problem with odroidXu4
Hello
First of all, excuse my English is not so good.
I have a problem with installing on OdroidXU4 with dietpi image
I install normally on an SD card, the system also boots.
I do the configuration root paswort etc, the system boots again at some point.
After the new booting, however, everything starts all over again.
I have to re-enter the password and reinstall everything.
I have to say I had cloudshell2 running with the XU4 before if that has anything to do with it?
Failed-software is also available in the terminal.
Thank you for your help
Unfortunately, the problem still exists.
I flash Dietpi on a 32 gb micro sd. But the setup keeps starting over.
I don’t live this, with another image eg Armbian it all works out without any problems.
I had the same issue, but as of today the new install image seems to have fixed the install issue. You might try downloading and flashing the latest image.
Jep the issue should be fixed with v6.21. If you are still stuck in the loop, please cancel any dietpi-software prompt and do the following:
> /DietPi/dietpi/.update_stage
echo 1 > /DietPi/dietpi/.install_stage
dietpi-update 1
Thank you, the problem has been solved.
However, I still have a problem with Deluge.
I connected a USB HDD, formatted it into Ext4 and integrated it.
If I change the directory in Deluge I can’t download.
The standard directory/mnt/dietpi_userdata/downloads is normal.
As soon as I put back the directory of the HDD, it doesn’t work.
Note the the deluge run user (or dietpi group) requires R/W permissions on the download directory.
Deluge runs as user deluge and group dietpi, to allow other e.g. media software to access those files as well, do:
chown -R dietpi:dietpi /mnt/usb_drive
chmod -R 775 /mnt/usb_drive
  • Replace usb_drive by your actual mount point.
Thank you, I did.
However, the problem still exists.
The download starts briefly, and then nothing happens anymore.
Port is released, and the status of the tracker is ok, too.
I tried it with rtorrent, everything runs normally on the HDD directory. Unfortunately, I can’t specify a Socks5 with auth proxy at rtorrent
Okay no permissions issue if the download starts. Please check dmesg for any I/O or voltage errors.
I can exclude voltage errors.
With rtorrent, it runs smoothly on the external HDD.
I only have this bug at Deluge.
This does not necessarily exclude voltage errors, since rtorrent and deluge might access the drive in a different intense way.
Just to be sure: The USB HDD has it’s own power supply?
I will try to replicate when I can, currently busy with other stuff as well :wink:.
Yes, I have an external power supply on it.
It has 5v and 1.5A
Unfortunately, I’m not the professional in terms of that.
Here’s the edition of the dmesg
root@DietPi:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.14.66+ (root@loki) (gcc version 4.9.2 (Debian 4.9.2-10+deb8u1)) #1 SMP PREEMPT Thu Aug 23 05:59:33 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Hardkernel Odroid XU4
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 128 MiB at 0xb6800000
[ 0.000000] Samsung CPU ID: 0xe5422001
[ 0.000000] On node 0 totalpages: 518656
[ 0.000000] free_area_init_node: node 0, pgdat c0d8e980, node_mem_map eee25000
[ 0.000000] Normal zone: 1728 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 196608 pages, LIFO batch:31
[ 0.000000] HighMem zone: 322048 pages, LIFO batch:31
[ 0.000000] Running under secure firmware.
[ 0.000000] random: get_random_bytes called from start_kernel+0x8c/0x420 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu @eed65000 s37568 r8192 d23872 u69632
[ 0.000000] pcpu-alloc: s37568 r8192 d23872 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516928
[ 0.000000] Kernel command line: console=tty1 console=ttySAC2,115200n8 root=UUID=3032ee2a-4efc-40b6-9c1f-2839a840144d rootwait ro fsck.repair=yes net.ifnames=0 drm_kms_helper.edid_firmware=edid/1920x1080.bin smsc95xx.macaddr=00:1e:06:61:7a:72 governor=performance hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=true vout=hdmi s5p_mfc.mem=16M
[ 0.000000] hdmi: using HDMI mode
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1904740K/2074624K available (8192K kernel code, 655K rwdata, 2352K rodata, 1024K init, 329K bss, 38812K reserved, 131072K cma-reserved, 1157120K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0900000 (9184 kB)
.init : 0xc0c00000 - 0xc0d00000 (1024 kB)
.data : 0xc0d00000 - 0xc0da3f50 ( 656 kB)
.bss : 0xc0dab0b4 - 0xc0dfd5fc ( 330 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] hperf_hmp: fast CPUs mask: 000000F0
[ 0.000000] hperf_hmp: slow CPUs mask: 0000000F
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000000] clocksource: mct-frc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000008] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000032] genirq: irq_chip COMBINER did not update eff. affinity mask of irq 49
[ 0.001607] Console: colour dummy device 80x30
[ 0.002303] console [tty1] enabled
[ 0.002345] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=96000)
[ 0.002387] pid_max: default: 32768 minimum: 301
[ 0.002587] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002628] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003488] CPU: Testing write buffer coherency: ok
[ 0.004403] CPU0: thread -1, cpu 0, socket 1, mpidr 80000100
[ 0.020051] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.020680] ARM CCI driver probed
[ 0.020914] Exynos MCPM support installed
[ 0.027989] Hierarchical SRCU implementation.
[ 0.043990] smp: Bringing up secondary CPUs …
[ 0.072408] CPU1: thread -1, cpu 1, socket 1, mpidr 80000101
[ 0.096365] CPU2: thread -1, cpu 2, socket 1, mpidr 80000102
[ 0.124356] CPU3: thread -1, cpu 3, socket 1, mpidr 80000103
[ 0.152295] CPU4: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.172279] CPU5: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.180612] CPU6: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.188609] CPU7: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.188761] smp: Brought up 1 node, 8 CPUs
[ 0.188908] SMP: Total of 8 processors activated (384.00 BogoMIPS).
[ 0.188931] CPU: All CPU(s) started in HYP mode.
[ 0.188950] CPU: Virtualization extensions available.
[ 0.190731] devtmpfs: initialized
[ 0.208195] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.208395] hperf_hmp: registered cpufreq transition notifier
[ 0.208582] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.208622] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.211081] pinctrl core: initialized pinctrl subsystem
[ 0.213249] NET: Registered protocol family 16
[ 0.218358] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.224360] cpuidle: using governor menu
[ 0.225307] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.225336] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.233790] exynos-audss-clk 3810000.audss-clock-controller: epll 180633609
[ 0.256667] EXYNOS5420 PMU initialized
[ 0.303153] usbcore: registered new interface driver usbfs
[ 0.303223] usbcore: registered new interface driver hub
[ 0.303378] usbcore: registered new device driver usb
[ 0.303819] i2c-gpio soc:i2c-hdmi: using pins 177 (SDA) and 178 (SCL)
[ 0.304405] s3c-i2c 12c70000.i2c: slave address 0x00
[ 0.304433] s3c-i2c 12c70000.i2c: bus frequency set to 378 KHz
[ 0.304665] s3c-i2c 12c70000.i2c: i2c-1: S3C I2C adapter
[ 0.305170] media: Linux media interface: v0.10
[ 0.305219] Linux video capture interface: v2.00
[ 0.305331] pps_core: LinuxPPS API ver. 1 registered
[ 0.305351] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <> giometti@linux.it> >
[ 0.305613] s3c2410-wdt 101d0000.watchdog: watchdog inactive, reset disabled, irq disabled
[ 0.306467] Advanced Linux Sound Architecture Driver Initialized.
[ 0.307846] clocksource: Switched to clocksource mct-frc
[ 0.365975] VFS: Disk quotas dquot_6.6.0
[ 0.366068] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.379615] NET: Registered protocol family 2
[ 0.380262] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.380356] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.380524] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.380639] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.380690] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.380903] NET: Registered protocol family 1
[ 0.381580] RPC: Registered named UNIX socket transport module.
[ 0.381603] RPC: Registered udp transport module.
[ 0.381622] RPC: Registered tcp transport module.
[ 0.381641] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.381842] Trying to unpack rootfs image as initramfs…
[ 0.691856] random: fast init done
[ 0.720735] Freeing initrd memory: 5588K
[ 0.722344] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.723468] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.726878] audit: initializing netlink subsys (disabled)
[ 0.727096] audit: type=2000 audit(0.720:1): state=initialized audit_enabled=0 res=1
[ 0.727673] Initialise system trusted keyrings
[ 0.727917] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.734979] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.735890] NFS: Registering the id_resolver key type
[ 0.735926] Key type id_resolver registered
[ 0.735945] Key type id_legacy registered
[ 0.735974] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.736028] romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
[ 0.740640] Key type asymmetric registered
[ 0.740666] Asymmetric key parser ‘x509’ registered
[ 0.740730] bounce: pool size: 64 pages
[ 0.740793] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.741016] io scheduler noop registered
[ 0.741040] io scheduler deadline registered
[ 0.741291] io scheduler cfq registered (default)
[ 0.741313] io scheduler mq-deadline registered
[ 0.741333] io scheduler kyber registered
[ 0.741580] io scheduler bfq registered
[ 0.743988] samsung-usb2-phy 12130000.phy: 12130000.phy supply vbus not found, using dummy regulator
[ 0.744961] exynos5_usb3drd_phy 12100000.phy: 12100000.phy supply vbus not found, using dummy regulator
[ 0.745047] exynos5_usb3drd_phy 12100000.phy: 12100000.phy supply vbus-boost not found, using dummy regulator
[ 0.745427] exynos5_usb3drd_phy 12500000.phy: 12500000.phy supply vbus not found, using dummy regulator
[ 0.745520] exynos5_usb3drd_phy 12500000.phy: 12500000.phy supply vbus-boost not found, using dummy regulator
[ 0.750269] dma-pl330 3880000.adma: Loaded driver for PL330 DMAC-241330
[ 0.750297] dma-pl330 3880000.adma: DBUFF-4x8bytes Num_Chans-6 Num_Peri-16 Num_Events-6
[ 0.752901] dma-pl330 121a0000.pdma: Loaded driver for PL330 DMAC-241330
[ 0.752929] dma-pl330 121a0000.pdma: DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[ 0.755486] dma-pl330 121b0000.pdma: Loaded driver for PL330 DMAC-241330
[ 0.755514] dma-pl330 121b0000.pdma: DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[ 0.756563] dma-pl330 10800000.mdma: Loaded driver for PL330 DMAC-241330
[ 0.756590] dma-pl330 10800000.mdma: DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32
[ 0.820591] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.822859] 12c00000.serial: ttySAC0 at MMIO 0x12c00000 (irq = 58, base_baud = 0) is a S3C6400/10
[ 0.823266] 12c10000.serial: ttySAC1 at MMIO 0x12c10000 (irq = 59, base_baud = 0) is a S3C6400/10
[ 0.823658] 12c20000.serial: ttySAC2 at MMIO 0x12c20000 (irq = 60, base_baud = 0) is a S3C6400/10
[ 1.734358] console [ttySAC2] enabled
[ 1.738349] 12c30000.serial: ttySAC3 at MMIO 0x12c30000 (irq = 61, base_baud = 0) is a S3C6400/10
[ 1.748979] exynos-mixer 14450000.mixer: Linked as a consumer to 14650000.sysmmu
[ 1.754991] iommu: Adding device 14450000.mixer to group 0
[ 1.762031] exynos-hdmi 14530000.hdmi: Failed to get supply ‘vdd’: -517
[ 1.767938] exynos-drm-g2d 10850000.g2d: Linked as a consumer to 10a60000.sysmmu
[ 1.774676] exynos-drm-g2d 10850000.g2d: Linked as a consumer to 10a70000.sysmmu
[ 1.781996] iommu: Adding device 10850000.g2d to group 1
[ 1.787604] exynos-drm-g2d 10850000.g2d: The Exynos G2D (ver 4.1) successfully probed.
[ 1.796217] exynos-rot 11c00000.rotator: Linked as a consumer to 11d40000.sysmmu
[ 1.802527] iommu: Adding device 11c00000.rotator to group 2
[ 1.808483] exynos-rot 11c00000.rotator: The exynos rotator is probed successfully
[ 1.816474] exynos-drm-ipp exynos-drm-ipp: drm ipp registered successfully.
[ 1.826884] mali 11800000.mali: Continuing without Mali regulator control
[ 1.832998] mali 11800000.mali: GPU identified as 0x0620 r0p1 status 0
[ 1.839228] mali 11800000.mali: Protected mode not available
[ 1.844795] devfreq devfreq0: Couldn’t update frequency transition information.
[ 1.852356] mali 11800000.mali: Probed as mali0
[ 1.865827] brd: module loaded
[ 1.868066] libphy: Fixed MDIO Bus: probed
[ 1.871809] usbcore: registered new interface driver r8152
[ 1.877024] usbcore: registered new interface driver cdc_ether
[ 1.882832] usbcore: registered new interface driver cdc_subset
[ 1.890716] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.895866] ehci-exynos: EHCI EXYNOS driver
[ 1.900293] exynos-ehci 12110000.usb: EHCI Host Controller
[ 1.905444] exynos-ehci 12110000.usb: new USB bus registered, assigned bus number 1
[ 1.913382] exynos-ehci 12110000.usb: irq 80, io mem 0x12110000
[ 1.931900] exynos-ehci 12110000.usb: USB 2.0 started, EHCI 1.00
[ 1.936739] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.943237] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.950423] usb usb1: Product: EHCI Host Controller
[ 1.955270] usb usb1: Manufacturer: Linux 4.14.66+ ehci_hcd
[ 1.960847] usb usb1: SerialNumber: 12110000.usb
[ 1.965977] hub 1-0:1.0: USB hub found
[ 1.969177] hub 1-0:1.0: 3 ports detected
[ 1.974051] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.979287] ohci-exynos: OHCI EXYNOS driver
[ 1.983629] exynos-ohci 12120000.usb: USB Host Controller
[ 1.988829] exynos-ohci 12120000.usb: new USB bus registered, assigned bus number 2
[ 1.996538] exynos-ohci 12120000.usb: irq 80, io mem 0x12120000
[ 2.064141] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.069492] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.076980] usb usb2: Product: USB Host Controller
[ 2.081443] usb usb2: Manufacturer: Linux 4.14.66+ ohci_hcd
[ 2.086985] usb usb2: SerialNumber: 12120000.usb
[ 2.092164] hub 2-0:1.0: USB hub found
[ 2.095309] hub 2-0:1.0: 3 ports detected
[ 2.101556] mousedev: PS/2 mouse device common for all mice
[ 2.107022] i2c /dev entries driver
[ 2.124274] vdd_ldo9: Bringing 3300000uV into 3000000-3000000uV
[ 2.146651] vdd_sd: Bringing 3300000uV into 2800000-2800000uV
[ 3.232875] s5m-rtc s2mps14-rtc: rtc core: registered s5m-rtc as rtc0
[ 3.241734] s5p-jpeg 11f50000.jpeg: Linked as a consumer to 11f10000.sysmmu
[ 3.247316] iommu: Adding device 11f50000.jpeg to group 3
[ 3.252989] s5p-jpeg 11f50000.jpeg: encoder device registered as /dev/video30
[ 3.259918] s5p-jpeg 11f50000.jpeg: decoder device registered as /dev/video31
[ 3.266837] s5p-jpeg 11f50000.jpeg: Samsung S5P JPEG codec
[ 3.272502] s5p-jpeg 11f60000.jpeg: Linked as a consumer to 11f20000.sysmmu
[ 3.279280] iommu: Adding device 11f60000.jpeg to group 4
[ 3.284957] s5p-jpeg 11f60000.jpeg: encoder device registered as /dev/video32
[ 3.291923] s5p-jpeg 11f60000.jpeg: decoder device registered as /dev/video33
[ 3.298815] s5p-jpeg 11f60000.jpeg: Samsung S5P JPEG codec
[ 3.305354] s5p-mfc 11000000.codec: Linked as a consumer to 11200000.sysmmu
[ 3.311324] s5p-mfc 11000000.codec: Linked as a consumer to 11210000.sysmmu
[ 3.318192] iommu: Adding device 11000000.codec to group 5
[ 3.341483] s5p-mfc 11000000.codec: preallocated 16 MiB buffer for the firmware and context buffers
[ 3.349188] (NULL device *): Direct firmware load for s5p-mfc-v8.fw failed with error -2
[ 3.357161] s5p_mfc_load_firmware:73: Firmware is not present in the /lib/firmware directory nor compiled in kernel
[ 3.367723] s5p-mfc 11000000.codec: decoder registered as /dev/video10
[ 3.374218] s5p-mfc 11000000.codec: encoder registered as /dev/video11
[ 3.382985] exynos-gsc 13e00000.video-scaler: Linked as a consumer to 13e80000.sysmmu
[ 3.389433] iommu: Adding device 13e00000.video-scaler to group 6
[ 3.396744] exynos-gsc 13e10000.video-scaler: Linked as a consumer to 13e90000.sysmmu
[ 3.403292] iommu: Adding device 13e10000.video-scaler to group 7
[ 3.429081] thermal thermal_zone0: failed to read out thermal zone (-22)
[ 3.435229] thermal thermal_zone1: failed to read out thermal zone (-22)
[ 3.441926] thermal thermal_zone2: failed to read out thermal zone (-22)
[ 3.448673] thermal thermal_zone3: failed to read out thermal zone (-22)
[ 3.455298] thermal thermal_zone4: failed to read out thermal zone (-22)
[ 3.461782] device-mapper: uevent: version 1.0.3
[ 3.465954] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: > dm-devel@redhat.com
[ 3.488326] sdhci: Secure Digital Host Controller Interface driver
[ 3.493051] sdhci: Copyright(c) Pierre Ossman
[ 3.497566] Synopsys Designware Multimedia Card Interface Driver
[ 3.503972] dwmmc_exynos 12200000.mmc: IDMAC supports 32-bit address mode.
[ 3.510275] dwmmc_exynos 12200000.mmc: Using internal DMA controller.
[ 3.516622] dwmmc_exynos 12200000.mmc: Version ID is 250a
[ 3.522011] dwmmc_exynos 12200000.mmc: DW MMC controller at irq 83,64 bit host data width,64 deep fifo
[ 3.531410] dwmmc_exynos 12200000.mmc: allocated mmc-pwrseq
[ 3.561088] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[ 3.588229] dwmmc_exynos 12220000.mmc: IDMAC supports 32-bit address mode.
[ 3.593688] dwmmc_exynos 12220000.mmc: Using internal DMA controller.
[ 3.600086] dwmmc_exynos 12220000.mmc: Version ID is 250a
[ 3.605465] dwmmc_exynos 12220000.mmc: DW MMC controller at irq 84,64 bit host data width,64 deep fifo
[ 3.636324] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[ 3.664921] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.671977] s5p-secss 10830000.sss: s5p-sss driver registered
[ 3.676485] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.689803] exynos-nocp: new NoC Probe device registered: 10ca1000.nocp
[ 3.695063] exynos-nocp: new NoC Probe device registered: 10ca1400.nocp
[ 3.701671] exynos-nocp: new NoC Probe device registered: 10ca1800.nocp
[ 3.708661] exynos-nocp: new NoC Probe device registered: 10ca1c00.nocp
[ 3.718704] NET: Registered protocol family 17
[ 3.721704] NET: Registered protocol family 15
[ 3.726150] Key type dns_resolver registered
[ 3.730800] Registering SWP/SWPB emulation handler
[ 3.735519] registered taskstats version 1
[ 3.739193] Loading compiled-in X.509 certificates
[ 3.748697] Key type encrypted registered
[ 3.769783] OF: graph: no port node found in /soc/hdmi@14530000
[ 3.775103] [drm] Exynos DRM: using 14450000.mixer device for DMA mapping operations
[ 3.782093] exynos-drm exynos-drm: bound 14450000.mixer (ops 0xc09664e0)
[ 3.788646] exynos-drm exynos-drm: bound 14530000.hdmi (ops 0xc0966b80)
[ 3.795214] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.801806] [drm] No driver support for vblank timestamp query.
[ 3.807804] [drm] Cannot find any crtc or sizes
[ 3.812655] [drm] Initialized exynos 1.0.0 20110530 for exynos-drm on minor 0
[ 3.819546] [drm] Cannot find any crtc or sizes
[ 3.825252] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 3.829292] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
[ 3.837179] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x02010010
[ 3.845604] xhci-hcd xhci-hcd.3.auto: irq 150, io mem 0x12000000
[ 3.851681] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.858308] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.865500] usb usb3: Product: xHCI Host Controller
[ 3.868820] mmc_host mmc1: Bus speed (slot 0) = 200000000Hz (slot req 200000000Hz, actual 200000000HZ div = 0)
[ 3.869601] NOHZ: local_softirq_pending 40
[ 3.869617] NOHZ: local_softirq_pending 40
[ 3.870241] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 3.871021] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[ 3.871736] NOHZ: local_softirq_pending 40
[ 3.873555] mmcblk1: p1 p2
[ 3.906313] usb usb3: Manufacturer: Linux 4.14.66+ xhci-hcd
[ 3.911859] usb usb3: SerialNumber: xhci-hcd.3.auto
[ 3.917019] hub 3-0:1.0: USB hub found
[ 3.920461] hub 3-0:1.0: 1 port detected
[ 3.924532] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 3.929802] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
[ 3.937432] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[ 3.944066] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 3.952168] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.958828] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.966020] usb usb4: Product: xHCI Host Controller
[ 3.970870] usb usb4: Manufacturer: Linux 4.14.66+ xhci-hcd
[ 3.976416] usb usb4: SerialNumber: xhci-hcd.3.auto
[ 3.981566] hub 4-0:1.0: USB hub found
[ 3.985015] hub 4-0:1.0: 1 port detected
[ 3.990973] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 3.995006] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 5
[ 4.002833] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x02010010
[ 4.011327] xhci-hcd xhci-hcd.6.auto: irq 151, io mem 0x12400000
[ 4.017389] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.024027] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.031220] usb usb5: Product: xHCI Host Controller
[ 4.036070] usb usb5: Manufacturer: Linux 4.14.66+ xhci-hcd
[ 4.041615] usb usb5: SerialNumber: xhci-hcd.6.auto
[ 4.046744] hub 5-0:1.0: USB hub found
[ 4.050215] hub 5-0:1.0: 1 port detected
[ 4.054283] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[ 4.059561] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 6
[ 4.067185] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
[ 4.073815] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 4.081918] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.088584] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.095776] usb usb6: Product: xHCI Host Controller
[ 4.100627] usb usb6: Manufacturer: Linux 4.14.66+ xhci-hcd
[ 4.106173] usb usb6: SerialNumber: xhci-hcd.6.auto
[ 4.111309] hub 6-0:1.0: USB hub found
[ 4.114772] hub 6-0:1.0: 1 port detected
[ 4.119621] rtc rtc1: invalid alarm value: 1900-1-1 0:0:0
[ 4.124113] s3c-rtc 101e0000.rtc: rtc core: registered s3c as rtc1
[ 4.131319] exynos-bus: new bus device registered: soc:bus_wcore ( 84000 KHz ~ 400000 KHz)
[ 4.138816] exynos-bus: new bus device registered: soc:bus_noc ( 67000 KHz ~ 100000 KHz)
[ 4.146766] exynos-bus: new bus device registered: soc:bus_fsys_apb (200000 KHz ~ 200000 KHz)
[ 4.155209] exynos-bus: new bus device registered: soc:bus_fsys (200000 KHz ~ 200000 KHz)
[ 4.163466] exynos-bus: new bus device registered: soc:bus_fsys2 ( 75000 KHz ~ 150000 KHz)
[ 4.171772] exynos-bus: new bus device registered: soc:bus_mfc ( 96000 KHz ~ 333000 KHz)
[ 4.179801] exynos-bus: new bus device registered: soc:bus_gen ( 89000 KHz ~ 267000 KHz)
[ 4.187776] exynos-bus: new bus device registered: soc:bus_peri ( 67000 KHz ~ 67000 KHz)
[ 4.196074] exynos-bus: new bus device registered: soc:bus_g2d ( 84000 KHz ~ 333000 KHz)
[ 4.204084] exynos-bus: new bus device registered: soc:bus_g2d_acp ( 67000 KHz ~ 267000 KHz)
[ 4.212469] exynos-bus: new bus device registered: soc:bus_jpeg ( 75000 KHz ~ 300000 KHz)
[ 4.220609] exynos-bus: new bus device registered: soc:bus_jpeg_apb ( 84000 KHz ~ 167000 KHz)
[ 4.229033] exynos-bus: new bus device registered: soc:bus_disp1_fimd (120000 KHz ~ 200000 KHz)
[ 4.237737] exynos-bus: new bus device registered: soc:bus_disp1 (120000 KHz ~ 300000 KHz)
[ 4.245971] exynos-bus: new bus device registered: soc:bus_gscl_scaler (150000 KHz ~ 300000 KHz)
[ 4.254793] exynos-bus: new bus device registered: soc:bus_mscl ( 84000 KHz ~ 400000 KHz)
[ 4.262837] samsung-i2s 3830000.i2s: ASoC: Failed to create component debugfs directory
[ 4.270501] samsung-i2s 3830000.i2s: ASoC: Failed to create component debugfs directory
[ 4.278998] odroid-audio sound: multicodec <-> 3830000.i2s mapping ok
[ 4.288151] s5m-rtc s2mps14-rtc: setting system clock to 2019-02-09 15:27:12 UTC (1549726032)
[ 4.299781] ALSA device list:
[ 4.301296] #0: Odroid-XU4
[ 4.305190] Freeing unused kernel memory: 1024K
[ 4.334883] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 4.340917] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 4.345535] random: udevadm: uninitialized urandom read (16 bytes read)
[ 4.411871] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[ 4.568535] usb 3-1: New USB device found, idVendor=05e3, idProduct=0610
[ 4.573792] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.580894] usb 3-1: Product: USB2.0 Hub
[ 4.584784] usb 3-1: Manufacturer: GenesysLogic
[ 4.616509] hub 3-1:1.0: USB hub found
[ 4.619284] hub 3-1:1.0: 2 ports detected
[ 4.679895] NOHZ: local_softirq_pending 80
[ 4.683329] NOHZ: local_softirq_pending 40
[ 4.683906] NOHZ: local_softirq_pending 80
[ 4.687905] NOHZ: local_softirq_pending 80
[ 4.694796] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 4.703431] NOHZ: local_softirq_pending 40
[ 4.706079] NOHZ: local_softirq_pending 40
[ 4.714562] NOHZ: local_softirq_pending 40
[ 4.722711] usb 4-1: New USB device found, idVendor=05e3, idProduct=0616
[ 4.727983] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.735551] usb 4-1: Product: USB3.0 Hub
[ 4.739630] usb 4-1: Manufacturer: GenesysLogic
[ 4.760994] hub 4-1:1.0: USB hub found
[ 4.763585] hub 4-1:1.0: 2 ports detected
[ 5.279978] usb 6-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 5.304795] usb 6-1: New USB device found, idVendor=0bda, idProduct=8153
[ 5.310052] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 5.317151] usb 6-1: Product: USB 10/100/1000 LAN
[ 5.321833] usb 6-1: Manufacturer: Realtek
[ 5.325900] usb 6-1: SerialNumber: 000001000000
[ 5.497924] usb 6-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 5.564870] r8152 6-1:1.0 eth0: v1.09.9
[ 5.787473] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.025081] NET: Registered protocol family 10
[ 6.028791] Segment Routing with IPv6
[ 6.036893] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.056981] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 6.073939] systemd[1]: Detected architecture arm.
[ 6.107088] systemd[1]: Set hostname to .
[ 6.298111] systemd[1]: getty-static.service: Cannot add dependency job, ignoring: Unit getty-static.service is masked.
[ 6.307649] systemd[1]: systemd-logind.service: Cannot add dependency job, ignoring: Unit systemd-logind.service is masked.
[ 6.320404] systemd[1]: Created slice System Slice.
[ 6.339971] systemd[1]: Reached target Remote File Systems.
[ 6.364028] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.384023] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.404005] systemd[1]: Listening on udev Kernel Socket.
[ 6.809303] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 7.149442] Adding 55284k swap on /var/swap. Priority:-2 extents:2 across:151544k SS
[ 7.385338] systemd-journald[225]: Received request to flush runtime journal from PID 1
[ 7.498713] gpiomem-exynos 13400000.gpiomem: Initialised: GPIO register area is 2
[ 7.505171] gpiomem-exynos 13400000.gpiomem: Initialised: Registers at 0x13400000
[ 7.509276] Driver for 1-wire Dallas network protocol.
[ 7.517337] gpiomem-exynos 13400000.gpiomem: Initialised: Registers at 0x14010000
[ 7.518000] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[ 7.558578] s5p-mfc 11000000.codec: Direct firmware load for s5p-mfc-v8.fw failed with error -2
[ 7.565894] s5p_mfc_load_firmware:73: Firmware is not present in the /lib/firmware directory nor compiled in kernel
[ 7.576660] s5p-mfc 11000000.codec: Direct firmware load for s5p-mfc-v8.fw failed with error -2
[ 7.584986] s5p_mfc_load_firmware:73: Firmware is not present in the /lib/firmware directory nor compiled in kernel
[ 10.114194] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.139083] r8152 6-1:1.0 eth0: carrier on
[ 10.141947] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.263896] usb 3-1.2: new high-speed USB device number 3 using xhci-hcd
[ 10.315908] random: crng init done
[ 10.317843] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.368727] usb 3-1.2: New USB device found, idVendor=152d, idProduct=2338
[ 10.374212] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 10.381469] usb 3-1.2: Product: USB to ATA/ATAPI bridge
[ 10.386681] usb 3-1.2: Manufacturer: JMicron
[ 10.390939] usb 3-1.2: SerialNumber: 000000000000
[ 10.419725] SCSI subsystem initialized
[ 10.429877] usb-storage 3-1.2:1.0: USB Mass Storage device detected
[ 10.436585] scsi host0: usb-storage 3-1.2:1.0
[ 10.440467] usbcore: registered new interface driver usb-storage
[ 10.450442] usbcore: registered new interface driver uas
[ 11.462383] scsi 0:0:0:0: Direct-Access ST8000AS 0002-1NA17Z PQ: 0 ANSI: 5
[ 11.497269] scsi 0:0:0:0: Attached scsi generic sg0 type 0
[ 11.504295] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[ 11.510389] sd 0:0:0:0: [sda] 15628053168 512-byte logical blocks: (8.00 TB/7.28 TiB)
[ 11.518312] sd 0:0:0:0: [sda] Write Protect is off
[ 11.522754] sd 0:0:0:0: [sda] Mode Sense: 28 00 00 00
[ 11.523074] sd 0:0:0:0: [sda] No Caching mode page found
[ 11.528033] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 11.534801] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[ 21.732109] sda: sda1
[ 21.735494] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[ 21.743090] sd 0:0:0:0: [sda] Attached SCSI disk
[ 22.550941] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
dmesg looks good so far, USB device detected as SCSI and mounted successfully and no error messages.
Yeah as said will try that as well on testing system with external drive.
Thank you, I had also read about the problem in other forums.
But not at dietpi.
Unfortunately, I did not find a solution to the problem there either.
Thank you for their support
