- DietPi version |
cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=9 G_DIETPI_VERSION_SUB=9 G_DIETPI_VERSION_RC=0 G_GITBRANCH='master' G_GITOWNER='MichaIng' G_LIVE_PATCH_STATUS[0]='applied' G_LIVE_PATCH_STATUS[1]='not applied' G_LIVE_PATCH_STATUS[2]='not applicable' G_LIVE_PATCH_STATUS[3]='not applicable'
- Distro version |
bookworm
- Kernel version |
uname --all
Linux DietPi 6.1.84-vendor-rk35xx #1 SMP Tue Dec 24 13:36:04 UTC 2024 aarch64 GNU/Linux
- Architecture |
dpkg --print-architecture
arm64
- SBC model |
echo $G_HW_MODEL_NAME
or (EG: RPi3) ROCK 5B (aarch64)
- Power supply used | 9V 2A
- SD card used | SanDisk ultra
- Software title | ustreamer
- Installed with crowsnest
- Propably yes
← If you sent a “dietpi-bugreport”, please paste the ID here → - Bug report ID | ``
- connecting two cameras and trying to use them
- there should be two streams that should work
- only one stream work and I get this error for the second camera in the logs
Can't start capturing: No space left on device
- I was looking for a solution and I found that USB cameras declare too much USB bandwidth usage and that it can be solved this way:
sudo rmmod uvcvideo; sudo modprobe uvcvideo quirks=128
but I get this errorrmmod: ERROR: Module uvcvideo is builtin.
