22:24:46 DietPi kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
Jan 18 22:24:46 DietPi kernel: Detected VIPT I-cache on CPU0
Jan 18 22:24:46 DietPi kernel: CPU features: detected: ARM erratum 845719
Jan 18 22:24:46 DietPi kernel: CPU features: detected: GIC system register CPU interface
Jan 18 22:24:46 DietPi kernel: Built 1 zonelists, mobility grouping on. Total pages: 999432
Jan 18 22:24:46 DietPi kernel: Policy zone: DMA
Jan 18 22:24:46 DietPi kernel: Kernel command line: root=UUID=16fd56b1-1af3-4832-b584-e15c71d16b10 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=4 ubootpart=0db3c612-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u "net.ifnames=0"
Jan 18 22:24:46 DietPi kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Jan 18 22:24:46 DietPi kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Jan 18 22:24:46 DietPi kernel: mem auto-init: stack:off, heap alloc:on, heap free:off
Jan 18 22:24:46 DietPi kernel: Memory: 3808536K/4061184K available (14848K kernel code, 2630K rwdata, 5976K rodata, 4352K init, 578K bss, 121576K reserved, 131072K cma-reserved)
Jan 18 22:24:46 DietPi kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
Jan 18 22:24:46 DietPi kernel: rcu: Preemptible hierarchical RCU implementation.
Jan 18 22:24:46 DietPi kernel: rcu: RCU event tracing is enabled.
Jan 18 22:24:46 DietPi kernel: rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
Jan 18 22:24:46 DietPi kernel: Trampoline variant of Tasks RCU enabled.
Jan 18 22:24:46 DietPi kernel: Rude variant of Tasks RCU enabled.
Jan 18 22:24:46 DietPi kernel: Tracing variant of Tasks RCU enabled.
Jan 18 22:24:46 DietPi kernel: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Jan 18 22:24:46 DietPi kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
Jan 18 22:24:46 DietPi kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Jan 18 22:24:46 DietPi kernel: GICv3: GIC: Using split EOI/Deactivate mode
Jan 18 22:24:46 DietPi kernel: GICv3: 256 SPIs implemented
Jan 18 22:24:46 DietPi kernel: GICv3: 0 Extended SPIs implemented
Jan 18 22:24:46 DietPi kernel: GICv3: Distributor has no Range Selector support
Jan 18 22:24:46 DietPi kernel: GICv3: 16 PPIs implemented
Jan 18 22:24:46 DietPi kernel: GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
Jan 18 22:24:46 DietPi kernel: ITS [mem 0xfee20000-0xfee3ffff]
Jan 18 22:24:46 DietPi kernel: ITS@0x00000000fee20000: allocated 65536 Devices @500000 (flat, esz 8, psz 64K, shr 0)
Jan 18 22:24:46 DietPi kernel: ITS: using cache flushing for cmd queue
Jan 18 22:24:46 DietPi kernel: GICv3: using LPI property table @0x00000000004d0000
Jan 18 22:24:46 DietPi kernel: GIC: using cache flushing for LPI property table
Jan 18 22:24:46 DietPi kernel: GICv3: CPU0: using allocated LPI pending table @0x00000000004e0000
Jan 18 22:24:46 DietPi kernel: GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
Jan 18 22:24:46 DietPi kernel: GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
Jan 18 22:24:46 DietPi kernel: random: get_random_bytes called from start_kernel+0x690/0x848 with crng_init=0
Jan 18 22:24:46 DietPi kernel: arch_timer: cp15 timer(s) running at 24.00MHz (phys).
Jan 18 22:24:46 DietPi kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
Jan 18 22:24:46 DietPi kernel: sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
Jan 18 22:24:46 DietPi kernel: Console: colour dummy device 80x25
Jan 18 22:24:46 DietPi kernel: printk: console [tty1] enabled
Jan 18 22:24:46 DietPi kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
Jan 18 22:24:46 DietPi kernel: pid_max: default: 32768 minimum: 301
Jan 18 22:24:46 DietPi kernel: LSM: Security Framework initializing
Jan 18 22:24:46 DietPi kernel: Yama: becoming mindful.
Jan 18 22:24:46 DietPi kernel: AppArmor: AppArmor initialized
Jan 18 22:24:46 DietPi kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Jan 18 22:24:46 DietPi kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Jan 18 22:24:46 DietPi kernel: rcu: Hierarchical SRCU implementation.
Jan 18 22:24:46 DietPi kernel: Platform MSI: interrupt-controller@fee20000 domain created
Jan 18 22:24:46 DietPi kernel: PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
Jan 18 22:24:46 DietPi kernel: EFI services will not be available.
Jan 18 22:24:46 DietPi kernel: smp: Bringing up secondary CPUs ...
Jan 18 22:24:46 DietPi kernel: Detected VIPT I-cache on CPU1
Jan 18 22:24:46 DietPi kernel: GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
Jan 18 22:24:46 DietPi kernel: GICv3: CPU1: using allocated LPI pending table @0x00000000004f0000
Jan 18 22:24:46 DietPi kernel: CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Jan 18 22:24:46 DietPi kernel: Detected VIPT I-cache on CPU2
Jan 18 22:24:46 DietPi kernel: GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
Jan 18 22:24:46 DietPi kernel: GICv3: CPU2: using allocated LPI pending table @0x0000000000580000
Jan 18 22:24:46 DietPi kernel: CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Jan 18 22:24:46 DietPi kernel: Detected VIPT I-cache on CPU3
Jan 18 22:24:46 DietPi kernel: GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
Jan 18 22:24:46 DietPi kernel: GICv3: CPU3: using allocated LPI pending table @0x0000000000590000
Jan 18 22:24:46 DietPi kernel: CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Jan 18 22:24:46 DietPi kernel: CPU features: detected: Spectre-v2
Jan 18 22:24:46 DietPi kernel: CPU features: detected: Spectre-v4
Jan 18 22:24:46 DietPi kernel: CPU features: detected: ARM errata 1165522, 1319367, or 1530923
Jan 18 22:24:46 DietPi kernel: Detected PIPT I-cache on CPU4
Jan 18 22:24:46 DietPi kernel: GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
Jan 18 22:24:46 DietPi kernel: GICv3: CPU4: using allocated LPI pending table @0x00000000005a0000
Jan 18 22:24:46 DietPi kernel: CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
Jan 18 22:24:46 DietPi kernel: Detected PIPT I-cache on CPU5
Jan 18 22:24:46 DietPi kernel: GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
Jan 18 22:24:46 DietPi kernel: GICv3: CPU5: using allocated LPI pending table @0x00000000005b0000
Jan 18 22:24:46 DietPi kernel: CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
Jan 18 22:24:46 DietPi kernel: smp: Brought up 1 node, 6 CPUs
Jan 18 22:24:46 DietPi kernel: SMP: Total of 6 processors activated.
Jan 18 22:24:47 DietPi kernel: CPU features: detected: 32-bit EL0 Support
Jan 18 22:24:47 DietPi kernel: CPU features: detected: CRC32 instructions
Jan 18 22:24:47 DietPi kernel: CPU features: detected: 32-bit EL1 Support
Jan 18 22:24:47 DietPi kernel: CPU: All CPU(s) started at EL2
Jan 18 22:24:47 DietPi kernel: alternatives: patching kernel code
Jan 18 22:24:47 DietPi kernel: devtmpfs: initialized
Jan 18 22:24:47 DietPi kernel: Registered cp15_barrier emulation handler
Jan 18 22:24:47 DietPi kernel: Registered setend emulation handler
Jan 18 22:24:47 DietPi kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jan 18 22:24:47 DietPi kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Jan 18 22:24:47 DietPi kernel: pinctrl core: initialized pinctrl subsystem
Jan 18 22:24:47 DietPi kernel: DMI not present or invalid.
Jan 18 22:24:47 DietPi kernel: NET: Registered protocol family 16
Jan 18 22:24:47 DietPi kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Jan 18 22:24:47 DietPi kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Jan 18 22:24:47 DietPi kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Jan 18 22:24:47 DietPi kernel: audit: initializing netlink subsys (disabled)
Jan 18 22:24:47 DietPi kernel: audit: type=2000 audit(0.072:1): state=initialized audit_enabled=0 res=1
Jan 18 22:24:47 DietPi kernel: thermal_sys: Registered thermal governor 'fair_share'
Jan 18 22:24:47 DietPi kernel: thermal_sys: Registered thermal governor 'bang_bang'
Jan 18 22:24:47 DietPi kernel: thermal_sys: Registered thermal governor 'step_wise'
Jan 18 22:24:47 DietPi kernel: thermal_sys: Registered thermal governor 'user_space'
Jan 18 22:24:47 DietPi kernel: cpuidle: using governor menu
Jan 18 22:24:47 DietPi kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jan 18 22:24:47 DietPi kernel: ASID allocator initialised with 65536 entries
Jan 18 22:24:47 DietPi kernel: Serial: AMBA PL011 UART driver
Jan 18 22:24:47 DietPi kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Jan 18 22:24:47 DietPi kernel: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
Jan 18 22:24:47 DietPi kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Jan 18 22:24:47 DietPi kernel: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
Jan 18 22:24:47 DietPi kernel: cryptd: max_cpu_qlen set to 1000
Jan 18 22:24:47 DietPi kernel: raid6: neonx8 gen() 1665 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: neonx8 xor() 1240 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: neonx4 gen() 1683 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: neonx4 xor() 1269 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: neonx2 gen() 1502 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: neonx2 xor() 1177 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: neonx1 gen() 1177 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: neonx1 xor() 935 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: int64x8 gen() 994 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: int64x8 xor() 579 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: int64x4 gen() 985 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: int64x4 xor() 592 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: int64x2 gen() 926 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: int64x2 xor() 524 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: int64x1 gen() 725 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: int64x1 xor() 391 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: using algorithm neonx4 gen() 1683 MB/s
Jan 18 22:24:47 DietPi kernel: raid6: .... xor() 1269 MB/s, rmw enabled
Jan 18 22:24:47 DietPi kernel: raid6: using neon recovery algorithm
Jan 18 22:24:47 DietPi kernel: reg-fixed-voltage vcc1v8-s3: Failed to register regulator: -517
Jan 18 22:24:47 DietPi kernel: reg-fixed-voltage vcc3v0-sd: Failed to register regulator: -517
Jan 18 22:24:47 DietPi kernel: vcc3v3_pcie: supplied by vcc12v_dcin
Jan 18 22:24:47 DietPi kernel: reg-fixed-voltage vcc3v3-sys: Failed to register regulator: -517
Jan 18 22:24:47 DietPi kernel: reg-fixed-voltage vcc5v0-host-regulator: Failed to register regulator: -517
Jan 18 22:24:47 DietPi kernel: reg-fixed-voltage vcc5v0-typec-regulator: Failed to register regulator: -517
Jan 18 22:24:47 DietPi kernel: vcc5v0_sys: supplied by vcc12v_dcin
Jan 18 22:24:47 DietPi kernel: vcc5v0_usb: supplied by vcc12v_dcin
Jan 18 22:24:47 DietPi kernel: iommu: Default domain type: Translated
Jan 18 22:24:47 DietPi kernel: vgaarb: loaded
Jan 18 22:24:47 DietPi kernel: SCSI subsystem initialized
Jan 18 22:24:47 DietPi kernel: libata version 3.00 loaded.
Jan 18 22:24:47 DietPi kernel: usbcore: registered new interface driver usbfs
Jan 18 22:24:47 DietPi kernel: usbcore: registered new interface driver hub
Jan 18 22:24:47 DietPi kernel: usbcore: registered new device driver usb
Jan 18 22:24:47 DietPi kernel: pps_core: LinuxPPS API ver. 1 registered
Jan 18 22:24:47 DietPi kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jan 18 22:24:47 DietPi kernel: PTP clock support registered
Jan 18 22:24:47 DietPi kernel: EDAC MC: Ver: 3.0.0
Jan 18 22:24:47 DietPi kernel: NetLabel: Initializing
Jan 18 22:24:47 DietPi kernel: NetLabel: domain hash size = 128
Jan 18 22:24:47 DietPi kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
Jan 18 22:24:47 DietPi kernel: NetLabel: unlabeled traffic allowed by default
Jan 18 22:24:47 DietPi kernel: clocksource: Switched to clocksource arch_sys_counter
Jan 18 22:24:47 DietPi kernel: VFS: Disk quotas dquot_6.6.0
Jan 18 22:24:47 DietPi kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jan 18 22:24:47 DietPi kernel: AppArmor: AppArmor Filesystem Enabled
Jan 18 22:24:47 DietPi kernel: NET: Registered protocol family 2
Jan 18 22:24:47 DietPi kernel: IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
Jan 18 22:24:47 DietPi kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
Jan 18 22:24:47 DietPi kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
Jan 18 22:24:47 DietPi kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
Jan 18 22:24:47 DietPi kernel: TCP: Hash tables configured (established 32768 bind 32768)
Jan 18 22:24:47 DietPi kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
Jan 18 22:24:47 DietPi kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
Jan 18 22:24:47 DietPi kernel: NET: Registered protocol family 44
Jan 18 22:24:47 DietPi kernel: PCI: CLS 0 bytes, default 64
Jan 18 22:24:47 DietPi kernel: Trying to unpack rootfs image as initramfs...
Jan 18 22:24:47 DietPi kernel: Freeing initrd memory: 12148K
Jan 18 22:24:47 DietPi kernel: hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
Jan 18 22:24:47 DietPi kernel: hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
Jan 18 22:24:47 DietPi kernel: kvm [1]: IPA Size Limit: 40 bits
Jan 18 22:24:47 DietPi kernel: kvm [1]: vgic-v2@fff20000
Jan 18 22:24:47 DietPi kernel: kvm [1]: GIC system register CPU interface enabled
Jan 18 22:24:47 DietPi kernel: kvm [1]: vgic interrupt IRQ18
Jan 18 22:24:47 DietPi kernel: kvm [1]: Hyp mode initialized successfully
Jan 18 22:24:47 DietPi kernel: Initialise system trusted keyrings
Jan 18 22:24:47 DietPi kernel: Key type blacklist registered
Jan 18 22:24:47 DietPi kernel: workingset: timestamp_bits=44 max_order=20 bucket_order=0
Jan 18 22:24:47 DietPi kernel: zbud: loaded
Jan 18 22:24:47 DietPi kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 18 22:24:47 DietPi kernel: fuse: init (API version 7.32)
Jan 18 22:24:47 DietPi kernel: integrity: Platform Keyring initialized
Jan 18 22:24:47 DietPi kernel: xor: measuring software checksum speed
Jan 18 22:24:47 DietPi kernel: 8regs : 2531 MB/sec
Jan 18 22:24:47 DietPi kernel: 32regs : 2917 MB/sec
Jan 18 22:24:47 DietPi kernel: arm64_neon : 2398 MB/sec
Jan 18 22:24:47 DietPi kernel: xor: using function: 32regs (2917 MB/sec)
Jan 18 22:24:47 DietPi kernel: Key type asymmetric registered
Jan 18 22:24:47 DietPi kernel: Asymmetric key parser 'x509' registered
Jan 18 22:24:47 DietPi kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
Jan 18 22:24:47 DietPi kernel: io scheduler mq-deadline registered
Jan 18 22:24:47 DietPi kernel: io scheduler kyber registered
Jan 18 22:24:47 DietPi kernel: io scheduler bfq registered
Jan 18 22:24:47 DietPi kernel: rockchip-usb2phy ff770000.syscon:usb2-phy@e450: failed to create phy
Jan 18 22:24:47 DietPi kernel: rockchip-usb2phy ff770000.syscon:usb2-phy@e460: failed to create phy
Jan 18 22:24:47 DietPi kernel: rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
Jan 18 22:24:47 DietPi kernel: rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
Jan 18 22:24:47 DietPi kernel: rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
Jan 18 22:24:47 DietPi kernel: rockchip-pcie f8000000.pcie: supply vpcie1v8 not found, using dummy regulator
Jan 18 22:24:47 DietPi kernel: rockchip-pcie f8000000.pcie: supply vpcie0v9 not found, using dummy regulator
Jan 18 22:24:47 DietPi kernel: rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
Jan 18 22:24:47 DietPi kernel: pci_bus 0000:00: root bus resource [bus 00-1f]
Jan 18 22:24:47 DietPi kernel: pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
Jan 18 22:24:47 DietPi kernel: pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
Jan 18 22:24:47 DietPi kernel: pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
Jan 18 22:24:47 DietPi kernel: pci 0000:00:00.0: supports D1
Jan 18 22:24:47 DietPi kernel: pci 0000:00:00.0: PME# supported from D0 D1 D3hot
Jan 18 22:24:47 DietPi kernel: pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: [1b21:0612] type 00 class 0x010601
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x10: [io size 0x0008]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x14: [io size 0x0004]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x18: [io size 0x0008]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x1c: [io size 0x0004]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x20: [io size 0x0020]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x000001ff]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:00.0 (capable of 4.000 Gb/s with 5.0 GT/s PCIe x1 link)
Jan 18 22:24:47 DietPi kernel: pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
Jan 18 22:24:47 DietPi kernel: pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa0101ff]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 4: no space for [io size 0x0020]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 4: failed to assign [io size 0x0020]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 0: no space for [io size 0x0008]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 0: failed to assign [io size 0x0008]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 2: no space for [io size 0x0008]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 2: failed to assign [io size 0x0008]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 1: no space for [io size 0x0004]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 1: failed to assign [io size 0x0004]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 3: no space for [io size 0x0004]
Jan 18 22:24:47 DietPi kernel: pci 0000:01:00.0: BAR 3: failed to assign [io size 0x0004]
Jan 18 22:24:47 DietPi kernel: pci 0000:00:00.0: PCI bridge to [bus 01]
Jan 18 22:24:47 DietPi kernel: pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff]
Jan 18 22:24:47 DietPi kernel: pcieport 0000:00:00.0: enabling device (0000 -> 0002)
Jan 18 22:24:47 DietPi kernel: pcieport 0000:00:00.0: PME: Signaling with IRQ 76
Jan 18 22:24:47 DietPi kernel: pcieport 0000:00:00.0: AER: enabled with IRQ 76
Jan 18 22:24:47 DietPi kernel: dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
Jan 18 22:24:47 DietPi kernel: dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
Jan 18 22:24:47 DietPi kernel: dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
Jan 18 22:24:47 DietPi kernel: dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
Jan 18 22:24:47 DietPi kernel: vdd_log: supplied by regulator-dummy
Jan 18 22:24:47 DietPi kernel: Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
Jan 18 22:24:47 DietPi kernel: ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 46, base_baud = 1500000) is a 16550A
Jan 18 22:24:47 DietPi kernel: serial serial0: tty port ttyS0 registered
Jan 18 22:24:47 DietPi kernel: ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 47, base_baud = 1500000) is a 16550A
Jan 18 22:24:47 DietPi kernel: printk: console [ttyS2] enabled
Jan 18 22:24:47 DietPi kernel: Serial: AMBA driver
Jan 18 22:24:47 DietPi kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0
Jan 18 22:24:47 DietPi kernel: loop: module loaded
Jan 18 22:24:47 DietPi kernel: ahci 0000:01:00.0: version 3.0
Jan 18 22:24:47 DietPi kernel: ahci 0000:01:00.0: enabling device (0000 -> 0002)
Jan 18 22:24:47 DietPi kernel: ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
Jan 18 22:24:47 DietPi kernel: ahci 0000:01:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
Jan 18 22:24:47 DietPi kernel: ahci 0000:01:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
Jan 18 22:24:47 DietPi kernel: scsi host0: ahci
Jan 18 22:24:47 DietPi kernel: scsi host1: ahci
Jan 18 22:24:47 DietPi kernel: ata1: SATA max UDMA/133 abar m512@0xfa010000 port 0xfa010100 irq 77
Jan 18 22:24:47 DietPi kernel: ata2: SATA max UDMA/133 abar m512@0xfa010000 port 0xfa010180 irq 77
Jan 18 22:24:47 DietPi kernel: spi-nor spi0.0: gd25q128 (16384 Kbytes)
Jan 18 22:24:47 DietPi kernel: libphy: Fixed MDIO Bus: probed
Jan 18 22:24:47 DietPi kernel: tun: Universal TUN/TAP device driver, 1.6
Jan 18 22:24:47 DietPi kernel: thunder_xcv, ver 1.0
Jan 18 22:24:47 DietPi kernel: thunder_bgx, ver 1.0
Jan 18 22:24:47 DietPi kernel: nicpf, ver 1.0
Jan 18 22:24:47 DietPi kernel: e1000e: Intel(R) PRO/1000 Network Driver
Jan 18 22:24:47 DietPi kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jan 18 22:24:47 DietPi kernel: igb: Intel(R) Gigabit Ethernet Network Driver
Jan 18 22:24:47 DietPi kernel: igb: Copyright (c) 2007-2014 Intel Corporation.
Jan 18 22:24:47 DietPi kernel: igbvf: Intel(R) Gigabit Virtual Function Network Driver
Jan 18 22:24:47 DietPi kernel: igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Jan 18 22:24:47 DietPi kernel: sky2: driver version 1.30
Jan 18 22:24:47 DietPi kernel: VFIO - User Level meta-driver version: 0.3
Jan 18 22:24:47 DietPi kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 18 22:24:47 DietPi kernel: ehci-pci: EHCI PCI platform driver
Jan 18 22:24:47 DietPi kernel: ehci-platform: EHCI generic platform driver
Jan 18 22:24:47 DietPi kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jan 18 22:24:47 DietPi kernel: ohci-pci: OHCI PCI platform driver
Jan 18 22:24:47 DietPi kernel: ohci-platform: OHCI generic platform driver
Jan 18 22:24:47 DietPi kernel: usbcore: registered new interface driver usb-storage
Jan 18 22:24:47 DietPi kernel: mousedev: PS/2 mouse device common for all mice
Jan 18 22:24:47 DietPi kernel: i2c /dev entries driver
Jan 18 22:24:47 DietPi kernel: rk808 0-001b: chip id: 0x0
Jan 18 22:24:47 DietPi kernel: rk808-regulator rk808-regulator: there is no dvs0 gpio
Jan 18 22:24:47 DietPi kernel: rk808-regulator rk808-regulator: there is no dvs1 gpio
Jan 18 22:24:47 DietPi kernel: rk808-regulator rk808-regulator: max buck steps per change: 8
Jan 18 22:24:47 DietPi kernel: vdd_center: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vdd_cpu_l: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vcc_ddr: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vcc_1v8: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vcc1v8_dvp: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vcc3v0_touch: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vcca_1v8: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vcc_sdio: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vcca3v0_codec: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vcc_1v5: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vcca1v8_codec: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vcc_3v0: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: rk808 0-001b: failed to register 12 regulator
Jan 18 22:24:47 DietPi kernel: rk808-rtc rk808-rtc: registered as rtc0
Jan 18 22:24:47 DietPi kernel: rk808-rtc rk808-rtc: setting system clock to 2022-01-18T21:24:37 UTC (1642541077)
Jan 18 22:24:47 DietPi kernel: fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
Jan 18 22:24:47 DietPi kernel: vdd_cpu_b: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
Jan 18 22:24:47 DietPi kernel: vdd_gpu: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: random: fast init done
Jan 18 22:24:47 DietPi kernel: dw_wdt ff848000.watchdog: No valid TOPs array specified
Jan 18 22:24:47 DietPi kernel: sdhci: Secure Digital Host Controller Interface driver
Jan 18 22:24:47 DietPi kernel: sdhci: Copyright(c) Pierre Ossman
Jan 18 22:24:47 DietPi kernel: Synopsys Designware Multimedia Card Interface Driver
Jan 18 22:24:47 DietPi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Jan 18 22:24:47 DietPi kernel: dwmmc_rockchip fe310000.mmc: IDMAC supports 32-bit address mode.
Jan 18 22:24:47 DietPi kernel: dwmmc_rockchip fe310000.mmc: Using internal DMA controller.
Jan 18 22:24:47 DietPi kernel: dwmmc_rockchip fe310000.mmc: Version ID is 270a
Jan 18 22:24:47 DietPi kernel: dwmmc_rockchip fe310000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
Jan 18 22:24:47 DietPi kernel: dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
Jan 18 22:24:47 DietPi kernel: dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
Jan 18 22:24:47 DietPi kernel: dwmmc_rockchip fe320000.mmc: Version ID is 270a
Jan 18 22:24:47 DietPi kernel: dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 37,32 bit host data width,256 deep fifo
Jan 18 22:24:47 DietPi kernel: dwmmc_rockchip fe310000.mmc: allocated mmc-pwrseq
Jan 18 22:24:47 DietPi kernel: mmc_host mmc0: card is non-removable.
Jan 18 22:24:47 DietPi kernel: mmc2: CQHCI version 5.10
Jan 18 22:24:47 DietPi kernel: ledtrig-cpu: registered to indicate activity on CPUs
Jan 18 22:24:47 DietPi kernel: hid: raw HID events driver (C) Jiri Kosina
Jan 18 22:24:47 DietPi kernel: usbcore: registered new interface driver usbhid
Jan 18 22:24:47 DietPi kernel: usbhid: USB HID core driver
Jan 18 22:24:47 DietPi kernel: rockchip-saradc ff100000.saradc: failed to get regulator, -517
Jan 18 22:24:47 DietPi kernel: drop_monitor: Initializing network drop monitor service
Jan 18 22:24:47 DietPi kernel: mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Jan 18 22:24:47 DietPi kernel: NET: Registered protocol family 10
Jan 18 22:24:47 DietPi kernel: mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
Jan 18 22:24:47 DietPi kernel: mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
Jan 18 22:24:47 DietPi kernel: Segment Routing with IPv6
Jan 18 22:24:47 DietPi kernel: NET: Registered protocol family 17
Jan 18 22:24:47 DietPi kernel: 8021q: 802.1Q VLAN Support v1.8
Jan 18 22:24:47 DietPi kernel: Key type dns_resolver registered
Jan 18 22:24:47 DietPi kernel: registered taskstats version 1
Jan 18 22:24:47 DietPi kernel: Loading compiled-in X.509 certificates
Jan 18 22:24:47 DietPi kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 3795b2e16b9620035634919321440b15f322c25d'
Jan 18 22:24:47 DietPi kernel: zswap: loaded using pool zstd/z3fold
Jan 18 22:24:47 DietPi kernel: Key type ._fscrypt registered
Jan 18 22:24:47 DietPi kernel: Key type .fscrypt registered
Jan 18 22:24:47 DietPi kernel: Key type fscrypt-provisioning registered
Jan 18 22:24:47 DietPi kernel: Btrfs loaded, crc32c=crc32c-generic
Jan 18 22:24:47 DietPi kernel: Key type encrypted registered
Jan 18 22:24:47 DietPi kernel: AppArmor: AppArmor sha1 policy hashing enabled
Jan 18 22:24:47 DietPi kernel: mmc2: new HS200 MMC card at address 0001
Jan 18 22:24:47 DietPi kernel: mmcblk2: mmc2:0001 M8B16G 14.5 GiB
Jan 18 22:24:47 DietPi kernel: mmcblk2boot0: mmc2:0001 M8B16G partition 1 4.00 MiB
Jan 18 22:24:47 DietPi kernel: mmcblk2boot1: mmc2:0001 M8B16G partition 2 4.00 MiB
Jan 18 22:24:47 DietPi kernel: mmcblk2rpmb: mmc2:0001 M8B16G partition 3 4.00 MiB, chardev (243:0)
Jan 18 22:24:47 DietPi kernel: mmcblk2: p1
Jan 18 22:24:47 DietPi kernel: mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
Jan 18 22:24:47 DietPi kernel: vcc3v3_sys: supplied by vcc5v0_sys
Jan 18 22:24:47 DietPi kernel: vcc5v0_host: supplied by vcc5v0_usb
Jan 18 22:24:47 DietPi kernel: vcc5v0_typec: supplied by vcc5v0_usb
Jan 18 22:24:47 DietPi kernel: mmc_host mmc0: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.1.auto: irq 78, io mem 0xfe800000
Part 2/2
Jan 18 22:24:47 DietPi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Jan 18 22:24:47 DietPi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 22:24:47 DietPi kernel: usb usb1: Product: xHCI Host Controller
Jan 18 22:24:47 DietPi kernel: usb usb1: Manufacturer: Linux 5.10.63-rockchip64 xhci-hcd
Jan 18 22:24:47 DietPi kernel: usb usb1: SerialNumber: xhci-hcd.1.auto
Jan 18 22:24:47 DietPi kernel: hub 1-0:1.0: USB hub found
Jan 18 22:24:47 DietPi kernel: hub 1-0:1.0: 1 port detected
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
Jan 18 22:24:47 DietPi kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Jan 18 22:24:47 DietPi kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
Jan 18 22:24:47 DietPi kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 22:24:47 DietPi kernel: usb usb2: Product: xHCI Host Controller
Jan 18 22:24:47 DietPi kernel: usb usb2: Manufacturer: Linux 5.10.63-rockchip64 xhci-hcd
Jan 18 22:24:47 DietPi kernel: usb usb2: SerialNumber: xhci-hcd.1.auto
Jan 18 22:24:47 DietPi kernel: hub 2-0:1.0: USB hub found
Jan 18 22:24:47 DietPi kernel: hub 2-0:1.0: 1 port detected
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 3
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.2.auto: irq 79, io mem 0xfe900000
Jan 18 22:24:47 DietPi kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Jan 18 22:24:47 DietPi kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 22:24:47 DietPi kernel: usb usb3: Product: xHCI Host Controller
Jan 18 22:24:47 DietPi kernel: usb usb3: Manufacturer: Linux 5.10.63-rockchip64 xhci-hcd
Jan 18 22:24:47 DietPi kernel: usb usb3: SerialNumber: xhci-hcd.2.auto
Jan 18 22:24:47 DietPi kernel: hub 3-0:1.0: USB hub found
Jan 18 22:24:47 DietPi kernel: hub 3-0:1.0: 1 port detected
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 4
Jan 18 22:24:47 DietPi kernel: xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
Jan 18 22:24:47 DietPi kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Jan 18 22:24:47 DietPi kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
Jan 18 22:24:47 DietPi kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 22:24:47 DietPi kernel: usb usb4: Product: xHCI Host Controller
Jan 18 22:24:47 DietPi kernel: usb usb4: Manufacturer: Linux 5.10.63-rockchip64 xhci-hcd
Jan 18 22:24:47 DietPi kernel: usb usb4: SerialNumber: xhci-hcd.2.auto
Jan 18 22:24:47 DietPi kernel: hub 4-0:1.0: USB hub found
Jan 18 22:24:47 DietPi kernel: hub 4-0:1.0: 1 port detected
Jan 18 22:24:47 DietPi kernel: ehci-platform fe380000.usb: EHCI Host Controller
Jan 18 22:24:47 DietPi kernel: ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
Jan 18 22:24:47 DietPi kernel: ehci-platform fe380000.usb: irq 39, io mem 0xfe380000
Jan 18 22:24:47 DietPi kernel: ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
Jan 18 22:24:47 DietPi kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Jan 18 22:24:47 DietPi kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 22:24:47 DietPi kernel: usb usb5: Product: EHCI Host Controller
Jan 18 22:24:47 DietPi kernel: usb usb5: Manufacturer: Linux 5.10.63-rockchip64 ehci_hcd
Jan 18 22:24:47 DietPi kernel: usb usb5: SerialNumber: fe380000.usb
Jan 18 22:24:47 DietPi kernel: hub 5-0:1.0: USB hub found
Jan 18 22:24:47 DietPi kernel: hub 5-0:1.0: 1 port detected
Jan 18 22:24:47 DietPi kernel: ehci-platform fe3c0000.usb: EHCI Host Controller
Jan 18 22:24:47 DietPi kernel: ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 6
Jan 18 22:24:47 DietPi kernel: ehci-platform fe3c0000.usb: irq 41, io mem 0xfe3c0000
Jan 18 22:24:47 DietPi kernel: ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
Jan 18 22:24:47 DietPi kernel: usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Jan 18 22:24:47 DietPi kernel: usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 22:24:47 DietPi kernel: usb usb6: Product: EHCI Host Controller
Jan 18 22:24:47 DietPi kernel: usb usb6: Manufacturer: Linux 5.10.63-rockchip64 ehci_hcd
Jan 18 22:24:47 DietPi kernel: usb usb6: SerialNumber: fe3c0000.usb
Jan 18 22:24:47 DietPi kernel: hub 6-0:1.0: USB hub found
Jan 18 22:24:47 DietPi kernel: hub 6-0:1.0: 1 port detected
Jan 18 22:24:47 DietPi kernel: ohci-platform fe3a0000.usb: Generic Platform OHCI controller
Jan 18 22:24:47 DietPi kernel: ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 7
Jan 18 22:24:47 DietPi kernel: ohci-platform fe3a0000.usb: irq 40, io mem 0xfe3a0000
Jan 18 22:24:47 DietPi kernel: usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
Jan 18 22:24:47 DietPi kernel: usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 22:24:47 DietPi kernel: usb usb7: Product: Generic Platform OHCI controller
Jan 18 22:24:47 DietPi kernel: usb usb7: Manufacturer: Linux 5.10.63-rockchip64 ohci_hcd
Jan 18 22:24:47 DietPi kernel: usb usb7: SerialNumber: fe3a0000.usb
Jan 18 22:24:47 DietPi kernel: hub 7-0:1.0: USB hub found
Jan 18 22:24:47 DietPi kernel: hub 7-0:1.0: 1 port detected
Jan 18 22:24:47 DietPi kernel: ohci-platform fe3e0000.usb: Generic Platform OHCI controller
Jan 18 22:24:47 DietPi kernel: ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 8
Jan 18 22:24:47 DietPi kernel: ohci-platform fe3e0000.usb: irq 42, io mem 0xfe3e0000
Jan 18 22:24:47 DietPi kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jan 18 22:24:47 DietPi kernel: ata1.00: ATA-9: WDC WD30EFRX-68EUZN0, 82.00A82, max UDMA/133
Jan 18 22:24:47 DietPi kernel: ata1.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 32), AA
Jan 18 22:24:47 DietPi kernel: ata1.00: configured for UDMA/133
Jan 18 22:24:47 DietPi kernel: scsi 0:0:0:0: Direct-Access ATA WDC WD30EFRX-68E 0A82 PQ: 0 ANSI: 5
Jan 18 22:24:47 DietPi kernel: sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
Jan 18 22:24:47 DietPi kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Jan 18 22:24:47 DietPi kernel: sd 0:0:0:0: [sda] Write Protect is off
Jan 18 22:24:47 DietPi kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Jan 18 22:24:47 DietPi kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jan 18 22:24:47 DietPi kernel: usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
Jan 18 22:24:47 DietPi kernel: usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 18 22:24:47 DietPi kernel: usb usb8: Product: Generic Platform OHCI controller
Jan 18 22:24:47 DietPi kernel: usb usb8: Manufacturer: Linux 5.10.63-rockchip64 ohci_hcd
Jan 18 22:24:47 DietPi kernel: usb usb8: SerialNumber: fe3e0000.usb
Jan 18 22:24:47 DietPi kernel: hub 8-0:1.0: USB hub found
Jan 18 22:24:47 DietPi kernel: hub 8-0:1.0: 1 port detected
Jan 18 22:24:47 DietPi kernel: vcc3v3_s3: supplied by vcc3v3_sys
Jan 18 22:24:47 DietPi kernel: vcc3v3_s0: supplied by vcc3v3_sys
Jan 18 22:24:47 DietPi kernel: vcc1v8_s3: supplied by vcc_1v8
Jan 18 22:24:47 DietPi kernel: vcc3v0_sd: supplied by vcc3v3_sys
Jan 18 22:24:47 DietPi kernel: debugfs: Directory 'power-domain' with parent 'pm_genpd' already present!
Jan 18 22:24:47 DietPi kernel: dwmmc_rockchip fe320000.mmc: Got CD GPIO
Jan 18 22:24:47 DietPi kernel: input: gpio-keys as /devices/platform/gpio-keys/input/input0
Jan 18 22:24:47 DietPi kernel: of_cfs_init
Jan 18 22:24:47 DietPi kernel: of_cfs_init: OK
Jan 18 22:24:47 DietPi kernel: mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
Jan 18 22:24:47 DietPi kernel: ata2: SATA link down (SStatus 0 SControl 300)
Jan 18 22:24:47 DietPi kernel: usb 8-1: new low-speed USB device number 2 using ohci-platform
Jan 18 22:24:47 DietPi kernel: usb 8-1: New USB device found, idVendor=045e, idProduct=0750, bcdDevice= 1.10
Jan 18 22:24:47 DietPi kernel: usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jan 18 22:24:47 DietPi kernel: usb 8-1: Product: Wired Keyboard 600
Jan 18 22:24:47 DietPi kernel: usb 8-1: Manufacturer: Microsoft
Jan 18 22:24:47 DietPi kernel: sda: sda1
Jan 18 22:24:47 DietPi kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jan 18 22:24:47 DietPi kernel: Freeing unused kernel memory: 4352K
Jan 18 22:24:47 DietPi kernel: Run /init as init process
Jan 18 22:24:47 DietPi kernel: with arguments:
Jan 18 22:24:47 DietPi kernel: /init
Jan 18 22:24:47 DietPi kernel: with environment:
Jan 18 22:24:47 DietPi kernel: HOME=/
Jan 18 22:24:47 DietPi kernel: TERM=linux
Jan 18 22:24:47 DietPi kernel: ubootpart=0db3c612-01
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: clock input from PHY
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: init for RGMII
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: DWMAC1000
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: COE Type 2
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: Normal descriptors
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
Jan 18 22:24:47 DietPi kernel: rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
Jan 18 22:24:47 DietPi kernel: rockchip-vop ff8f0000.vop: Adding to iommu group 2
Jan 18 22:24:47 DietPi kernel: rockchip-vop ff900000.vop: Adding to iommu group 3
Jan 18 22:24:47 DietPi kernel: input: Microsoft Wired Keyboard 600 as /devices/platform/fe3e0000.usb/usb8/8-1/8-1:1.0/0003:045E:0750.0001/input/input1
Jan 18 22:24:47 DietPi kernel: rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
Jan 18 22:24:47 DietPi kernel: [drm] unsupported AFBC format[3231564e]
Jan 18 22:24:47 DietPi kernel: rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
Jan 18 22:24:47 DietPi kernel: dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
Jan 18 22:24:47 DietPi kernel: rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
Jan 18 22:24:47 DietPi kernel: rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
Jan 18 22:24:47 DietPi kernel: [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
Jan 18 22:24:47 DietPi kernel: microsoft 0003:045E:0750.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Wired Keyboard 600] on usb-fe3e0000.usb-1/input0
Jan 18 22:24:47 DietPi kernel: input: Microsoft Wired Keyboard 600 as /devices/platform/fe3e0000.usb/usb8/8-1/8-1:1.1/0003:045E:0750.0002/input/input2
Jan 18 22:24:47 DietPi kernel: libphy: stmmac: probed
Jan 18 22:24:47 DietPi kernel: RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
Jan 18 22:24:47 DietPi kernel: RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
Jan 18 22:24:47 DietPi kernel: microsoft 0003:045E:0750.0002: input,hidraw1: USB HID v1.11 Device [Microsoft Wired Keyboard 600] on usb-fe3e0000.usb-1/input1
Jan 18 22:24:47 DietPi kernel: EXT4-fs (mmcblk2p1): mounted filesystem with writeback data mode. Opts: (null)
Jan 18 22:24:47 DietPi systemd[1]: Inserted module 'autofs4'
Jan 18 22:24:47 DietPi systemd[1]: systemd 247.3-6 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
Jan 18 22:24:47 DietPi systemd[1]: Detected architecture arm64.
Jan 18 22:24:47 DietPi systemd[1]: Set hostname to <DietPi>.
Jan 18 22:24:47 DietPi kernel: dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
Jan 18 22:24:47 DietPi systemd[1]: Configuration file /usr/local/lib/luarocks/rocks/ats/master-0/ats.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
Jan 18 22:24:47 DietPi systemd[1]: Queued start job for default target Graphical Interface.
Jan 18 22:24:47 DietPi kernel: random: systemd: uninitialized urandom read (16 bytes read)
Jan 18 22:24:47 DietPi systemd[1]: Created slice system-getty.slice.
Jan 18 22:24:47 DietPi systemd[1]: Created slice system-modprobe.slice.
Jan 18 22:24:47 DietPi systemd[1]: Created slice system-serial\x2dgetty.slice.
Jan 18 22:24:47 DietPi systemd[1]: Created slice User and Session Slice.
Jan 18 22:24:47 DietPi systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jan 18 22:24:47 DietPi systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Jan 18 22:24:47 DietPi systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Jan 18 22:24:47 DietPi systemd[1]: Reached target Local Encrypted Volumes.
Jan 18 22:24:47 DietPi systemd[1]: Reached target Paths.
Jan 18 22:24:47 DietPi systemd[1]: Reached target Remote File Systems.
Jan 18 22:24:47 DietPi systemd[1]: Reached target Slices.
Jan 18 22:24:47 DietPi systemd[1]: Reached target Swap.
Jan 18 22:24:47 DietPi systemd[1]: Listening on Syslog Socket.
Jan 18 22:24:47 DietPi systemd[1]: Listening on fsck to fsckd communication Socket.
Jan 18 22:24:47 DietPi systemd[1]: Listening on initctl Compatibility Named Pipe.
Jan 18 22:24:47 DietPi systemd[1]: Listening on Journal Audit Socket.
Jan 18 22:24:47 DietPi systemd[1]: Listening on Journal Socket (/dev/log).
Jan 18 22:24:47 DietPi systemd[1]: Listening on Journal Socket.
Jan 18 22:24:47 DietPi systemd[1]: Listening on udev Control Socket.
Jan 18 22:24:47 DietPi systemd[1]: Listening on udev Kernel Socket.
Jan 18 22:24:47 DietPi systemd[1]: Mounting Huge Pages File System...
Jan 18 22:24:47 DietPi systemd[1]: Mounting POSIX Message Queue File System...
Jan 18 22:24:47 DietPi systemd[1]: Mounting Kernel Debug File System...
Jan 18 22:24:47 DietPi systemd[1]: Mounting Kernel Trace File System...
Jan 18 22:24:47 DietPi systemd[1]: Starting Restore / save the current clock...
Jan 18 22:24:47 DietPi systemd[1]: Starting Set the console keyboard layout...
Jan 18 22:24:47 DietPi systemd[1]: Starting Create list of static device nodes for the current kernel...
Jan 18 22:24:47 DietPi systemd[1]: Starting Load Kernel Module configfs...
Jan 18 22:24:47 DietPi systemd[1]: Starting Load Kernel Module drm...
Jan 18 22:24:47 DietPi systemd[1]: Starting Load Kernel Module fuse...
Jan 18 22:24:47 DietPi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Jan 18 22:24:47 DietPi systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Jan 18 22:24:47 DietPi systemd[1]: Starting Journal Service...
Jan 18 22:24:47 DietPi systemd[1]: Starting Load Kernel Modules...
Jan 18 22:24:47 DietPi systemd[1]: Starting Remount Root and Kernel File Systems...
Jan 18 22:24:47 DietPi systemd[1]: Starting Coldplug All udev Devices...
Jan 18 22:24:47 DietPi systemd[1]: Mounted Huge Pages File System.
Jan 18 22:24:47 DietPi systemd[1]: Mounted POSIX Message Queue File System.
Jan 18 22:24:47 DietPi systemd[1]: Mounted Kernel Debug File System.
Jan 18 22:24:47 DietPi systemd[1]: Mounted Kernel Trace File System.
Jan 18 22:24:47 DietPi systemd[1]: Finished Restore / save the current clock.
Jan 18 22:24:47 DietPi systemd[1]: Finished Create list of static device nodes for the current kernel.
Jan 18 22:24:47 DietPi systemd[1]: modprobe@configfs.service: Succeeded.
Jan 18 22:24:47 DietPi systemd[1]: Finished Load Kernel Module configfs.
Jan 18 22:24:47 DietPi systemd[1]: modprobe@drm.service: Succeeded.
Jan 18 22:24:47 DietPi systemd[1]: Finished Load Kernel Module drm.
Jan 18 22:24:47 DietPi systemd[1]: modprobe@fuse.service: Succeeded.
Jan 18 22:24:47 DietPi systemd[1]: Finished Load Kernel Module fuse.
Jan 18 22:24:47 DietPi systemd[1]: Mounting FUSE Control File System...
Jan 18 22:24:47 DietPi systemd[1]: Mounting Kernel Configuration File System...
Jan 18 22:24:47 DietPi systemd[1]: Finished Load Kernel Modules.
Jan 18 22:24:47 DietPi systemd[1]: Starting Apply Kernel Variables...
Jan 18 22:24:47 DietPi kernel: EXT4-fs (mmcblk2p1): re-mounted. Opts: (null)
Jan 18 22:24:47 DietPi systemd[1]: Finished Remount Root and Kernel File Systems.
Jan 18 22:24:47 DietPi systemd[1]: Mounted FUSE Control File System.
Jan 18 22:24:47 DietPi systemd[1]: Mounted Kernel Configuration File System.
Jan 18 22:24:47 DietPi systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jan 18 22:24:47 DietPi systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
Jan 18 22:24:47 DietPi systemd[1]: Starting Load/Save Random Seed...
Jan 18 22:24:47 DietPi systemd[1]: Starting Create System Users...
Jan 18 22:24:47 DietPi systemd[1]: Finished Apply Kernel Variables.
Jan 18 22:24:47 DietPi systemd[1]: Finished Create System Users.
Jan 18 22:24:47 DietPi systemd[1]: Starting Create Static Device Nodes in /dev...
Jan 18 22:24:47 DietPi systemd[1]: Finished Create Static Device Nodes in /dev.
Jan 18 22:24:47 DietPi systemd[1]: Starting Rule-based Manager for Device Events and Files...
Jan 18 22:24:47 DietPi systemd[1]: Finished Set the console keyboard layout.
Jan 18 22:24:47 DietPi systemd[1]: Reached target Local File Systems (Pre).
Jan 18 22:24:47 DietPi systemd[1]: Set up automount mnt-81ee498c\x2d61b0\x2d46fd\x2da3e6\x2d519ba18a9d4a.automount.
Jan 18 22:24:47 DietPi systemd[1]: Mounting /tmp...
Jan 18 22:24:47 DietPi systemd[1]: Mounted /tmp.
Jan 18 22:24:47 DietPi systemd[1]: Reached target Local File Systems.
Jan 18 22:24:47 DietPi systemd[1]: Starting Set console font and keymap...
Jan 18 22:24:47 DietPi systemd[1]: Finished Set console font and keymap.
Jan 18 22:24:47 DietPi systemd[1]: Started Rule-based Manager for Device Events and Files.
Jan 18 22:24:47 DietPi systemd-journald[395]: Journal started
Jan 18 22:24:47 DietPi systemd-journald[395]: Runtime Journal (/run/log/journal/cef4e30325d34162b67bb0b821e538f5) is 4.8M, max 38.6M, 33.8M free.
Jan 18 22:24:46 DietPi systemd-random-seed[415]: Kernel entropy pool is not initialized yet, waiting until it is.
Jan 18 22:24:47 DietPi systemd[1]: Started Journal Service.
Jan 18 22:24:47 DietPi systemd-udevd[419]: Network interface NamePolicy= disabled on kernel command line, ignoring.
Jan 18 22:24:47 DietPi fake-hwclock[387]: Current system time: 2022-01-18 21:24:46
Jan 18 22:24:47 DietPi fake-hwclock[387]: fake-hwclock saved clock information is in the past: 2022-01-18 21:24:21
Jan 18 22:24:47 DietPi fake-hwclock[387]: To set system time to this saved clock anyway, use "force"
Jan 18 22:24:47 DietPi systemd[1]: Starting Flush Journal to Persistent Storage...
Jan 18 22:24:47 DietPi systemd[1]: Finished Flush Journal to Persistent Storage.
Jan 18 22:24:47 DietPi systemd[1]: Starting Create Volatile Files and Directories...
Jan 18 22:24:47 DietPi systemd[1]: Finished Create Volatile Files and Directories.
Jan 18 22:24:47 DietPi systemd[1]: Starting Network Time Synchronization...
Jan 18 22:24:47 DietPi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Jan 18 22:24:47 DietPi systemd[1]: Finished Coldplug All udev Devices.
Jan 18 22:24:47 DietPi systemd[1]: Starting Helper to synchronize boot up for ifupdown...
Jan 18 22:24:47 DietPi systemd[1]: Finished Helper to synchronize boot up for ifupdown.
Jan 18 22:24:47 DietPi systemd[1]: Finished Update UTMP about System Boot/Shutdown.
Jan 18 22:24:47 DietPi systemd-udevd[428]: Using default interface naming scheme 'v247'.
Jan 18 22:24:47 DietPi systemd[1]: Found device /dev/ttyS2.
Jan 18 22:24:47 DietPi systemd[1]: Started Network Time Synchronization.
Jan 18 22:24:47 DietPi kernel: mc: Linux media interface: v0.10
Jan 18 22:24:47 DietPi systemd[1]: Reached target System Initialization.
Jan 18 22:24:47 DietPi systemd[1]: Started Daily Cleanup of Temporary Directories.
Jan 18 22:24:47 DietPi systemd[1]: Reached target System Time Set.
Jan 18 22:24:47 DietPi systemd[1]: Reached target System Time Synchronized.
Jan 18 22:24:47 DietPi systemd[1]: Started Run certbot twice daily.
Jan 18 22:24:47 DietPi systemd[1]: Started Discard unused blocks once a week.
Jan 18 22:24:47 DietPi systemd[1]: Started Daily rotation of log files.
Jan 18 22:24:47 DietPi systemd[1]: Started Clean PHP session files every 30 mins.
Jan 18 22:24:47 DietPi systemd[1]: Reached target Timers.
Jan 18 22:24:47 DietPi systemd[1]: Listening on D-Bus System Message Bus Socket.
Jan 18 22:24:47 DietPi kernel: videodev: Linux video capture interface: v2.00
Jan 18 22:24:47 DietPi systemd[1]: Reached target Sockets.
Jan 18 22:24:47 DietPi systemd[1]: Reached target Basic System.
Jan 18 22:24:47 DietPi systemd[1]: Started ATS - Active Thermal Service.
Jan 18 22:24:47 DietPi kernel: typec_fusb302 4-0022: No cable types defined, using default cables
Jan 18 22:24:47 DietPi kernel: OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
Jan 18 22:24:47 DietPi systemd[1]: Started D-Bus System Message Bus.
Jan 18 22:24:47 DietPi kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan 18 22:24:47 DietPi systemd[1]: Starting DietPi-PreBoot...
Jan 18 22:24:47 DietPi systemd[1]: Starting LSB: Lightweight SSH server...
Jan 18 22:24:47 DietPi systemd[1]: Started Start entropy gathering daemon (rngd).
Jan 18 22:24:47 DietPi systemd[1]: Starting System Logging Service...
Jan 18 22:24:47 DietPi rngd[474]: Unable to open file: /dev/tpm0
Jan 18 22:24:47 DietPi rngd[474]: can't open any entropy source
Jan 18 22:24:47 DietPi rngd[474]: Maybe RNG device modules are not loaded
Jan 18 22:24:47 DietPi systemd[1]: Starting User Login Management...
Jan 18 22:24:47 DietPi systemd[1]: rngd.service: Main process exited, code=exited, status=1/FAILURE
Jan 18 22:24:47 DietPi systemd[1]: rngd.service: Failed with result 'exit-code'.
Jan 18 22:24:47 DietPi kernel: rockchip-rga ff680000.rga: HW Version: 0x03.02
Jan 18 22:24:47 DietPi kernel: rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
Jan 18 22:24:47 DietPi kernel: panfrost ff9a0000.gpu: clock rate = 500000000
Jan 18 22:24:47 DietPi kernel: panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
Jan 18 22:24:47 DietPi kernel: panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
Jan 18 22:24:47 DietPi kernel: panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
Jan 18 22:24:47 DietPi kernel: panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
Jan 18 22:24:47 DietPi kernel: [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1
Jan 18 22:24:47 DietPi kernel: Registered IR keymap rc-cec
Jan 18 22:24:47 DietPi kernel: rc rc0: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0
Jan 18 22:24:47 DietPi kernel: input: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0/input3
Jan 18 22:24:47 DietPi kernel: rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
Jan 18 22:24:47 DietPi kernel: rkvdec ff660000.video-codec: Adding to iommu group 1
Jan 18 22:24:47 DietPi systemd-logind[479]: New seat seat0.
Jan 18 22:24:48 DietPi kernel: hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
Jan 18 22:24:48 DietPi kernel: hantro-vpu ff650000.video-codec: Adding to iommu group 0
Jan 18 22:24:48 DietPi kernel: hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2
Jan 18 22:24:48 DietPi kernel: hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3
Jan 18 22:24:48 DietPi kernel: es8316 1-0011: Failed to get IRQ 0: -22
Jan 18 22:24:48 DietPi systemd[1]: Condition check resulted in /sys/subsystem/net/devices/eth0 being skipped.
Jan 18 22:24:48 DietPi rsyslogd[475]: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd. [v8.2102.0]
Jan 18 22:24:48 DietPi systemd[1]: Started System Logging Service.
Jan 18 22:24:48 DietPi rsyslogd[475]: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="475" x-info="https://www.rsyslog.com"] start
Jan 18 22:24:48 DietPi systemd-logind[479]: Watching system buttons on /dev/input/event1 (Microsoft Wired Keyboard 600)
Jan 18 22:24:48 DietPi systemd-logind[479]: Watching system buttons on /dev/input/event2 (Microsoft Wired Keyboard 600)
Jan 18 22:24:48 DietPi systemd-logind[479]: Watching system buttons on /dev/input/event0 (gpio-keys)
Jan 18 22:24:48 DietPi dropbear[496]: Failed loading /etc/dropbear/dropbear_dss_host_key
Jan 18 22:24:48 DietPi dropbear[537]: Running in background
Jan 18 22:24:48 DietPi dropbear[473]: Starting Dropbear SSH server: dropbear.
Jan 18 22:24:48 DietPi systemd[1]: Started LSB: Lightweight SSH server.
Jan 18 22:24:48 DietPi systemd-logind[479]: Watching system buttons on /dev/input/event3 (dw_hdmi)
Jan 18 22:24:48 DietPi systemd[1]: Started User Login Management.
Jan 18 22:24:48 DietPi systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
Jan 18 22:24:48 DietPi DietPi-PreBoot[528]: DietPi-CPU_set
Jan 18 22:24:48 DietPi DietPi-PreBoot[528]: βββββββββββββββββββββββββββββββββββββββββββββββββββββ
Jan 18 22:24:48 DietPi DietPi-PreBoot[528]: Mode: Applying CPU governor settings: schedutil
Jan 18 22:24:48 DietPi systemd-udevd[440]: controlC0: Process '/usr/sbin/alsactl -E HOME=/run/alsa -E XDG_RUNTIME_DIR=/run/alsa/runtime restore 0' failed with exit code 99.
Jan 18 22:24:48 DietPi systemd[1]: Starting Save/Restore Sound Card State...
Jan 18 22:24:48 DietPi systemd[1]: Finished Save/Restore Sound Card State.
Jan 18 22:24:48 DietPi systemd[1]: Reached target Sound Card.
Jan 18 22:24:48 DietPi DietPi-PreBoot[528]: [ INFO ] DietPi-CPU_set | Setting CPU frequency limits : Max = Disabled MHz | Min = Disabled MHz
Jan 18 22:24:48 DietPi DietPi-PreBoot[528]: [ OK ] DietPi-CPU_set | Applied CPU governor settings: schedutil
Jan 18 22:24:48 DietPi systemd[1]: Finished DietPi-PreBoot.
Jan 18 22:24:48 DietPi systemd[1]: Reached target Network (Pre).
Jan 18 22:24:48 DietPi systemd[1]: Starting ifup for eth0...
Jan 18 22:24:48 DietPi systemd[1]: Starting Raise network interfaces...
Jan 18 22:24:48 DietPi kernel: rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
Jan 18 22:24:48 DietPi kernel: rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
Jan 18 22:24:48 DietPi kernel: rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
Jan 18 22:24:48 DietPi kernel: rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
Jan 18 22:24:48 DietPi kernel: random: crng init done
Jan 18 22:24:48 DietPi kernel: random: 7 urandom warning(s) missed due to ratelimiting
Jan 18 22:24:48 DietPi systemd[1]: Finished Load/Save Random Seed.
Jan 18 22:24:48 DietPi systemd[1]: Condition check resulted in First Boot Complete being skipped.
Jan 18 22:24:48 DietPi systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jan 18 22:24:48 DietPi systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jan 18 22:24:48 DietPi systemd[1]: Finished ifup for eth0.
Jan 18 22:24:48 DietPi systemd[1]: Finished Raise network interfaces.
Jan 18 22:24:48 DietPi systemd[1]: Reached target Network.
Jan 18 22:24:48 DietPi systemd[1]: Reached target Network is Online.
Jan 18 22:24:48 DietPi systemd[1]: Started DietPi-PostBoot.
Jan 18 22:24:48 DietPi systemd[1]: Starting Fail2Ban Service...
Jan 18 22:24:48 DietPi systemd[1]: Starting Real time performance monitoring...
Jan 18 22:24:48 DietPi systemd[1]: Starting LSB: pihole-FTL daemon...
Jan 18 22:24:48 DietPi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Jan 18 22:24:48 DietPi systemd[1]: Starting Permit User Sessions...
Jan 18 22:24:48 DietPi systemd[1]: Starting Unbound DNS server...
Jan 18 22:24:48 DietPi systemd[1]: Started Fail2Ban Service.
Jan 18 22:24:48 DietPi systemd[1]: Finished Permit User Sessions.
Jan 18 22:24:48 DietPi systemd[1]: Started Getty on tty1.
Jan 18 22:24:48 DietPi pihole-FTL[668]: Not running
Jan 18 22:24:48 DietPi systemd[1]: Started Serial Getty on ttyS2.
Jan 18 22:24:48 DietPi systemd[1]: Reached target Login Prompts.
Jan 18 22:24:48 DietPi systemd[1]: Started Real time performance monitoring.
Jan 18 22:24:49 DietPi su[691]: (to pihole) root on none
Jan 18 22:24:49 DietPi su[691]: pam_unix(su:session): session opened for user pihole(uid=998) by (uid=0)
Jan 18 22:24:49 DietPi systemd[1]: Created slice User Slice of UID 998.
Jan 18 22:24:49 DietPi systemd[1]: Starting User Runtime Directory /run/user/998...
Jan 18 22:24:49 DietPi netdata[688]: CONFIG: cannot load cloud config '/var/lib/netdata/cloud.d/cloud.conf'. Running with internal defaults.
Jan 18 22:24:49 DietPi netdata[688]: 2022-01-18 22:24:49: netdata INFO : MAIN : CONFIG: cannot load cloud config '/var/lib/netdata/cloud.d/cloud.conf'. Running with internal defaults.
Jan 18 22:24:49 DietPi systemd[1]: Finished User Runtime Directory /run/user/998.
Jan 18 22:24:49 DietPi systemd[1]: Starting User Manager for UID 998...
Jan 18 22:24:49 DietPi unbound[695]: [695:0] info: start of service (unbound 1.13.1).
Jan 18 22:24:49 DietPi systemd[1]: Started Unbound DNS server.
Jan 18 22:24:49 DietPi systemd[1]: Reached target Host and Network Name Lookups.
Jan 18 22:24:49 DietPi systemd[1]: Condition check resulted in Unbound DNS server via resolvconf being skipped.
Jan 18 22:24:49 DietPi systemd[697]: pam_unix(systemd-user:session): session opened for user pihole(uid=998) by (uid=0)
Jan 18 22:24:49 DietPi systemd[720]: gpgconf: error running '/usr/lib/gnupg/scdaemon': probably not installed
Jan 18 22:24:49 DietPi fail2ban-server[672]: fail2ban.server [672]: INFO --------------------------------------------------
Jan 18 22:24:49 DietPi fail2ban-server[672]: fail2ban.server [672]: INFO Starting Fail2ban v0.11.2
Jan 18 22:24:49 DietPi fail2ban-server[672]: fail2ban.observer [672]: INFO Observer start...
Jan 18 22:24:49 DietPi systemd[697]: Queued start job for default target Main User Target.
Jan 18 22:24:49 DietPi systemd[697]: Created slice User Application Slice.
Jan 18 22:24:49 DietPi systemd[697]: Reached target Paths.
Jan 18 22:24:49 DietPi systemd[697]: Reached target Timers.
Jan 18 22:24:49 DietPi systemd[697]: Listening on GnuPG network certificate management daemon.
Jan 18 22:24:49 DietPi systemd[697]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 18 22:24:49 DietPi systemd[697]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jan 18 22:24:49 DietPi systemd[697]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jan 18 22:24:49 DietPi systemd[697]: Listening on GnuPG cryptographic agent and passphrase cache.
Jan 18 22:24:49 DietPi systemd[697]: Reached target Sockets.
Jan 18 22:24:49 DietPi systemd[697]: Reached target Basic System.
Jan 18 22:24:49 DietPi systemd[697]: Reached target Main User Target.
Jan 18 22:24:49 DietPi systemd[697]: Startup finished in 660ms.
Jan 18 22:24:49 DietPi systemd[1]: Started User Manager for UID 998.
Jan 18 22:24:49 DietPi fail2ban-server[672]: fail2ban.database [672]: INFO Connected to fail2ban persistent database '/var/lib/fail2ban/fail2ban.sqlite3'
Jan 18 22:24:49 DietPi systemd[1]: Started Session c1 of user pihole.
Jan 18 22:24:49 DietPi fail2ban-server[672]: fail2ban.jail [672]: INFO Creating new jail 'dropbear'
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.jail [672]: INFO Jail 'dropbear' uses systemd {}
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.jail [672]: INFO Initiated 'systemd' backend
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.filter [672]: INFO maxRetry: 3
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.filter [672]: INFO findtime: 600
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.actions [672]: INFO banTime: 600
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.jail [672]: INFO Creating new jail 'sshd'
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.jail [672]: INFO Jail 'sshd' uses systemd {}
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.filter [672]: INFO maxLines: 1
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.filtersystemd [672]: INFO [sshd] Added journal match for: '_SYSTEMD_UNIT=sshd.service + _COMM=sshd'
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.filtersystemd [672]: NOTICE Jail started without 'journalmatch' set. Jail regexs will be checked against all journal entries, which is not advised for performance reasons.
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.jail [672]: INFO Jail 'dropbear' started
Jan 18 22:24:50 DietPi fail2ban-server[672]: fail2ban.jail [672]: INFO Jail 'sshd' started
Jan 18 22:24:50 DietPi fail2ban-server[672]: Server ready
Jan 18 22:24:52 DietPi kernel: rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Jan 18 22:24:52 DietPi kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jan 18 22:24:53 DietPi login[676]: pam_unix(login:session): session opened for user root(uid=0) by LOGIN(uid=0)
Jan 18 22:24:53 DietPi systemd[1]: Created slice User Slice of UID 0.
Jan 18 22:24:53 DietPi systemd[1]: Starting User Runtime Directory /run/user/0...
Jan 18 22:24:53 DietPi systemd-logind[479]: New session 2 of user root.
Jan 18 22:24:53 DietPi systemd[1]: Finished User Runtime Directory /run/user/0.
Jan 18 22:24:53 DietPi systemd[1]: Starting User Manager for UID 0...
Jan 18 22:24:53 DietPi systemd[1363]: pam_unix(systemd-user:session): session opened for user root(uid=0) by (uid=0)
Jan 18 22:24:53 DietPi systemd[1]: Starting ProFTPD FTP Server...
Jan 18 22:24:53 DietPi proftpd[1371]: Checking syntax of configuration file
Jan 18 22:24:53 DietPi systemd[1376]: gpgconf: error running '/usr/lib/gnupg/scdaemon': probably not installed
Jan 18 22:24:54 DietPi systemd[1363]: Queued start job for default target Main User Target.
Jan 18 22:24:54 DietPi systemd[1363]: Created slice User Application Slice.
Jan 18 22:24:54 DietPi systemd[1363]: Reached target Paths.
Jan 18 22:24:54 DietPi systemd[1363]: Reached target Timers.
Jan 18 22:24:54 DietPi systemd[1363]: Listening on GnuPG network certificate management daemon.
Jan 18 22:24:54 DietPi systemd[1363]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 18 22:24:54 DietPi systemd[1363]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jan 18 22:24:54 DietPi systemd[1363]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jan 18 22:24:54 DietPi systemd[1363]: Listening on GnuPG cryptographic agent and passphrase cache.
Jan 18 22:24:54 DietPi systemd[1363]: Reached target Sockets.
Jan 18 22:24:54 DietPi systemd[1363]: Reached target Basic System.
Jan 18 22:24:54 DietPi systemd[1363]: Reached target Main User Target.
Jan 18 22:24:54 DietPi systemd[1363]: Startup finished in 331ms.
Jan 18 22:24:54 DietPi systemd[1]: Started User Manager for UID 0.
Jan 18 22:24:54 DietPi systemd[1]: Started Session 2 of user root.
Jan 18 22:24:54 DietPi login[1403]: ROOT LOGIN on '/dev/tty1'
Jan 18 22:24:54 DietPi pihole-FTL[851]: FTL started!
Jan 18 22:24:54 DietPi su[691]: pam_unix(su:session): session closed for user pihole
Jan 18 22:24:54 DietPi systemd[1]: Started LSB: pihole-FTL daemon.
Jan 18 22:24:54 DietPi systemd[1]: Reached target Multi-User System.
Jan 18 22:24:54 DietPi systemd[1]: Reached target Graphical Interface.
Jan 18 22:24:54 DietPi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jan 18 22:24:54 DietPi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Jan 18 22:24:54 DietPi systemd[1]: Finished Update UTMP about System Runlevel Changes.
Jan 18 22:24:54 DietPi systemd[1]: Started ProFTPD FTP Server.
Jan 18 22:24:54 DietPi systemd[1]: Startup finished in 11.290s (kernel) + 8.462s (userspace) = 19.753s.
Jan 18 22:24:54 DietPi systemd[1]: Starting Advanced key-value store...
Jan 18 22:24:54 DietPi redis-server[1441]: 1441:C 18 Jan 2022 22:24:54.703 # WARNING supervised by systemd - you MUST set appropriate values for TimeoutStartSec and TimeoutStopSec in your service unit.
Jan 18 22:24:54 DietPi redis-server[1441]: 1441:C 18 Jan 2022 22:24:54.703 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
Jan 18 22:24:54 DietPi redis-server[1441]: 1441:C 18 Jan 2022 22:24:54.704 # Redis version=6.0.16, bits=64, commit=00000000, modified=0, pid=1441, just started
Jan 18 22:24:54 DietPi redis-server[1441]: 1441:C 18 Jan 2022 22:24:54.704 # Configuration loaded
Jan 18 22:24:54 DietPi redis-server[1441]: WARNING supervised by systemd - you MUST set appropriate values for TimeoutStartSec and TimeoutStopSec in your service unit.
Jan 18 22:24:54 DietPi redis-server[1441]: oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
Jan 18 22:24:54 DietPi redis-server[1441]: Redis version=6.0.16, bits=64, commit=00000000, modified=0, pid=1441, just started
Jan 18 22:24:54 DietPi redis-server[1441]: Configuration loaded
Jan 18 22:24:54 DietPi redis-server[1441]: 1441:M 18 Jan 2022 22:24:54.715 # Server initialized
Jan 18 22:24:54 DietPi redis-server[1441]: 1441:M 18 Jan 2022 22:24:54.715 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
Jan 18 22:24:54 DietPi redis[1441]: Server initialized
Jan 18 22:24:54 DietPi redis[1441]: WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
Jan 18 22:24:54 DietPi systemd[1]: Started Advanced key-value store.
Jan 18 22:24:54 DietPi systemd[1]: Starting MariaDB 10.5.12 database server...
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] /usr/sbin/mariadbd (mysqld 10.5.12-MariaDB-0+deb11u1) starting as process 1507 ...
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: Uses event mutexes
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: Number of pools: 1
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: Using ARMv8 crc32 + pmull instructions
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] mariadbd: O_TMPFILE is not supported on /tmp (disabling future attempts)
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: Using Linux native AIO
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: Completed initialization of buffer pool
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: 128 rollback segments are active.
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: Creating shared tablespace for temporary tables
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: 10.5.12 started; log sequence number 325390474; transaction id 1813756
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] InnoDB: Loading buffer pool(s) from /mnt/dietpi_userdata/mysql/ib_buffer_pool
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] Plugin 'FEEDBACK' is disabled.
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] Server socket created on IP: '127.0.0.1'.
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] Reading of all Master_info entries succeeded
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] Added new Master_info '' to hash table
Jan 18 22:24:55 DietPi mariadbd[1507]: 2022-01-18 22:24:55 0 [Note] /usr/sbin/mariadbd: ready for connections.
Jan 18 22:24:55 DietPi mariadbd[1507]: Version: '10.5.12-MariaDB-0+deb11u1' socket: '/run/mysqld/mysqld.sock' port: 3306 Debian 11
Jan 18 22:24:56 DietPi systemd[1]: Started MariaDB 10.5.12 database server.
Jan 18 22:24:56 DietPi /etc/mysql/debian-start[1541]: Upgrading MySQL tables if necessary.
Jan 18 22:24:56 DietPi systemd[1]: Starting The PHP 7.4 FastCGI Process Manager...
Jan 18 22:24:56 DietPi mariadbd[1507]: 2022-01-18 22:24:56 0 [Note] InnoDB: Buffer pool(s) load completed at 220118 22:24:56
Jan 18 22:24:56 DietPi /etc/mysql/debian-start[1548]: Looking for 'mysql' as: /usr/bin/mysql
Jan 18 22:24:56 DietPi /etc/mysql/debian-start[1548]: Looking for 'mysqlcheck' as: /usr/bin/mysqlcheck
Jan 18 22:24:56 DietPi /etc/mysql/debian-start[1548]: This installation of MariaDB is already upgraded to 10.5.12-MariaDB, use --force if you still need to run mysql_upgrade
Jan 18 22:24:56 DietPi /etc/mysql/debian-start[1559]: Checking for insecure root accounts.
Jan 18 22:24:56 DietPi /etc/mysql/debian-start[1563]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
Jan 18 22:24:56 DietPi systemd[1]: Started The PHP 7.4 FastCGI Process Manager.
Jan 18 22:24:56 DietPi systemd[1]: Starting Lighttpd Daemon...
Jan 18 22:24:57 DietPi systemd[1]: Started Lighttpd Daemon.
Jan 18 22:24:57 DietPi systemd[1]: Starting NZBGet (DietPi)...
Jan 18 22:24:57 DietPi systemd[1]: Started NZBGet (DietPi).
Jan 18 22:24:57 DietPi systemd[1]: Started Regular background program processing daemon.
Jan 18 22:24:57 DietPi cron[1635]: (CRON) INFO (pidfile fd = 3)
Jan 18 22:24:57 DietPi cron[1635]: (CRON) INFO (Running @reboot jobs)
Jan 18 22:24:57 DietPi CRON[1638]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
Jan 18 22:24:57 DietPi CRON[1639]: (root) CMD (/usr/sbin/logrotate --state /var/lib/logrotate/pihole /etc/pihole/logrotate)
Jan 18 22:24:57 DietPi CRON[1637]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
Jan 18 22:24:57 DietPi CRON[1641]: (root) CMD ( PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote reboot)
Jan 18 22:24:58 DietPi CRON[1638]: pam_unix(cron:session): session closed for user root
Jan 18 22:25:01 DietPi CRON[1674]: pam_unix(cron:session): session opened for user www-data(uid=33) by (uid=0)
Jan 18 22:25:01 DietPi CRON[1675]: (www-data) CMD (php /var/www/nextcloud/cron.php)
Jan 18 22:25:04 DietPi CRON[1674]: pam_unix(cron:session): session closed for user www-data
Jan 18 22:25:17 DietPi systemd-timesyncd[454]: Initial synchronization to time server 217.79.179.106:123 (2.debian.pool.ntp.org).
Jan 18 22:25:17 DietPi systemd[1]: Stopping Network Time Synchronization...
Jan 18 22:25:17 DietPi systemd[1]: systemd-timesyncd.service: Succeeded.
Jan 18 22:25:17 DietPi systemd[1]: Stopped Network Time Synchronization.
Jan 18 22:25:27 DietPi CRON[1637]: pam_unix(cron:session): session closed for user root
Jan 18 22:25:55 DietPi dropbear[2449]: Child connection from 192.168.2.212:54654
Jan 18 22:26:02 DietPi dropbear[2449]: Password auth succeeded for 'root' from 192.168.2.212:54654
This may be the device, but ATS is starting afterwards.
However, to rule it out, please try the following:
mkdir -p /etc/systemd/system/ats.service.d
echo -e '[Unit]\nAfter=getty.target' > /etc/systemd/system/ats.service.d/start-later.conf
But also there is another interesting log:
This file is also shown by systemctl cat ats and Iβm wondering why/how systemd even tries to read files at that path, probably a symlink?
Can you check:
ls -l /etc/systemd/system/ats.service
ls -l /lib/systemd/system/ats.service
ls -l /usr/local/lib/luarocks/rocks/ats/master-0/ats.service
