My hardware is a RPI 3B, 16G Sandisk SD card and a WE EasyStore 2T USB HDD, all of which worked great before my update.
After using v 5.9(ish) for several months flawlessly as a backup and media server, I noticed that I could update to v6.6 last night. So I did.
Since the update, I have a couple of problems that I’ll make separate posts for.
In this case, I’m concerned about my USB drive; if I run Drive_Manager, I see two drives. One listed as “vfat” at 42M and an “ext4” at 15G, but no large HDD.
Command “fdisk -l” gives this:
root@DietPi:~# fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 14.9 GiB, 15931539456 bytes, 31116288 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x27504eef
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 93802 85611 41.8M c W95 FAT32 (LBA)
/dev/mmcblk0p2 98304 31116287 31017984 14.8G 83 Linux
Disk /dev/sda: 1.8 TiB, 2000365289472 bytes, 3906963456 sectors
Disklabel type: gpt
Disk identifier: B95A329B-8696-4DE5-B2A7-0D5C4466D3B2
Device Start End Sectors Size Type
/dev/sda1 2048 3906961407 3906959360 1.8T Microsoft basic data
There’s clearly a 1.8T drive down near the end of that, but I’m not sure how to actually make it usable.
I’ve exhausted my limited knowledge and my [generic.search.engine]-foo isn’t strong enough for me to work through this, so I’m at a loss.
What else do I need to be doing to troubleshoot and fix this issue so I can keep backing up my data here easily?
