Rock64 starting errors
  • DietPi version | G_DIETPI_VERSION_CORE=8
    G_DIETPI_VERSION_SUB=8
    G_DIETPI_VERSION_RC=1
  • Distro version | bullseye
  • Kernel version | Linux DietPi 5.15.52-rockchip64 #22.05.4 SMP PREEMPT Mon Jul 4 09:40:29 CEST 2022 aarch64 GNU/Linux
  • SBC model | `ROCK64 (aarch64)’
  • Power supply used | (5V 3A)
  • SD card used | (SanDisk ultra)
  • Software title | (Kernel)
  • Was the software title installed freshly or updated/migrated? No
  • Can this issue be replicated on a fresh installation of DietPi? Yes
  • Bug report ID | 05c3104e-04e9-4b62-a3a7-5ebb7487e342
  1. Hello again. As a new DietPi fan that I’ve been discover recently, I’ve installed the system on another device, this time a Rock64 2 Gb RAM. I have installed twice a fresh system according to the official procedures, and twice after going through the installation and update process, I get a message like this on startup. Should something be done about this?
  • Zero errors
[    3.334774] gpio-syscon ff100000.syscon:gpio: can't read the data register offset!
[    3.628208] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed
[    8.483422] usb 1-1: Failed to query (GET_INFO) UVC control 3 on unit 1: -32 (exp. 1).
 [    2.008888] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[    2.009129] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[    2.172126] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
[    2.512796] dw-apb-uart ff130000.serial: forbid DMA for kernel console
[    3.417185] rockchip-u3phy ff470000.usb3-phy: vbus_drv is not assigned
[    3.627587] rk_gmac-dwmac ff540000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[    8.529663] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[    8.541391] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[    9.227143] rk_gmac-dwmac ff540000.ethernet eth0: PTP not supported by HW
[  180.423142] rc rc0: two consecutive events of type space
Where do you see these messages? I don’t think that you need to worry about.
When the system starts. They have error status on dmesg.
@MichaIng
can you have a look pls.
When I uploaded Armbian for Rock64 I do not have these messages. It is only after switching to DietPi that they appear.
I guess I need to rebuild our ROCK64 image. Probably the boot config does not play so well with latest kernel anymore.
