Problems with the settings dietpi-config / performance options
When comparing the settings of DietPi Bullseye on an RPi Zero W, I noticed that the system does not accept any changes in the performance options. Every change from e.g. ondemand to performance is set visually, but is not active after a reboot. Ondemand can therefore not be changed. What could be the problem?
How do you check for the current CPU governor?
With the command “cpu”. I switch from ondemand to performance, reboot and enter “cpu” and ondemand is issued again. I have done this several times, a change to the gouvenor is not applied.
maybe @MichaIng could have a look
Does no one have any idea what the problem could be?
