Python RuntimeError: Failed to add edge detection when using GPIO on DietPi
[Yes] I have searched the existing open and closed issues
    G_DIETPI_VERSION_SUB=12
    G_DIETPI_VERSION_RC=1
  • Distro version | bookworm 1
  • Kernel version | Linux coktailmaschine 6.12.25+rpt-rpi-v6 #1 Raspbian 1:6.12.25-1+rpt1 (2025-04-30) armv6l GNU/Linux
  • Architecture | armhf
  • SBC model | RPi Zero W (armv6l)
  • Power supply used | 5V 3A
  • SD card used | SanDisk ultra
  • Hi everyone,
    I’m trying to run some simple Python GPIO code on my DietPi setup, but I’m running into this error:
    GPIO.setmode(GPIO.BCM) GPIO.setup(BUTTON_GPIO, GPIO.IN, pull_up_down=GPIO.PUD_UP) GPIO.setup(LED_GPIO, GPIO.OUT) GPIO.add_event_detect(BUTTON_GPIO, GPIO.BOTH, callback=button_callback, bouncetime=50)
    Error output:
    GPIO.add_event_detect(BUTTON_GPIO, GPIO.BOTH, ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ RuntimeError: Failed to add edge detection
    What I’ve tried so far:
    • Confirmed that I’m using the correct BCM pin numbers
    • Tried running the script with sudo
    • Checked that nothing else is using the GPIO pins
    • Updated DietPi and Python packages
    System details:
    • DietPi version: [your version here]
    • Raspberry Pi model: [your model here]
    • Python version: [your version here]
    • GPIO library: RPi.GPIO
    Has anyone else encountered this on DietPi? Is this a permissions or driver issue, or something with how DietPi handles GPIO?
    Thanks in advance!
