DietPi version |
cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=10
G_DIETPI_VERSION_RC=2
G_GITOWNER=‘MichaIng’ -
Distro version |
bullseye -
Kernel version |
uname -a
Linux DietPi 5.15.74-rockchip64 #22.08.6 SMP PREEMPT Tue Oct 18 06:50:17 UTC 2022 aarch64 GNU/Linux -
SBC model |
echo $G_HW_MODEL_NAME
or (EG: RPi3)
ROCK64 (aarch64) -
5V 3A (from pine64 store) -
None -
List block Devides | lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mtdblock0 31:0 0 16M 0 disk
mmcblk1 179:0 0 14.7G 0 disk
└─mmcblk1p1 179:1 0 14.7G 0 part /
mmcblk1boot0 179:32 0 4M 1 disk
mmcblk1boot1 179:64 0 4M 1 disk
cec-utils - Was the software title installed freshly or updated/migrated?
fresh install - Can this issue be replicated on a fresh installation of DietPi?
← If you sent a “dietpi-bugreport”, please paste the ID here → - Bug report ID |
echo $G_HW_UUID
a34a9f18-079c-420e-b824-d11ef755007d
run | cec-client
Should show a list of hdmi connected devices
No device type given. Using ‘recording device’
CEC Parser created - libCEC version 6.0.2
no serial port given. trying autodetect:
path: /dev/cec0
com port: Linux
opening a connection to the CEC adapter…
DEBUG: [ 65] Broadcast (F): osd name set to 'Broadcast'
DEBUG: [ 65] CLinuxCECAdapterCommunication::Open - m_fd=3 bStartListening=1
DEBUG: [ 65] CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_G_PHYS_ADDR - addr=ffff
WARNING: [ 65] CLinuxCECAdapterCommunication::Open - physical address is invalid
DEBUG: [ 65] CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0
DEBUG: [ 65] CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=1
NOTICE: [ 66] connection opened
DEBUG: [ 66] CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=ffff
DEBUG: [ 66] << Broadcast (F) -> TV (0): POLL
TRAFFIC: [ 66] << f0
DEBUG: [ 66] processor thread started
DEBUG: [ 210] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=f0 opcode=ffffffff
TRAFFIC: [ 210] << f0
DEBUG: [ 358] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=f0 opcode=ffffffff
DEBUG: [ 358] >> POLL not sent
DEBUG: [ 358] TV (0): device status changed into 'not present'
DEBUG: [ 358] registering new CEC client - v6.0.2
DEBUG: [ 358] SetClientVersion - using client version '6.0.2'
NOTICE: [ 358] setting HDMI port to 1 on device TV (0)
DEBUG: [ 358] << Broadcast (F) -> TV (0): POLL
TRAFFIC: [ 358] << f0
DEBUG: [ 505] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=f0 opcode=ffffffff
TRAFFIC: [ 505] << f0
DEBUG: [ 653] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=f0 opcode=ffffffff
DEBUG: [ 653] >> POLL not sent
DEBUG: [ 653] SetConfiguration: double tap timeout = 200ms, repeat rate = 0ms, release delay = 500ms
DEBUG: [ 653] detecting logical address for type 'recording device'
DEBUG: [ 653] trying logical address 'Recorder 1'
DEBUG: [ 653] << Recorder 1 (1) -> Recorder 1 (1): POLL
TRAFFIC: [ 653] << 11
ERROR: [ 653] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT failed - tx_status=00 errno=64
DEBUG: [ 653] using logical address 'Recorder 1'
DEBUG: [ 653] Recorder 1 (1): device status changed into 'handled by libCEC'
DEBUG: [ 653] Recorder 1 (1): power status changed from 'unknown' to 'on'
DEBUG: [ 653] Recorder 1 (1): vendor = Pulse Eight (001582)
DEBUG: [ 653] Recorder 1 (1): CEC version 1.4
DEBUG: [ 653] AllocateLogicalAddresses - device '0', type 'recording device', LA '1'
DEBUG: [ 653] CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0
DEBUG: [ 653] CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=1
DEBUG: [ 653] Recorder 1 (1): osd name set to 'CECTester'
DEBUG: [ 653] Recorder 1 (1): menu language set to 'eng'
NOTICE: [ 653] setting HDMI port to 1 on device TV (0)
DEBUG: [ 653] << Recorder 1 (1) -> TV (0): POLL
TRAFFIC: [ 653] << 10
DEBUG: [ 653] CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=ffff
DEBUG: [ 795] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
TRAFFIC: [ 796] << 10
DEBUG: [ 943] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
DEBUG: [ 943] >> POLL not sent
DEBUG: [ 943] Recorder 1 (1): physical address changed from ffff to 1000
DEBUG: [ 943] << Recorder 1 (1) -> broadcast (F): physical address 1000
TRAFFIC: [ 943] << 1f:84:10:00:01
ERROR: [ 943] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT failed - tx_status=00 errno=64
DEBUG: [ 943] using device/input physical address 0000
NOTICE: [ 944] CEC client registered: libCEC version = 6.0.2, client version = 6.0.2, firmware version = 0, logical address(es) = Recorder 1 (1) , base device: TV (0), HDMI port number: 1, physical address: 1.0.0.0, compiled on Linux-4.19.0-14-arm64 ... , features: P8_USB, DRM, P8_detect, randr, Exynos, Linux, AOCEC
DEBUG: [ 944] << Recorder 1 (1) -> TV (0): OSD name 'CECTester'
DEBUG: [ 944] << Recorder 1 (1) -> TV (0): POLL
TRAFFIC: [ 944] << 10
DEBUG: [ 1091] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
TRAFFIC: [ 1091] << 10
DEBUG: [ 1238] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
DEBUG: [ 1238] >> POLL not sent
DEBUG: [ 1238] not sending command 'set osd name': destination device 'TV' marked as not present
DEBUG: [ 1238] << requesting power status of 'TV' (0)
DEBUG: [ 1238] << Recorder 1 (1) -> TV (0): POLL
TRAFFIC: [ 1239] << 10
DEBUG: [ 1386] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
TRAFFIC: [ 1386] << 10
waiting for input
DEBUG: [ 1533] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
DEBUG: [ 1533] >> POLL not sent
DEBUG: [ 1533] not sending command 'give device power status': destination device 'TV' marked as not present
DEBUG: [ 2666] changing physical address to FFFF
DEBUG: [ 2666] SetDevicePhysicalAddress - not setting invalid physical address ffff
I am just a end-user following instructions from: hdmi-cec using cec-client
Some additional information:
(reconnect to the CEC adapter)
r
DEBUG: [ 5922750] << requesting active source
TRAFFIC: [ 5922751] << 1f:85
ERROR: [ 5922751] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT failed - tx_status=00 errno=64
closing the connection
DEBUG: [ 5922751] unregistering all CEC clients
NOTICE: [ 5922751] unregistering client: libCEC version = 6.0.2, client version = 6.0.2, firmware version = 0, logical address(es) = Recorder 1 (1) , base device: TV (0), HDMI port number: 1, physical address: 1.0.0.0, compiled on Linux-4.19.0-14-arm64 ... , features: P8_USB, DRM, P8_detect, randr, Exynos, Linux, AOCEC
DEBUG: [ 5922751] Recorder 1 (1): power status changed from 'on' to 'unknown'
DEBUG: [ 5922751] Recorder 1 (1): vendor = Unknown (000000)
DEBUG: [ 5922751] Recorder 1 (1): CEC version unknown
DEBUG: [ 5922751] Recorder 1 (1): osd name set to 'Recorder 1'
DEBUG: [ 5922751] Recorder 1 (1): device status changed into 'unknown'
DEBUG: [ 5922751] CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0
DEBUG: [ 5922752] CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0
DEBUG: [ 5922752] CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=ffff
DEBUG: [ 5923758] CLinuxCECAdapterCommunication::Process - stopped - m_fd=3
opening a new connection
DEBUG: [ 5923758] CLinuxCECAdapterCommunication::Close - m_fd=3
DEBUG: [ 5923758] TV (0): device status changed into 'unknown'
DEBUG: [ 5923759] CLinuxCECAdapterCommunication::Open - m_fd=3 bStartListening=1
DEBUG: [ 5923759] CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_G_PHYS_ADDR - addr=ffff
WARNING: [ 5923759] CLinuxCECAdapterCommunication::Open - physical address is invalid
DEBUG: [ 5923759] CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0
DEBUG: [ 5923759] CLinuxCECAdapterCommunication::Open - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=1
DEBUG: [ 5923759] CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=ffff
NOTICE: [ 5923759] connection opened
DEBUG: [ 5923760] processor thread started
DEBUG: [ 5923760] << Broadcast (F) -> TV (0): POLL
TRAFFIC: [ 5923760] << f0
DEBUG: [ 5923903] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=f0 opcode=ffffffff
TRAFFIC: [ 5923903] << f0
DEBUG: [ 5924051] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=f0 opcode=ffffffff
DEBUG: [ 5924051] >> POLL not sent
DEBUG: [ 5924051] TV (0): device status changed into 'not present'
DEBUG: [ 5924051] registering new CEC client - v6.0.2
DEBUG: [ 5924051] SetClientVersion - using client version '6.0.2'
NOTICE: [ 5924052] setting HDMI port to 1 on device TV (0)
DEBUG: [ 5924052] << Broadcast (F) -> TV (0): POLL
TRAFFIC: [ 5924052] << f0
DEBUG: [ 5924199] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=f0 opcode=ffffffff
TRAFFIC: [ 5924199] << f0
DEBUG: [ 5924346] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=f0 opcode=ffffffff
DEBUG: [ 5924346] >> POLL not sent
DEBUG: [ 5924346] SetConfiguration: double tap timeout = 200ms, repeat rate = 0ms, release delay = 500ms
DEBUG: [ 5924346] detecting logical address for type 'recording device'
DEBUG: [ 5924346] trying logical address 'Recorder 1'
DEBUG: [ 5924346] << Recorder 1 (1) -> Recorder 1 (1): POLL
TRAFFIC: [ 5924346] << 11
ERROR: [ 5924346] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT failed - tx_status=00 errno=64
DEBUG: [ 5924346] using logical address 'Recorder 1'
DEBUG: [ 5924346] Recorder 1 (1): device status changed into 'handled by libCEC'
DEBUG: [ 5924346] Recorder 1 (1): power status changed from 'unknown' to 'on'
DEBUG: [ 5924346] Recorder 1 (1): vendor = Pulse Eight (001582)
DEBUG: [ 5924346] Recorder 1 (1): CEC version 1.4
DEBUG: [ 5924346] AllocateLogicalAddresses - device '0', type 'recording device', LA '1'
DEBUG: [ 5924347] CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=0
DEBUG: [ 5924347] CLinuxCECAdapterCommunication::SetLogicalAddresses - ioctl CEC_ADAP_S_LOG_ADDRS - log_addr_mask=0000 num_log_addrs=1
DEBUG: [ 5924347] Recorder 1 (1): osd name set to 'CECTester'
NOTICE: [ 5924347] setting HDMI port to 1 on device TV (0)
DEBUG: [ 5924347] << Recorder 1 (1) -> TV (0): POLL
TRAFFIC: [ 5924347] << 10
DEBUG: [ 5924347] CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=ffff
DEBUG: [ 5924489] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
TRAFFIC: [ 5924489] << 10
DEBUG: [ 5924636] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
DEBUG: [ 5924636] >> POLL not sent
DEBUG: [ 5924636] << Recorder 1 (1) -> broadcast (F): physical address 1000
TRAFFIC: [ 5924636] << 1f:84:10:00:01
ERROR: [ 5924636] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT failed - tx_status=00 errno=64
TRAFFIC: [ 5924637] << 1f:84:10:00:01
ERROR: [ 5924637] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT failed - tx_status=00 errno=64
DEBUG: [ 5924637] using device/input physical address FFFF
NOTICE: [ 5924637] CEC client registered: libCEC version = 6.0.2, client version = 6.0.2, firmware version = 0, logical address(es) = Recorder 1 (1) , base device: TV (0), HDMI port number: 1, physical address: 1.0.0.0, compiled on Linux-4.19.0-14-arm64 ... , features: P8_USB, DRM, P8_detect, randr, Exynos, Linux, AOCEC
DEBUG: [ 5924637] << Recorder 1 (1) -> TV (0): OSD name 'CECTester'
DEBUG: [ 5924637] << Recorder 1 (1) -> TV (0): POLL
TRAFFIC: [ 5924637] << 10
DEBUG: [ 5924784] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
TRAFFIC: [ 5924784] << 10
DEBUG: [ 5924931] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
DEBUG: [ 5924932] >> POLL not sent
DEBUG: [ 5924932] not sending command 'set osd name': destination device 'TV' marked as not present
DEBUG: [ 5924932] << requesting power status of 'TV' (0)
DEBUG: [ 5924932] << Recorder 1 (1) -> TV (0): POLL
TRAFFIC: [ 5924932] << 10
DEBUG: [ 5925079] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
TRAFFIC: [ 5925079] << 10
DEBUG: [ 5925227] CLinuxCECAdapterCommunication::Write - ioctl CEC_TRANSMIT - tx_status=24 len=1 addr=10 opcode=ffffffff
DEBUG: [ 5925227] >> POLL not sent
DEBUG: [ 5925227] not sending command 'give device power status': destination device 'TV' marked as not present
